Old 12-04-2011, 02:36 AM   #57571
mercenario27
mercenario27's Avatar
Oddometer: 61
Originally Posted by ER70S-2 View Post
This wasn't my idea, learned it here:
Is that yellow thing screwed into the airbox a prefilter you made for your open airbox. I just used a nitro r/c car engine air cleaner for my breather.
Current
1997 Suzuki DR650 & 2006 Honda CB900F 919 Hornet
Gone
1996 Suzuki GSF750 Kan.of.tuna & 1986 Honda VF700 Intercepter
mercenario27 is offline   Reply With Quote
Old 12-04-2011, 04:59 AM   #57572
exoff-roadgoat
Will ride for food
exoff-roadgoat's Avatar
Oddometer: 4,393
Originally Posted by shu View Post
That's a good question. I ordered one and started to put it in but quickly took it back out. It is painted and after about the first 2 turns in it got *very tight*. I don't know if the theads were not right or if the paint made it so tight. Anyway, I took it back out and put my stock plug back in. I'm not going to mess around and screw up the threaded hole in the case.
............shu
Same here. I bought my mag plug at Auto Zone. It went in a little harder than it should and when I removed it at the next oil change the threads were bunged up. I put the stocker back in but need to get a quality mag plug for the next oil change. My 07, 4000 mile DR needs to have the NSU checked this winter, valves too. She sure runs quiet and smooth right now.
exoff-roadgoat is offline   Reply With Quote
Old 12-04-2011, 09:20 AM   #57573
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Carb probs
Hi guys, I'm trying to get a handle on this so I can get at it today. Hopefully everyone is out riding istead of answering this. Iced up here so maintenance time. I'm having a stutter in the first third throttle range. I found this pick and have been reading as much as possible, but can't wrap my head around it for some reason. I have a bone stock 09 DR, only thing I've changed is the air filter. To a K&N and took out the snorkel. So I found this pic and have a few questions,
Does the carb have to come off to get at this fuel mixture screw? And what should it be set at (turns) once I get in to it. Has anyone had the same issue and found adjusting this to be the answer? Thanks
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 12-04-2011, 09:26 AM   #57574
sagebrushocean
Harris's hawker
sagebrushocean's Avatar
Oddometer: 180
Originally Posted by asrvivor View Post
... but can't wrap my head around it for some reason.
Part of the reason you're having trouble figuring it out is that this diagram shows the idle mixture screw adjusting airflow, whereas the idle mixture screw on your carb adjusts fuel flow by being inside the pilot ("slow") jet. On the stock carb the fuel screw is covered by a removable plug. Once the plug is popped out, you can adjust the mixture (screw in to lean the mixture, out to richen).
2008 DR650SE supermoto
2009 CRF230M
sagebrushocean is offline   Reply With Quote
Old 12-04-2011, 09:31 AM   #57575
Stringer99
Oddometer: 183
Originally Posted by Ken E Ahnung View Post
Id say its definately either the 5x8 cam knock pin, or the 5x8 shifter pin. Here is a pic of my cam pin.
Stringer99 is offline   Reply With Quote
Old 12-04-2011, 09:38 AM   #57576
ER70S-2
ER70S-2's Avatar
Oddometer: 7,223
It's a prefilter made for snowmobiles, used to change jetting as the weather changed, by controlling airflow. They came in a 2 or 3 pack from Thunder Products.
Do you have a pic or link of the RC filter?
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 12-04-2011, 11:10 AM   #57577
gumbometer
hairy reasoner
gumbometer's Avatar
Oddometer: 36
Excellent! I know where the pins are in the shifter cam-driven gear, but is there another name for the "cam knock pin"? I'm not sure what/where that is. Thanks loads for taking the time to help me figure this out. I want to get back on the road!
gumbometer is offline   Reply With Quote
Old 12-04-2011, 11:19 AM   #57578
ER70S-2
ER70S-2's Avatar
Oddometer: 7,223
Number 3 here:
http://www.bikebandit.com/2004-suzuk...5873#sch502856
2013 WR250R
Old 12-04-2011, 11:54 AM   #57579
gumbometer
hairy reasoner
gumbometer's Avatar
Oddometer: 36
Oh, I hope it's not that one! Still, not impossible to reach...Looking at it in the service manual, I can't tell if there's a gasket between the cylinder head cover and the head itself. The manual doesn't mention one, but it seems like there would be one there. Is there? Once again, thank you!
Old 12-04-2011, 12:08 PM   #57580
Stringer99
Oddometer: 183
That gets sealed with Suzuki 1207B silicone gasket or equivilent.
Old 12-04-2011, 12:41 PM   #57581
gumbometer
hairy reasoner
gumbometer's Avatar
Oddometer: 36
You guys are saving me a lot of hair-pulling. Thank you!
Old 12-04-2011, 02:17 PM   #57582
Speedo66
Transient
Oddometer: 6,930
Have a Mikuni T-38 flatside carb for sale, heard it works well on the DR's.
http://www.advrider.com/forums/showthread.php?t=739140
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 12-04-2011, 04:14 PM   #57583
vintagespeed
fNg
Oddometer: 1,850
Originally Posted by rglee View Post
Help! My DR ran perfect.....While it's missing/hesitating I can roll on the throttle and it accelerates perfectly.....
my guess is too lean. try taping the hole in your airbox up & give it another ride. when i re-jetted my bike back to stock for mileage for the LAB2V last week, i had to close up the airbox to richen it up.
vintagespeed is offline   Reply With Quote
Old 12-04-2011, 07:07 PM   #57584
sect8dr
ride them all
Oddometer: 244
New to me
I just picked up my second DR the other day, its an 05 with 5000 miles on it, first one was an 01 and got rid of it at 25000 miles. the 05 has a whine when in third gear but other than that runs like a champ. The 01 had a procycle high perf kit in it and ran real strong, but it had no whine at all from the tranny. I guess my question would be how long can i let this whine go without looking into it. is there some kind of oil that is better for the tranny? i always run Mobil 1 4T in every bike of mine. I read about the neutral switch screws and will probably do that at some point this winter, any tips on making it last would be great.
sect8dr is online now   Reply With Quote
Old 12-04-2011, 08:57 PM   #57585
Magnum Noel
Magnum Noel's Avatar
Oddometer: 196
but need to get a quality mag plug for the next oil change[ quote]
I'm sure the magnetic sump plug I got through the local Suzuki Dealer was from another suzuki bike. The bloke behind the counter seemed suprised it didn't have one as standard.
Magnum Noel is offline   Reply With Quote
Times are GMT -7.   It's 01:51 PM.
