Old 11-29-2011, 12:01 PM   #57391
ER70S-2
ER70S-2's Avatar
Oddometer: 6,870
Originally Posted by Fitryder View Post
Hello all,
What the hell?
Btw I have the large 30L + safari tank
t....
The petcocks are so low on the Safari that the fuel line has to make a 'tall' loop to get on the carb inlet. That will trap air and literally vapor lock.
So if the tank is anywhere below half (guesstimate), the bike might stall. Next time it happens add fuel to raise the fuel pressure in the tank (head).
There's a video on how to twist the carb inlet, done by someone at Safari. But I'm late and have to leave.
This is not the issue if it's happening with a full-ish fuel tank.
205'd
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-29-2011, 12:04 PM   #57392
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Help!!!
Took the DR for a ride today with the new TM-40 carb. When I first starting the bike, i let it run for a few mins with the choke on, and when I shut it off, the bike died, Just figured it still cold, so I started again, and just rode with choke off, throttle up. it was all street riding, mostly on the highway, only about 20 miles, and died at one light when I bleeped the throttle. I got home and it felt like the idle was a bit low, so i turned the knob in a little bit it while sitting on the bike. I smelled gas, but thought nothing of it. Got off the bike while it was running, and saw fuel spilling out of the vent hose. I followed the vent hose up, and it was the one under the Idle adjustment (see pic). What is this from? When I shut the petcock off, the fuel stops flowing from the vent hose.
I would like some advice before I start pulling the carb apart, Thanks guys..
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 11-29-2011, 12:07 PM   #57393
ER70S-2
ER70S-2's Avatar
Oddometer: 6,870
Originally Posted by newride View Post
so if I get out the metal shell, the rubber seal should go in? It doesn't need a new metal shell? So why does the metal need to be in there? The new seal has no metal piece with it.
The metal shell is rubber coated, it is the seal, that's why you had so much trouble getting the rubber peeled out of the wheel. Try to bend your new seal, it isn't the rubber giving that stiffness.
2013 WR250R
Old 11-29-2011, 12:13 PM   #57394
newride
newride's Avatar
Oddometer: 704
ahhhh, Thanks so much.
Now to get that metal piece out without destroying the bearings.........
1975 BMW R90/6
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 11-29-2011, 01:03 PM   #57395
planemanx15
Oddometer: 1,009
Ughh.. The worst kind of problem... I went out to the bike after it cooled and bit and tried to simulate the problem again... No luck
Old 11-29-2011, 01:23 PM   #57396
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,384
The rubber body of the seal is normally bonded to/over that metal part.
That wheel bearing does not look to flash either (an easy replacement)
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 11-29-2011, 01:35 PM   #57397
GISdood
GISdood's Avatar
Oddometer: 856
Here's that video...
GISdood is offline   Reply With Quote
Old 11-29-2011, 01:38 PM   #57398
steve o 77
steve o 77's Avatar
Oddometer: 50
someone correct me if Im wrong but I think that means the float is set way too high allowing the bowl to overfill.
1981 XS650 - Cafe'd, sorta, 2006 CRF250R mufflers, pod filters
steve o 77 is offline   Reply With Quote
Old 11-29-2011, 01:50 PM   #57399
ADV8
ADV8's Avatar
Oddometer: 2,384
I can't remember if the hose in the picture goes to the bowl drain (probably not) or up via a internal tube to a overflow but.........
My TM40 has done this a few times over the last few years for no apparent reason.
Once was coming into Top Springs (dirt road in the middle of nowhere) and noticed it exiting fuel from a hose.
Stripped the carb but found no obvious signs of the fuel seat not seating.
Another time I came out of a large hardware store to find the bike sitting over a '3 foot puddle of fuel.
Could the float stick once in a blue moon is still ??????????
I never leave the fuel taps on,if it was to run down the inlet tract that might risk hydraulic ing the engine also.
Old 11-29-2011, 01:50 PM   #57400
epix1718
epix1718's Avatar
Oddometer: 729
Mine did this as well, I removed the carb to adjusted the float and has never occurred again. Pretty simple to do, I was a newb and got it on my first try. Maybe it was just beginners luck
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Old 11-29-2011, 02:18 PM   #57401
steve o 77
steve o 77's Avatar
Oddometer: 50
It also stripes oil off the cylinder walls accelerating wear on the piston rings and cylinder.
lol yeah that is pretty lucky. There are lots of techniques for setting the bowl height, I've never done it though.
Old 11-29-2011, 02:41 PM   #57402
procycle
procycle's Avatar
Oddometer: 2,402
More likely a little bit of dirt or debris is stuck in the float valve.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-29-2011, 05:24 PM   #57403
newride
newride's Avatar
Oddometer: 704
stock foot pegs for DR
Does anyone have a stock close up photo of their stock DR foot pegs? Took mine apart, painted them. Kind of forgot exactly how they sit on the bike. I think I have it, but I am losing my mind thinking about it.
Mahalo,
1975 BMW R90/6
Old 11-29-2011, 05:43 PM   #57404
epix1718
epix1718's Avatar
Oddometer: 729
Mahalo,
Don't have a pic on the bike but here is a diagram that may help
97 Suzuki DR650
98 Honda XR250R
Old 11-29-2011, 06:03 PM   #57405
newride
newride's Avatar
Oddometer: 704
Thank you brother. yes it surely does.
1975 BMW R90/6
Times are GMT -7.   It's 03:07 AM.
