03-20-2012, 04:44 PM
#61786 | |||
Oddometer: 2,556
2004 DR650: 46,358 miles of ![]() ER70S-2 screwed with this post 03-20-2012 at 04:52 PM Reason: Duelling with Mongle |
03-20-2012, 04:47 PM
#61787 | |
Carbon-based bipedal
Oddometer: 2,028
03-20-2012, 05:59 PM
#61788 |
Mindless Savage
Oddometer: 868
Ah. My bad then. I didn't have my DR specs close at hand so wasn't sure what the OEM recommended pressures were....
2008 DR 650 We can handle it....We're Canadian |
03-20-2012, 06:05 PM
#61789 | |
kezza
Oddometer: 731
try this
Give it a go anyway.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250 Website: http://www.territoryon2wheels.com "May the Road Never Rise to Defeat you..." |
03-20-2012, 06:14 PM
#61790 | |
kezza
Oddometer: 731
Simply replace if they get knotchy.
03-20-2012, 06:24 PM
#61791 | |
on the road o'dreams
Oddometer: 5,382
Safedrifter has got it right, IMO. I add a little more air as I'm 200 lbs. and carry luggage. So on highway, maybe 24/28 or so. I've found I get the most even wear and most miles running below 30 PSI, even with a full load. YMMV. |
#61792 | |
Grumpy Young Man
Oddometer: 3,754
I run 70-80MPH with a passenger and luggage regularly, with short bursts sometimes going faster. The DR's seen 101MPH (GPS) in the dirt. I use 25-30PSI onroad, and 15-25PSI offroad, depending on load and surface. I ride in about the middle of the seat and forward. I rarely slide back further unless offroad or eating miles. The DR feels fine onroad at any speed. The PO put in heavier oil and springs for a 200lb+ rider. The bike is in the high position. I put on a sleek YZ450 front fender for aesthetics, but the stocker caused no wind issues for me either. I have FAR KTM mirrors, Trackside handguards, and no windscreen. I mention these things because many people claim wind issues on relatively-stock DRs at much lower speeds than I sometimes travel. I have a stock TW tire up front, and ran the stock TW in the rear until replacing it with a Kenda K761 at about 12K miles. I've got over 15K miles now, and the K761 is starting to show wear in the center. The almost wornout front TW is about to get replaced with a cheap Sandsnake knobby as an offroad experiment. I don't expect the knobby to run well or long on pavement, but I have a streetbike too. Kommando screwed with this post 03-20-2012 at 06:32 PM |
03-20-2012, 06:29 PM
#61793 | |
Oddometer: 5,382
Chances are either your routing along the frame spine is wrong or your bark buster or hand guard is pushed into the grip and preventing it from returning. Hard to explain how the two cables should be routed. The hand guard is easily fixed ... just tap it outward a bit until throttle is free. When you fall ... in will stick again. Adv Grifter screwed with this post 03-20-2012 at 06:37 PM |
03-20-2012, 06:33 PM
#61794 | |
Oddometer: 137
Maynard " Youth is fleeting, immaturity is forever" |
03-20-2012, 06:44 PM
#61795 | |
Oddometer: 137
03-20-2012, 07:10 PM
#61796 | |
Oddometer: 22
Reading above I will try dropping the psi a bit. I've also heard that once the tires have broken in some that they become slightly more manageable. Mark |
03-20-2012, 07:42 PM
#61797 | |
Goin' Somewhere
Oddometer: 1,267
Shinko 700's ??
Hey sagedrifter ....
How much noise do the 700's put out on the road ?? ... Thanks ... Quote:
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - '09 DR650SE - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -- - '12 NC700X |
03-20-2012, 07:44 PM
#61798 | |
Oddometer: 598
My suggestion is to remove the seat and gas tank so you can follow the cables from throttle to carb. I managed to pinch one cable on another bike and had to remove them to find the problem. However, if the throttle operates the cables smoothly when not connected to the carb, that is not the problem. OK, throttle cable running free now? The problem is the carb. Did you take it apart? Does the cable plate on the carb rotate correctly and snap shut when you release it? Start the bike without the cables attached. Does the engine idle properly and rev up and down when you operate the cable plate? The answers to these questions will show where the problem is.
Attitude ~ The difference between Ordeal and Adventure James |
03-20-2012, 08:08 PM
#61799 | |
Oddometer: 533
The cable plate rotates freely, snaps shut. Bike is in another garage at the moment so when I get off work tomorrow I'll try these suggestions
97 Suzuki DR650 97 Ural Sportsman 2WD 98 Honda XR250R 83 Yamaha XT550 www.drriders.com |
03-20-2012, 08:18 PM
#61800 | |
Southern Explorer
Oddometer: 1,233
Its hard to say exactly, but they are no louder than a 705 as far as I can remember. I can hear them when I'm not wearing ear plugs, but I can hear the mild 705's too. |
