Old 11-16-2011, 07:41 PM   #56926
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,966
Originally Posted by Stringer99 View Post
Hey guys I've got this engine apart, guess im going to go OEM piston and rings with a professional deglaze/cross hatch. But how do I clean up the head like this? Sure would like everything brand new looking when I start to bolt her together.
how many miles on the motor?
if less than 25k, why waste the time effort & $?
gasket it & ride on
plugeye is offline   Reply With Quote
Old 11-16-2011, 07:49 PM   #56927
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,392
Originally Posted by ER70S-2 View Post
Check the gap at the bottom of ring travel, it most likely has the smallest, least worn diameter. The problem is too tight, not too loose. As the cylinder heats and expands, the gap gets smaller. If the gap is too small the ring will bind/seize in the cylinder, with really bad results.
http://www.macdizzy.com/1989jhopup.htm
Originally Posted by motolab View Post
The gap would get larger as the cylinder heats and expands. I think the rings get hot enough where the cylinder expanding away from the rings is not enough to compensate for how much the rings grow.
Regards,
Derek
I'm going to vote with ER70S. The gap gets smaller at higher engine temps. I used some Keith Black hypereutectic pistons on a V8 I built and they call for a huge gap on the top ring because the top ring groove is closer to the top of the piston than most pistons. I think it was .035 gap for the top ring on a 4 1/8 inch piston. I had to grind a lot off the top rings to arrive at that spec. They said if you didn't run that large of a gap the rings would expand and the ends would butt together and sieze/break ring lands, etc.
And of course the aluminum piston expands in the bore as it heats up which also makes the ring gap smaller.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 11-16-2011, 07:57 PM   #56928
Stringer99
Oddometer: 183
gasket it & ride on
4700 miles. what all is involved?
Stringer99 is offline   Reply With Quote
Old 11-16-2011, 08:06 PM   #56929
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,966
basically a new motor, barely broken in.
Old 11-16-2011, 08:13 PM   #56930
motolab
motolab's Avatar
Oddometer: 2,851
You may want to re-read. I didn't disagree.
The piston expanding does not make the ring gap smaller.
Regards,
Derek
motolab is offline   Reply With Quote
Old 11-16-2011, 09:57 PM   #56931
trailrider383
867-5309
Oddometer: 3,392
OK
Now that I think about it you are probably right. There is clearance behind the ring at the bottom of the ring groove also.
Regards,
Derek
Old 11-17-2011, 12:29 AM   #56932
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
And just a heads up. Turns out the absence of an exposed rivet in your base gasket does NOT guarentee your base gasket is paper. Mine has no rivets and was made of metal with a thin rubberized coating.
What year bike?
NordieBoy is offline   Reply With Quote
Old 11-17-2011, 03:07 AM   #56933
jon_l
jon_l's Avatar
Oddometer: 3,459
Originally Posted by doug s. View Post
after:
i am wery happy w/how it turned out.
doug s.
As well you should be Doug. That is beautiful!
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 11-17-2011, 06:47 AM   #56934
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,198
+1, awesome work doug, nicely done.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 11-17-2011, 06:57 AM   #56935
Stringer99
Oddometer: 183
Originally Posted by NordieBoy View Post
What year bike?
2003
Anyone know how to clean up an engine and remove all carbon? thanks.
Old 11-17-2011, 07:26 AM   #56936
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,090
There are a number of ways; however, aluminum is less heat tolerant than cast iron. You can bake it (lower temps, less time than cast), you can soak/spray it, you can use a soda blast, etc. Honestly, I' probably use soap and water with a household plastic scrub brush if I were doing it myself since the head doesn't look very bad. Also, any machine shop will be able to do it for you for a nominal charge.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 11-17-2011, 07:55 AM   #56937
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,082
I'm working on the exact same thing at the moment but mine has a LOT more miles on it and compression issues.
It you have one nearby, you can drop off the fully disassembled head to an engine shop and they can hot soak it.
It also depends on what equipment you have available. If you have blasting equipment, then after an initial cleaning, soda blasting would be ideal but you could also use a VERY mild glass bead or walnut shell. I actually use some completely worn out (almost powdered dust) glass bead for stuff like this BUT make sure all valve stem openings are completely blocked off. Afterwards Wash the living tar out of it. Use a dishwasher (twice) if you're single or your wife is out of town. Seriously.
If you don't have access to a cabinet then chemicals (carb cleaner, brake cleaner, all the nasty crap. etc) brass brushes and patience. DO NOT damage the valve seats. Re lap them (look it up) when you're done for good measure.
Oh and be sure to keep track of what valve went where. Yes it matters.
FloridaSteve is offline   Reply With Quote
Old 11-17-2011, 07:58 AM   #56938
SkunkWizard
recycle crime scene tape
SkunkWizard's Avatar
Oddometer: 762
Low Front Fender
I too like a low fender on the DR. The riding I do here in so. Cal Does not require a need for a high clearance fender. I had an old front fender from my Bultaco Pursang in the shed. I modified it and used it for a plug to make a fiberglass mold to fit with an RSW fork brace. I laid up two plies of Kevlar, one ply carbon fiber. Then masked off a section of C/F and painted it OEM DR blue. It’s been in a few wrecks (broken femur 2010) since the pictures were taken a few years ago and it still looks ok sans some scratches. The memory of the Kevlar allows it to flex quite a bit and come back to org.
here is a recent pic
~DR 650~
Upgrades:
1. dented tank
SkunkWizard screwed with this post 11-17-2011 at 08:04 AM
SkunkWizard is offline   Reply With Quote
Old 11-17-2011, 08:59 AM   #56939
vintagespeed
fNg
Oddometer: 1,855
Eek
2003 Anyone know how to clean up an engine and remove all carbon? thanks.
that head doesn't need cleaning from the pic above. but if you really must, just get some good solvent and a wire brush, it'll clean up just like new. hell, it's only 4700mi old. it IS new.
and when you're working on stuff, if you have to YANK or PRY, you're doing it wrong. slow down & take your time. dont let those monkeys at the machine shop bore all the plating off your cylinder bud. a new cylinder is very, VERY pricey.
vintagespeed is offline   Reply With Quote
Old 11-17-2011, 09:42 AM   #56940
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 828
May Be 'new to me' SUPERMOTO WHEEL QUESTION
I am looking at a used and farkled DR650. He has two sets of wheels, the second set being 17" with some street tires on them. Excel rims on 'zuk hubs, bearings, extra rotors, etc.
I am not quite sure how much they are worth above and beyond the price of the bike. I am told he has $1300 in them, but obviously used they aren't worth that much. What is the resale market on them? That will tell me what they are worth to purchase with the bike.
thanks
Themastermike is online now   Reply With Quote
Times are GMT -7.   It's 09:16 PM.
