01-08-2012, 02:17 PM
#58861 | |
Oddometer: 11
Oh, and I'm a stickler for that basic stuff. Chuck. |
01-08-2012, 03:13 PM
#58862 |
Oddometer: 339
New to Me 07 Suzuki DR650
DR650 with old Givi I had laying around. Ready to get plates and insurance Monday. You will be seeing me around this thread more often. Thanks for convincing me I needed one, like I needed another motorcycle. Thanks ALOT!
01-08-2012, 03:30 PM
#58863 | |
Oddometer: 2
Try these: http://www.batinc.net/thermos.htm |
01-08-2012, 03:55 PM
#58864 | |
Oddometer: 618
Paper or plastic manual?
I just find it much easier to work my way through an unfamiliar job when i can flip through the pages, make notes, and so on. I need all the help I can get...
Attitude ~ The difference between Ordeal and Adventure James |
01-08-2012, 05:18 PM
#58865 |
Oddometer: 61
Maybe buying 2000 DR650SE - ok deal or what?
So I found a local guy who is selling a 2000 DR650SE, basically stock with aftermarket slip-on. He says it is in great condition, and runs well. Forget what he said was mileage, though i think it was around 10,000. Asking price is $2600.
This is the best deal I have found on a DR650, though most have been much newer, and over $4000. I know very little about the bike, and this would be my first dual sport. I looked at some new ones at the local dealer, but really don't want to spend that much and dislike buying new anyway. So my question is, is this a decent price for the age of the bike? I am going to go look at it tomorrow after work. Short notice I know, but any thoughts on price, or what problem areas I should look at, are very much appreciated. Thanks in advance. Andrew |
01-08-2012, 05:25 PM
#58866 | ||
Stuck @ Home! >=^(
Oddometer: 1,172
Manic Cycles=My Facebook Page |
01-08-2012, 05:59 PM
#58867 | |
on the road o'dreams
Oddometer: 5,510
I don't know how much experience you have setting valve lash .... but experience and "feel" can help. The DR650 valve gear is fairly quiet, as are most "modern" Japanese top ends ... even singles. It will make a bit of noise ... no way to quantify that here ... but quieter than an Enfield I would think. EDIT: Remember ... Suzuki calls for a RANGE on both intake and exhaust. Intake: .08mm to .013mm Exhaust: .017mm to .022mm Since the DR valve gear is so stable ... I prefer to set lash on the "snug" side of the given range. This is up for debate ... but it's how Suzuki set them at the factory, where many bikes come set at minimum spec. Clearance is Clearance!! ![]() My settings are: EDIT Intake: .010mm Exhaust: .019mm I like to feel quite a bit of "Drag" on the feeler gauge as I slide it under in the gap. The next size up should NOT go in. Don't strip out the nuts when you tighten them down. Good luck, sounds like you're close to being an expert at this. Adv Grifter screwed with this post 01-09-2012 at 09:28 AM |
01-08-2012, 06:12 PM
#58868 |
I can pass this guy.....
Oddometer: 2,789
Awesome, thanks much.
2012 Triumph Bonneville 2006 Suzuki Vstrom 650 ![]() and 19 Others... Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311 |
01-08-2012, 06:30 PM
#58869 | |
Oddometer: 11
My manual has it at: Intake: .003 - .005 Exhaust: .007 - .009 That's in inches. So I did .004 and .008 respectively. In each case I made sure that the next size up would no go. Until I have more experience with what this bike likes, that's the best I can do. With the Bullet, it's all by feel. No gauges involved. Since it's pushrods, you set for free spin and no up and down play. As the valvetrain warms the clearances open up and you get that characteristic tappet sound beloved by Bulleteers the world over. Chuck
'06 RE Bullet 65 w/ "ACE FIREBALL" 535 performance kit. ("Beefy") '11 Suzuki DR650 ("Slim") |
01-08-2012, 07:30 PM
#58870 | |
Oddometer: 11
01-08-2012, 07:39 PM
#58871 |
Toadthumpin
Oddometer: 1,591
Rotopax mount
After doing a little research trying to find a Rotopax mounting options, I came across this and really like the way this has been mounted. Has anyone else done this? and/or Had any problems with this set-up? (passenger peg removed and rotopax mounted in its place)
01-08-2012, 07:55 PM
#58872 |
Oddometer: 2,612
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. ER70S-2 screwed with this post 01-09-2012 at 01:36 PM |
01-08-2012, 08:14 PM
#58873 |
Oddometer: 233
Dr650 #2???
2006 DR650 Oregon Tag-O-Rama ![]() http://www.advrider.com/forums/showt...=752387&page=3 |
01-08-2012, 08:22 PM
#58874 | |
Buell me
Oddometer: 2,024
![]() A four stroke requires two complete revolutions 360' x 2 = 720' to fully complete a firing cycle. That's why the tdc mark will appear twice, with the piston coming up on the compression stroke, indicating the correct of the two revolutions, while approaching the tdc mark. Remembering that the DR's head, tends to accumulate a rat's nest of debris around the two spark plugs, I clean this area "Fully Completely" like the Tragically Hip , and remove one plug so I can verify the escaping pressure, indicating the piston is coming up on the compression stroke, making it easier than watching the sequence, of the intake and exhaust rockers cycling. Upon arriving at the correct tdc, I expect to be able to easily "wiggle" both intake and exhaust rockers. I also appreciate the ease of rotating and postitioning the motor, with one of the plugs out, without working against compression forces. Despite the 96+ DR650 being known as holding clearances extremely well over extended periods, what with good materials and relatively small and lightweight valve train dimensions, I agree with your setting the gap to middle range ! When finished, I rotate the motor several times, find the correct tdc mark and double check the clearances, one last time... 996DL 996DL screwed with this post 01-09-2012 at 10:18 AM |
01-08-2012, 08:28 PM
#58875 | |
Oddometer: 233
![]() I'm a bit cheap when it come to extending my range, and saw this 3 gallon fuel tank in cabelas for about $30. Seems to me like it would work out great, strap it to a rack on the back of your bike. Just my thought... Link to it's webpage: http://www.moellermarine.com/afterma...topside_tanks/
