02-10-2012, 11:31 AM
#59971 |
Armature speller
Oddometer: 6,781
02-10-2012, 01:02 PM
#59972 |
I can pass this guy.....
Oddometer: 2,750
The KLR had a stock rim with a130 TKC. My DR has the wide supermoto rear rim. So that in itself will lend a difference. I wouldn't recommend (or even know if it's possible) to fit a 150 on our stock rear rim. I love the way it handles with its current set up.
2012 Triumph Bonneville 2006 Suzuki Vstrom ![]() Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311 |
02-10-2012, 01:35 PM
#59973 |
Oddometer: 1,607
It would definitely be a bad idea to cram the 150 tire onto the stock rim.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
02-10-2012, 01:42 PM
#59974 |
Rider
Oddometer: 391
Sage advice from Procycle...indeed a narrower 130 TKC80 should weigh less & less rotational mass=quicker acceleration. I also tried a TKC80 140/17 rear (on a 2.5" Behr tubeless rim) & didn't like it...almost a totally different tire...the 140 had a shorter looking profile, much bigger, wider tread blocks, & a much more rounded profile so that the outer tread blocks wouldn't fully contact the pavement at full lean. I went back to a 130/17 with a flatter profile & smaller tread blocks & am much happier with it.
ADVBedouin screwed with this post 02-10-2012 at 01:53 PM |
02-10-2012, 02:07 PM
#59975 | |
Oddometer: 642
Quick question, I currently use regular motorcycle 10W-40 oil and change it about every 2,000 miles. How long could/should I go between oil changes if I switched over to synthetic?
Thanks Quote:
02-10-2012, 02:13 PM
#59976 | |
Oddometer: 756
3000 is a safe interval, oil is not that expensive.... yet...
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
02-10-2012, 02:27 PM
#59977 | |
Oddometer: 606
Oil fil cap
Thanks for the link. I will order a couple of them.
Attitude ~ The difference between Ordeal and Adventure James |
02-10-2012, 02:28 PM
#59978 | |
Southern Explorer
Oddometer: 1,233
02-10-2012, 03:13 PM
#59979 |
Oddometer: 102
SW-MOTECH bash plate
Here's one Jeff can proably address: I was shopping for an SW-MOTECH bash plate for my 2008 and found prices from $124.99 (ProCycle) to $249.99 (Twisted Throttle). They look to be the same piece? Any idea as to why the huge variance in cost?
There is never enough time or money to do it right the first time. 2008 DR650, 2006 V-Strom 1000 |
02-10-2012, 03:21 PM
#59980 |
Oddometer: 177
02-10-2012, 03:26 PM
#59981 | |
Oddometer: 1,607
02-10-2012, 03:31 PM
#59982 | |
Knuckle dragger
Oddometer: 1,306
Twisted Throttle is used to the BMW crowd...those guys will pay any $$ if you tell them it is the best! I think they have about a 150% mark up on everything. A BMW coffee mug from them is probably $50!
02-10-2012, 03:44 PM
#59983 | |
UberNoob
Oddometer: 69
My Smugmug, it's how I roll. |
02-10-2012, 03:54 PM
#59984 | |
almost gnarly
Oddometer: 1,473
I bought my Barkbusters from Twisted throttle and they weren't any more expensive than anybody else. Of course nobody else sells Barbusters.
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
02-10-2012, 04:02 PM
#59985 | |
WannabenarlyADV'rrrr
Oddometer: 327
Or do people go around jacking oil from your bike?? If so that is waay crazy!! What are we in roadwarrior time's? Oh thanks ADVB, PRO and SAGE for the advice on the tires! Sounded like you were using 150's on a stock rim. I will stick to getting the 130's. bd
Burn out dont fade away!! |
