03-12-2012, 08:27 PM
#61336 | |
bam-a-lam
Oddometer: 1,839
The hesitaiton is only when I whack the throtte to WOT from around 1/4 to full. Otherwise no hesitation and in normal riding I probably won't be doing to many off idle to full out WOT accelerations. Was getting about 45 mpg and gonna see what I get now for comparison then if significantly different will make jetting/needle changes. Btw, at sea level as well.
'12 H-D Road Glide Custom '09 Suzuki DR650 '09 H-D XR1200 blk-betty screwed with this post 03-12-2012 at 08:33 PM |
#61337 | |
lifelong reject fixer
Oddometer: 1,217
The pictures I saw before Procycle pulled them from their website showed dual petcocks. Not having to lay the bike over to get the last half-gallon of fuel when needed might be worthwhile. The smaller than promised capacity is a disappointment and I'm still mulling whether it is $100 worth of worthwhile for the dual petcocks, but I've not yet ruled out the tank.
'08 DR650SE; '91 GL1500SE; USMC 1972-76; NRA Life Member ------------ "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius |
03-12-2012, 08:31 PM
#61338 | |
Southern Explorer
Oddometer: 1,233
Sent from my GT-S5690L using Tapatalk |
03-12-2012, 08:37 PM
#61339 | |
Southern Explorer
Oddometer: 1,233
Disregard the needle info, 4th or two up from the bottom is right. Its just a vac carb. Ride it for a while, the 150 main jet is fine. You will always have the BST rubber band wind up. Sent from my GT-S5690L using Tapatalk sagedrifter screwed with this post 03-12-2012 at 08:43 PM |
03-12-2012, 08:38 PM
#61340 |
Oddometer: 2,564
03-12-2012, 08:44 PM
#61341 | |
Oddometer: 195
03-12-2012, 08:46 PM
#61342 | |
on the road o'dreams
Oddometer: 5,390
Should take just a few minutes. You may have to remove choke & throttle cables ... not too hard. Use caution with rubber diaphram and replacing needle into jet needle. Do the same to access float bowl. Rotate other way ... pull bowl, Main jet, Pilot ... all there. Handle float mech. with care. |
03-12-2012, 08:50 PM
#61343 | |
Southern Explorer
Oddometer: 1,233
03-12-2012, 08:57 PM
#61344 | |
Oddometer: 756
I don't know. Here's what I see when I look at this pic: (disclaimer: I might be a complete idiot, this is the internet you know. To get that swing arm into position where the chain could grind it at that angle, the rear wheel would need to be swung up all the way to the end of it's travel. Maybe that bike had a heavy rider or was overloaded and the rear shock kept bottoming out? Funny that the chain shows no signs of wear on the inner edge. My bike is oversprung. Its springs, front and rear, are designed to carry me, 30 pounds of add-ons like center stand, panniers and racks, skid plate, etc plus 40 pounds of gear, 2 spare tires, 2+ extra gallons of gas in the IMS tank and 2 more gallons strapped to the bike, and a couple gallons of water, and a bunch of tools. In other words, even though I only weigh 155 pounds, the bike is set up for a 250 pound load (Jesse Keintech recommended the suspension changes when I was setting up the bike to go to Kazakhstan). Sagedrifter- I know you have a bunch of stuff on your bike, and a Safari tank- maybe all the extra weight allows the chain to bite into your swingarm protector? .............shu |
03-12-2012, 08:58 PM
#61345 |
Repeat Offender
Oddometer: 61
I made the same assumption with my fmf q4 and stock header but it still needs choke to start and the throttle smoothness and power bump was more obvious than i would have guessed. I ain't touching it now.
03-12-2012, 09:01 PM
#61346 | |
bam-a-lam
Oddometer: 1,839
'12 H-D Road Glide Custom '09 Suzuki DR650 '09 H-D XR1200 |
03-12-2012, 09:04 PM
#61347 | |
bam-a-lam
Oddometer: 1,839
Think I'l ride it a little, check fuel mileage and make decison later.
03-12-2012, 09:15 PM
#61348 | |
Southern Explorer
Oddometer: 1,233
I run the .50/8.3 springs and if I set my chain with any more slack it would be hanging from the center stand. I've read about a few guys wearing out the chain buffer slide thingy, so its not all that rare. There was a recent thread about it over on DRRiders. I think my guard wore out too quick, not sure what I could do to stop that from occurring. A better suspension perhaps would help. I'm just running springs. |
03-12-2012, 09:24 PM
#61349 | |
Oddometer: 2,564
03-12-2012, 09:29 PM
#61350 |
I can pass this guy.....
Oddometer: 2,748
Tech Question.
My bike keeps stalling out. As if the RPMs drop to low and she cuts out. I know she's supposed to idle at 1500 (as stated on the engine) my vapor shows her idling around 1200-1100 then she stalls. It's appearing that my idle knob on my TM40 carb isn't doing anything. It used too! ![]() I twist left and right looking for any indication that it's adjusting the idle and get nothing. I'm hoping that's the case and I just need to somehow fix that, turn up the idle abit and be done with it, before I go through and start checking clogs in the fuel system. Any input would be appreciated.
2012 Triumph Bonneville 2006 Suzuki Vstrom ![]() Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311 |
