Old 02-12-2012, 10:02 AM   #59926
procycle
procycle's Avatar
Oddometer: 2,251
Originally Posted by epix1718 View Post
While in the middle of doing my RMZ250 Fork Swap (2007 RMZ) I'm about ready to unlace my SUN Supermoto Wheel that is currently laced to a stock DR650 Hub, and hopefully exchange the hub for a RMZ Hub, but any guesses to whether the spoke angles would be the same?
If not, what are my options?
The hole angles in the rim will be fine. The RMZ spokes will be too long. The threads will probably bottom out in the nipple before the spokes are fully tensioned. The bend in the RMZ spokes is different but maybe not enough to be a problem. The surest option would be to have a set of spokes made.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-12-2012, 10:08 AM   #59927
DIRT MAN
Tracker
DIRT MAN's Avatar
Oddometer: 75
Dr650
The rear wheel is 18"
011 1200 gs
013 KTM250FXCW
[COLOR=red]013 husky tr650
DIRT MAN is offline   Reply With Quote
Old 02-12-2012, 10:21 AM   #59928
JayHawk
Grandpa to 3
JayHawk's Avatar
Oddometer: 132
Clutch questions
While on a recent trip I had to take my '07 to a shop for what turned out to be a loose primary nut. The mechanic suggested heavy clutch springs which I allowed him to install.
Since then my clutch is quite grabby when engaging, especially when cold. I can adjust some of that out by adjusting the cable but then the clutch doesn't seem to disengage all the way.
I never had clutch issues before the work was done but with nearly 19,000 miles I guess anything is possible. Before I open her up again I'd like to have replacement parts on hand, so any suggestions on brands: stock Suzuki, DP or others? Anything else I should look for that might be causing my problem? The NSU bolts have already been locktited BTW.
Thanks, 'Hawk
'07 DR 650
JayHawk is offline   Reply With Quote
Old 02-12-2012, 10:38 AM   #59929
doug s.
Oddometer: 1,313
this was done on my bike w/zero issues. spokes from the sm wheel which were on the dr hub worked fine w/the rm hub.
ymmv,
doug s.
doug s. is offline   Reply With Quote
Old 02-12-2012, 10:43 AM   #59930
doug s.
Oddometer: 1,313
Thanks, 'Hawk
i have only one recommendation - take it back to the mechanic and tell him you want it fixed, on his nickel. after all, his nickel is the one you gave him to fix your bike. i would suspect that installing standard clutch springs will make everything all better.
if the above is not conwenient, (you mentioned being on a trip), simply replace the springs w/stock-rated springs. not sure if one brand is better than any other. i generally try to go for most reasonable price, but do research to ensure cheap doesn't mean bad.
doug s.
Old 02-12-2012, 11:15 AM   #59931
discoganya
discoganya's Avatar
Oddometer: 188
[QUOTE=ilragazzo;17966619]Yeah I saw him today... nice guy too, bad he thinks my jeep is not worth his DR. I might sell my jeep and ask him again with cash.... but I hate yellow.
Originally Posted by DIRT MAN View Post
[SIZE=2]This is my winter project, I have put Honda CRF 450 forks and Gary Emig of "Emig Racing" made the triple clamps and steering stabilizer. The bike has a Honda front wheel and a RMZ 450 rear wheel. Gary made the spacers for the rear wheel to work. Installed TKC 80 tires front and rear.
Nice well thought out.
I am looking into that one.
As for getting a loan. If I can avoid it I will. But after looking at the yellow one earlier today I may just buy a new one.
KAMANDO thanks for the info, usefull knowledge here.
ilragazzo -- You have a PM
2005 DR650, 2002 SV650, 2003 ZZR1200
discoganya is offline   Reply With Quote
Old 02-12-2012, 11:22 AM   #59932
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 2,995
Originally Posted by Weldman View Post
Looks much more serious i.e. badass, less "cartoony" than some other colors.
Couldnt help but imagine how great it would look with a black supermoto front fender
By God, Woodrow; it's been one hell of a party.
dogjaw is offline   Reply With Quote
Old 02-12-2012, 11:27 AM   #59933
Weldman
Weldman's Avatar
Oddometer: 1,287
Oh yeah ...
sweet!
Nawfick, Virginny
Weldman is offline   Reply With Quote
Old 02-12-2012, 12:04 PM   #59934
procycle
procycle's Avatar
Oddometer: 2,251
Huh?
Old 02-12-2012, 12:09 PM   #59935
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,989
Is this a question?
Its a 17".
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 02-12-2012, 12:20 PM   #59936
Garak
Cardassian Spy
Garak's Avatar
Oddometer: 266
Originally Posted by goodcat8 View Post
Is this a question?
Its a 17".
I think he's talking about his own rear wheel on the bike pictured above. Bergdonk asked about it being a 19". Could be wrong though.
Across the country on the kindness of strangers and the strangeness of friends (and a DR650).
My LinkedIn Profile
Garak is offline   Reply With Quote
Old 02-12-2012, 02:12 PM   #59937
BergDonk
BergDonk's Avatar
Oddometer: 3,367
I'm will shortly be lacing an ex RMZ Excel rim to my DR650 hub because the DID did its usual cracking thing at the join. Because of the bigger holes in the rim, I'm using HD spokes too, and will probably have to open out the holes in the hub a bit to to suit. Should get around to it in the next week or so. Spokes are the same length.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 02-12-2012, 03:10 PM   #59938
Nibis
Where to next?
Nibis's Avatar
Oddometer: 844
Originally Posted by ram1000 View Post
I agree the gray does nothing for the DR.
Not sure I like it either makes it look like faded black. I tend to like the Blue, or Yellow , not to hip on the white either.
Nibis is offline   Reply With Quote
Old 02-12-2012, 03:23 PM   #59939
ride4321
ride4321's Avatar
Oddometer: 1,863
Originally Posted by dogjaw View Post
Helped the local Suzuki dealer put together a new DR today,.. Looks really good in gray.
I like the grey. Looks a whole lot less cartoony than my yellow DR. But Spongebob looks good my my yellow one and he'd stick out too much on the gray so I'll stick with the funny cartoony yellow I guess. If I ever buy a new one I'd consider the gray. These bikes ain't meant to be styling ya know.
Don't you know there ain't no devil, it's just God when he's drunk.
Tom Waits
ride4321 is offline   Reply With Quote
Old 02-12-2012, 03:48 PM   #59940
poppawheelie
poppawheelie's Avatar
Oddometer: 559
Laugh
Yellow is the traditional Suzuki racing color from way back. Think Roger DeCoster. My Suzuki's back then were all yellow. Wish my white DR was yellow.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie is offline   Reply With Quote
Times are GMT -7.   It's 10:20 PM.
