Old 03-20-2012, 07:24 PM   #61666
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 7,252
Originally Posted by Toxic Mark View Post
I recently mounted Kenda Big Blocks on my DR (OEM wheel set) and immediately noticed that I have lost highway speed stability (wobbles) anywhere above 65 mph indicated. Is this what I should have expected? When I ride with my brother who lives at the foot of the San Bernadino mountains I'm happy to have the knobs, but when I am back up in the Bay Area where I have to slab it to get to dirt I hate them.
I've toyed with the idea of a second wheel set with something along the lines of GP-1s. I've tried troubleshooting the wobble with no success. And I don't want to be swapping tires everytime I head south.
Ideas? Advice? How stable is your DR at highway speeds? And what tires are you on that provide that stability? Would a 19" front provide more stability over a 21" given the same tire?
-Mark
Big knobs, heavy tires, and soft rubber on a light moto sound like a recipe for squirm and vibes on pavement.
I run 70-80MPH with a passenger and luggage regularly, with short bursts sometimes going faster. The DR's seen 101MPH (GPS) in the dirt. I use 25-30PSI onroad, and 15-25PSI offroad, depending on load and surface. I ride in about the middle of the seat and forward. I rarely slide back further unless offroad or eating miles. The DR feels fine onroad at any speed.
The PO put in heavier oil and springs for a 200lb+ rider. The bike is in the high position. I put on a sleek YZ450 front fender for aesthetics, but the stocker caused no wind issues for me either. I have FAR KTM mirrors, Trackside handguards, and no windscreen. I mention these things because many people claim wind issues on relatively-stock DRs at much lower speeds than I sometimes travel.
I have a stock TW tire up front, and ran the stock TW in the rear until replacing it with a Kenda K761 at about 12K miles. I've got over 15K miles now, and the K761 is starting to show wear in the center. The almost wornout front TW is about to get replaced with a cheap Sandsnake knobby as an offroad experiment.
I don't expect the knobby to run well or long on pavement, but I have a streetbike too.
Kommando screwed with this post 03-20-2012 at 07:32 PM
Kommando is online now   Reply With Quote
Old 03-20-2012, 07:29 PM   #61667
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by epix1718 View Post
Grrr, for the life of me I'm have some issues hooking up the throttle cables to the stock carb. I put both cables on (push cable on frontmost, pull cable on rearmost) and both cables have tension, but as I rotate the throttle back to WOT and release it just sticks, not returning to rest.
I can rotate the throttle by hand but whatever position I leave it at it won't return to rest. I attached just the pull cable and the throttle fully at rest and start the bike it starts up like it is at WOT. This is very frustrating! First time I've ever done something like this so what am I doing wrong?
Proceed carefully. You don't want to hurt yourself. Maybe consult a pro for this.
Chances are either your routing along the frame spine is wrong or your bark buster or hand guard is pushed into the grip and preventing it from returning.
Hard to explain how the two cables should be routed. The hand guard is easily fixed ... just tap it outward a bit until throttle is free. When you fall ... in will stick again.
Adv Grifter screwed with this post 03-20-2012 at 07:37 PM
Old 03-20-2012, 07:33 PM   #61668
maynard911
Oddometer: 142
-Mark
Real dirt tires suck on the street and real street tires suck on the dirt. Life and dual sport tires are a compromise. A 19" front with the same tire will be somewhat less stable than a 21" due to the decrease in rake and trail involved in lowering the front. If you lower the rear also you get back to where you started. I'm running the 19"/17' combo, so this is not conjecture. Those Kenda's won't last very long, you could just grin and bear it, and then get something like Shinko 700's next time (maybe Metfo Explorers if you are feeling flush). They are not as good in the loose, but worlds better on pavement, closer to the 'ideal' dual sport 50/50, or go with the second wheel set. If you go with the latter PM me I have what you want.
Maynard " Youth is fleeting, immaturity is forever"
maynard911 is offline   Reply With Quote
Old 03-20-2012, 07:44 PM   #61669
maynard911
Oddometer: 142
Thanks for the info.
Carb is fully assemebled and on the bike, attached firmly to the motor and air box.
When not attached to the carb the cables slide in/out with ease. Just to make sure I have it correct, when I pull the throttle back the cable should extend out, while the push should retract? That's my understanding at the moment. When disconnected from the carb, should the throttle snap right back to "rest" when I let go of it while rotating?.. because mine just stays put.
The carb itself the throttle rotation thingy-ma-bob rotates freely with no cables attached, lots of spring tension when fully rotated and snaps right back when let off. I'll keep playing with it til I figure it out.
You have the cables hooked up backassward, more throttle is pull, less is push.
Old 03-20-2012, 08:10 PM   #61670
Toxic Mark
Toxic Mark's Avatar
Oddometer: 36
That makes sense about the stability issue. How are you liking your 19"/17" setup? Did you lower your rear as you suggest? Are you riding much offroad with them? What tires are you running now and do you like them? I'm curious how many DR riders use 2 wheel sets.
Reading above I will try dropping the psi a bit. I've also heard that once the tires have broken in some that they become slightly more manageable.
Mark
Toxic Mark is offline   Reply With Quote
Old 03-20-2012, 08:42 PM   #61671
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,425
Shinko 700's ??
Hey sagedrifter ....
How much noise do the 700's put out on the road ?? ...
Thanks ...
Originally Posted by sagedrifter View Post
I really like the Shinko 700 as an all rounder, nice and stabil on the pavement and good on most surfaces. The 244 Shinko is cheap and better off road but, short lived on pavement.
Tires are always a compromise, I like to run a mild knob on the front and a mild DS tire like a 700, Anakee, 705, Kenda 761 etc. on the rear. I've been running the 700 Shinko on the front lately and its actually decent on gravel roads and dirt trails with the mild 705 on the rear.
If your an aggressive DS rider that does ride slab at speed, try a MT 21 / Shinko 700 combo or maybe a Mefo on the rear.
Honda
GsVs is offline   Reply With Quote
Old 03-20-2012, 08:44 PM   #61672
JagLite
JagLite's Avatar
Oddometer: 1,116
Question Stuck throttle
You didn't say why the cables were off the carb and that might be a clue.
My suggestion is to remove the seat and gas tank so you can follow the cables from throttle to carb.
I managed to pinch one cable on another bike and had to remove them to find the problem.
However, if the throttle operates the cables smoothly when not connected to the carb, that is not the problem.
OK, throttle cable running free now?
The problem is the carb.
Did you take it apart?
Does the cable plate on the carb rotate correctly and snap shut when you release it?
Start the bike without the cables attached.
Does the engine idle properly and rev up and down when you operate the cable plate?
The answers to these questions will show where the problem is.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 03-20-2012, 09:08 PM   #61673
epix1718
epix1718's Avatar
Oddometer: 713
Carb was off due to me removing the pumper carb (sold the TM40, returning this bike back to stock.. I have 2 DR's so no need for 2 farkled bikes), putting the stock carb back on.
The cable plate rotates freely, snaps shut. Bike is in another garage at the moment so when I get off work tomorrow I'll try these suggestions I'm guessing I just had the cables on backwards.
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Old 03-20-2012, 09:18 PM   #61674
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,413
Thanks ...
Not noisy to me. My last TKC-80 front was much louder. I don't get the low speed vibration with the 700's, they don't cup as bad for some reason. My last two non-700 fronts cupped and hummed noticibly at 4K, one Anakee and the TKC-80. The current 700 has very light cupping at 4K, it still looks new.
Its hard to say exactly, but they are no louder than a 705 as far as I can remember. I can hear them when I'm not wearing ear plugs, but I can hear the mild 705's too.
sagedrifter is offline   Reply With Quote
Old 03-20-2012, 09:54 PM   #61675
BadDogMax
Oddometer: 159
I know what you are talking about, a very home-made looking battery.
But very clean looking, not a negative about how it looks.
Are you talking about the Baja Designs battery?
It's made for running lights on a converted dual sport with low electrical needs. I made a similar NiCad battery for my old XL600r (no electric start) and it eventually fried from overcharging.
2007 Suzuki DR650
BadDogMax is offline   Reply With Quote
Old 03-21-2012, 04:00 AM   #61676
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 2,989
Mark
Once my TKC's "broke in" they've been like glue to any surface I run them on. As mentioned a little earlier my only complaint is wobbles above 70 and rear wear from pavement. I'm a big fan of the 19Fx17R combo. Had it on both my DR's.
TKC's 19x17
DISTANZIA'S 19X17
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 03-21-2012, 04:17 AM   #61677
jon_l
jon_l's Avatar
Oddometer: 3,033
Originally Posted by TeeVee View Post
So, need some advice from the collective.
several months ago i made the mistake of putting my gaerne sg-12's away before they were completely dry. they of course, started growing mold or mildew, not sure which but they stunk. so, i washed 'em in a strong lysol bath and left them under a fan in the sun for two days. didn't work. treated them with heavy lysol sprays for days on end while they baked in the tropical sun. still no joy.
i'm thinking my only option is bleach, which will of course bleach out the liners. and while i firmly believe that form follows function, i'd rather seek a non-damaging alternative before i ruin a $500 pair of boots.
any ideas?
tia
This vendor sells Gaerne, and seems knowledgeable. Ask him: http://www.advrider.com/forums/showthread.php?t=669864
'09 Honda CBF1000
jon_l is offline   Reply With Quote
Old 03-21-2012, 04:58 AM   #61678
jon_l
jon_l's Avatar
Oddometer: 3,033
Big Blocks are fairly soft and aggressive, the will feel squirmy at speed when aired up. My first thought is too much air pressure.
I can run aggressive tires at 28 psi up to 70 mph or so with a touring load. I really notice wiggle above 75. The rear will wiggle around even with a mild TKC with 30 psi, I drop the pressure to 28 and it is much better, at 25 psi it goes away.
I have not tried GP-1's, I usually go with a cheaper option. If I was going to spend the money, I would try the Mefo option.
I mounted an MT-21 Sunday, and have a Mefo Explorer rear. Haven't ridden yet except around the block. Will report back in the future.
'09 Honda CBF1000
Old 03-21-2012, 05:58 AM   #61679
Thanas
Oddometer: 75
@ SBG
My fornt 2,50 x 19 rim is from a european Suzuki XF 650 Freewind. It uses the same hub as the DR 650. And therefore was a direct bolt in.
My rear which should be in the mail today, will be a Warp9 4,25 x 17 rim, with buchanon spokes.
I hope to be able to complete my bike this evening and be on 2 wheels again tomorrow. Really anxious to see how the TKC80's will work.
Best regards,
Thanas
Suzuki DR 650 SE 2006
Thanas is offline   Reply With Quote
Old 03-21-2012, 06:33 AM   #61680
996DL
Buell me
Oddometer: 2,184
Thumb Don't ignore or dispute this advice !
Originally Posted by joefromsf View Post
Yikes. No. That's the incorrect number from the service manual. It's OK for upper bolt, but not lower.
Post from Rick at Cogent: http://www.advrider.com/forums/showp...&postcount=239
This is invaluable advice, don't argue with it and let's include / highlight it, in Crustys DR thread index, someone...
996DL
996DL is offline   Reply With Quote
Times are GMT -7.   It's 04:53 PM.
