Old 01-07-2012, 08:08 AM   #58711
asrvivor
Rabies Cure ????
asrvivor's Avatar
Oddometer: 1,877
Brake lever
Hi guys, I bent the hell outta my rear brake foot lever. It has always been fairly useless as i put the lowered pegs on and couldn't get it lowered enough to make for ease of use. Now I took a spill and bent it pretty good. What I'm wondering is has anyone taken the lever off and cut and re welded it in a lower position? Any pics? Thanks john
Staring straight into the shining sun....
Just cause I'm wrong, don't make you right / Needtobreathe
Our OBDR Trip http://advrider.com/forums/showthread.php?t=712724
Our UTBDR Trip http://advrider.com/forums/showthread.php?t=816500
asrvivor is offline   Reply With Quote
Old 01-07-2012, 08:21 AM   #58712
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,839
Originally Posted by Adv Grifter
There are several references in this thread about DR350 wheels. Far as I know they bolt right up. It's an 18" rear, which some prefer. Not sure if ALL DR350's are minus Cush Drive. Remember, there were 3 different DR350 models. Basically one street legal, one off road.
I've owned two DR350SEs, a '97 and a '99. Yes, there are three different models; DR350, DR350S, DR350SE. The "S" indicates "street" and the "E" indicates "electric start". The DR350S was offered from 1990-93, the DR350SE was offered from 1994-99.
Originally Posted by Rusty Rocket
Pretty sure the wheels will work, (same swingarm on all 350 models) but I personally wouldn't put one on my 650 that didn't have the cush drive.
You will have to purchase a DR650 brake rotor to use any DR350 wheel.
A quick look at the on-line fiche shows a cush-drive hub on a '95 DR350SE but not on the '96 model. I also see some posts over @ TT that report cush drive rear hubs on 1990-95 DR350S/SE and non cush drive hubs on 1996-99 DR350SE. My two DR350SEs did not have cush drive rear hubs. The DR350 (non-street legal version) never had cush drive rear hubs.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 01-07-2012, 08:31 AM   #58713
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,150
Originally Posted by planemanx15 View Post
all this suspenion talk is blowing my ming, it sounds so confusing... is there some kind of dummies guide to suspensions online?
Sure beats saddlebags and windshield chatter.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-07-2012, 09:53 AM   #58714
TrophyHunter
Oddometer: 2,192
I bought this http://www.amazon.com/Techs-Motorcyc.../dp/0760331405 but haven't had a chance to get thru it. Lots of tech stuff online but I still like having books.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 01-07-2012, 10:03 AM   #58715
JagLite
JagLite's Avatar
Oddometer: 1,200
Talking Suspender tuning
Here you go...
http://drriders.com/topic3218.html
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 01-07-2012, 10:17 AM   #58716
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Ned Suesse (Neduro on ADV) has an eBook that covers it all pretty well. It can be downloaded here for $14. Well worth it. BTW Ned's in the Dakar this year and knows his stuff.
Dual Sport Suspension Ebook
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 01-07-2012, 10:27 AM   #58717
Mtn Man
Mtn Man's Avatar
Oddometer: 210
Transmission Question / Gears
Hey guys need a little wisdom from those with more DR experience. My buddy and I are noticing some issues with the DR popping out of 2nd gear from time to time. It happens to me mostly when farting around in the mountains but my buddy is now experiencing the problem while riding to work. Thoughts? Problem? The reason I ask one of our friends was changing his oil a couple weeks ago and found a metal shaving on his mag oil plug ... long story short it appears to be a gear issue and now a major repair is under way.
Mtn Man is offline   Reply With Quote
Old 01-07-2012, 10:32 AM   #58718
Rusty Rocket
Life behind "Bars"
Oddometer: 9,150
See if the shifter is hitting the case when you shift. May have bent it or the shift shaft. Or may just have to reposition the lever.
2009 DR650
Old 01-07-2012, 10:44 AM   #58719
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Thanas View Post
The question is, will 15-43 require a longer than 110 link chain on the DR?
Thanks,
Thanas
Hi Thanas,
For DR650 parts in Europe try Hessler:
http://www.hessler-motorsport.de/sit...d=45&Itemid=75
They have a really good selection of DR parts.
The 110 chain will be fine going to a 43T rear sprocket. No problem. You could also use a 14T front sprocket ... will help to give you lower gearing.
In any case, buy NEW sprockets when you buy your NEW chain. If you do commuting and lots of kms, I recommend the 525 DID X-Ring VM-2 chain. It's very strong and worth the extra money. Will last OVER 20,000 miles
(30K kms)
Adv Grifter screwed with this post 01-07-2012 at 10:55 AM
Old 01-07-2012, 10:52 AM   #58720
Adv Grifter
Oddometer: 6,128
Rusty's point above is very important. This exact thing happened to a friend who thought sure the Trans was toast. I took one minute to straighten the shift lever ... problem went away! Trans was perfect!
When you fall ... lever gets pushed into case ... interfering with shifting.
Old 01-07-2012, 11:24 AM   #58721
motolab
motolab's Avatar
Oddometer: 2,584
Originally Posted by luckett View Post
What are the equations? With a estimation of sprung weight, we could plug in the min and max of the frequency range to derive the spring rate range one should be considering.
Wheel rate in kg/mm=Wf/248.5 where W= laden sprung weight in kg and f= desired natural frequency in Hz. Spring rate in kg/mm=(0.5Cos)(wheel rate) where is the rake angle in degrees.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-07-2012, 11:31 AM   #58722
Rusty Rocket
Life behind "Bars"
Oddometer: 9,150
Regards,
Derek
That hurts. What is a # that would be a value for desired rate? ( what are we shootin' for?)
2009 DR650
Old 01-07-2012, 11:46 AM   #58723
motolab
motolab's Avatar
Oddometer: 2,584
That hurts.
It's not really that hard.
As mentioned previously (see http://www.advrider.com/forums/showp...ostcount=58842), it's known that a resonant frequency in the range of 1-2.5 Hz is optimal. Available travel and individual preference plays into determining the exact number (less available travel requires a higher frequency).
Regards,
Derek
Old 01-07-2012, 01:57 PM   #58724
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Bent shifter or foot brake
Oh yes, this does happen, especially way out in the woods. My tool kit includes a 10" adjustable wrench to gently bend those levers back to original shape. Works for me.
Dave
smilin jack is offline   Reply With Quote
Old 01-07-2012, 07:23 PM   #58725
BKLYNBullit
Oddometer: 11
valve train noise
Hey fellas,
Just did the first service valve adjustment on my new (2011) DR. The exhausts needed only minor tweaking but both intakes were so tight they needed two to three complete turns each before I could slip the gauge in. It's a wonder to me that the engine could function in that state.
Well, I got it to spec and the And the valve clatter is now very pronounced. This is something I've come to associate with a healthy running pushrod single (my RE Bullet in particular), but is it normal for the DR's?
Thanks in advance for any input.
Chuck.
BKLYNBullit is offline   Reply With Quote
Times are GMT -7.   It's 01:50 PM.
