Old 04-08-2012, 11:43 AM   #62581
ER70S-2
ER70S-2's Avatar
Oddometer: 6,289
Originally Posted by shaddix View Post
Hey guys! I looked at my spark plugs today and they were black. So going by this guide it says to run it at full throttle and check to see if they're black or white or tan as a first step to determining jetting needs. Now considering that my plugs are already black, will that mean that if it's too lean at full throttle they won't be white? Do I need to clean the plugs first before I test for lean/rich mixture?
How old is your bike and how many miles? What's your gas mileage, has it gotten worse? If you've had the bike for a while the jetting may be fine. The two o-rings in the carb may be failing causing a rich mixture at all throttle settings. We spend most of our time on the needle circuit, so this would be the one start with. Since the USA bikes don't have an adjustable needle, you can't drop the needle one clip. This means that I'd check the needle for wear (smaller diameter would flow more gas) and check the needle jet for 'ovaling', another wear point on some bikes (larger hole, more fuel).
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-08-2012, 11:57 AM   #62582
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,419
Plugs should be a grey color, reminds me of graphite.
Sent from my GT-S5690L using Tapatalk
sagedrifter is offline   Reply With Quote
Old 04-08-2012, 12:18 PM   #62583
Potosi Joe
Oddometer: 305
A+ to Procycle jet kit.
I installed my PC jetting kit with air box mod and drilled slide, installed a WR450R stock muffler (custom fit) with insert removed a couple weeks ago. Rode it yesterday over back-roads, gravel and some highway. Runs great. Fuel mileage was 53.8 mpg.
Potosi Joe is offline   Reply With Quote
Old 04-08-2012, 12:33 PM   #62584
sandwash
sandwash's Avatar
Oddometer: 1,350
Tunning by spark plug color is alittle tougher these days,gas burns alot cleaner.Google it,alot different these days:arc(where,timming),) on eletrode,color (how many,heat range) on threads and the color on the base(inside,wide open) of the insolator.
97dr650
sandwash is online now   Reply With Quote
Old 04-08-2012, 12:38 PM   #62585
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
You are running too Rich. Forget about Full throttle and all that. Black plugs means you are WAY on the rich side and wasting lots of fuel. After you solve the puzzle ... treat your self to NEW PLUGS.
What is your current jetting? (untouched from new?)
What is current altitude?
What air box configuration do you have? (Stock, modified ... or ?)
What exhaust? Stock or other?
An older/high mileage bike could have worn O rings (in float bowl, in float needle) Or could be restriction in air box or non stock Jets, clogged jet, torn rubber diaphragm, fuel or air leak.
Many put in a bigger (richer) Pilot jet. This is wrong. For the stock carb in almost any tuning configuration, the stock Pilot Jet is retained.
A totally stock DR650 will run very very lean. Plugs will be nearly White no matter the throttle opening. This is how the bike was meant to run to pass EPA and such. A Dyno Jet needle/Jet kit will let the Carb be the best it can be and still get decent fuel economy.
I would remove the Carb. Replace the nasty Phillips screws holding float bowl on with Allen head screws. Work slowly and carefully. Choke and Throttle cables come off. All vent hose removed, put out of way. Take Pics so you know how it all goes back.
Old 04-08-2012, 12:53 PM   #62586
Aerocycle
Aerocycle's Avatar
Oddometer: 233
Originally Posted by jon_l View Post
My new boots are Gaerne Balance Oiled. I have wide feet and big calves. The boots were comfortable right out of the box.
Beautiful!!!
2006 DR650
Oregon Tag-O-Rama
http://www.advrider.com/forums/showt...=752387&page=3
Aerocycle is offline   Reply With Quote
Old 04-08-2012, 12:56 PM   #62587
Aerocycle
Aerocycle's Avatar
Oddometer: 233
Originally Posted by AST236 View Post
Michelin Anakee 2's on my '98.....Put a hundred miles on them today and like them a lot. Smooth, quiet and not bad on dirt roads.
I could be wrong here, but doesn't the axle shaft go through the other direction? Just something I noticed. Guess it wont make a difference if the spacers are placed correctly. But my Axle shaft is running through from the other direction. Maybe I screwed up....
2006 DR650
Oregon Tag-O-Rama
Old 04-08-2012, 12:59 PM   #62588
shaddix
Oddometer: 647
edit:r emoved bad photos
e
I may be wrong about them being black, so I took some photos!
The other plug is like grey on one side and black on the other..
The bike is an 09 with 11k miles. I get about 38mpg city, 46 highway ~70mph, moderate hills. I've only had the bike for three weeks. The previous owner rejetted it, I am not very familiar with carb construction and function even though i've read many articles. When I take it apart I'm sure the rest of your post will make sense to me!
They might be grey, but they looked black to me
doh........ I have more reading to do then :x
The current jetting is unknown to me. The previous owner told me the previous previous owner had rejetted it and cut the airbox(the whole top of the airbox under the seat is gone, k&n filter). And after this the first previous owner(guy I bought it from) told me he put the next biggest main jet in. So I really have no idea how it's setup currently, and no way to find out unless I'm lucky enough that the parts are labeled what they are.
I'm probably 500 feet over sea level, central alabama.
Stock exhaust
I will give a shot at taking the whole thing apart today and maybe I won't tear it up
shaddix screwed with this post 04-08-2012 at 02:40 PM
shaddix is offline   Reply With Quote
Old 04-08-2012, 01:52 PM   #62589
TonyTooTall
Oddometer: 20
DSC00083 by TonyTooTall, on Flickr
New to me, so much more fun that the street bike I use to have.
TonyTooTall screwed with this post 04-08-2012 at 07:27 PM
TonyTooTall is offline   Reply With Quote
Old 04-08-2012, 02:07 PM   #62590
ER70S-2
ER70S-2's Avatar
Oddometer: 6,289
shaddix:
Good pics, well lit, sharp focus, good macro.
But we want to see the porcelin coloring, please. Smaller would be good, for the guys still on dial-up. I think this is one of my original DR plugs, still lying on my desk.
2013 WR250R
Old 04-08-2012, 02:22 PM   #62591
jon_l
jon_l's Avatar
Oddometer: 3,147
You're right, the castle nut is on the right side.
CBF1000 & PCX150
jon_l is online now   Reply With Quote
Old 04-08-2012, 02:29 PM   #62592
AST236
AST236's Avatar
Oddometer: 2,035
I put it back like it was when I got it.
Everything slid in place w/ no issues so I'm not sure if it makes much difference or not since the axle is just riding fore/aft in the slot in the swingarm.
Smarter people than me please jump in and tell me if I need to turn it around to avoid damage or falling on my arse....
I usually run out of talent before I run out of horsepower.
I don't like sand.
AST236 is offline   Reply With Quote
Old 04-08-2012, 02:32 PM   #62593
Adv Grifter
Oddometer: 6,128
idle:
half throttle:
full throttle:
Stock exhaust
Those plugs aren't too bad at all Maybe a tad rich? but far from BLACK. You could go down ONE main jet size (leaner) ... or go UP on the needle clip position to lean out a bit. But you don't need much. You are fairly close, IMHO.
If your air box is stock (top not cut open) then you could open it up and leave jetting as is. Doing this will also lean things out a bit. This may put you spot on jetting wise and MPG may improve too. Lots of back and forth, give and take balancing air / fuel mix.
Have fun.
Old 04-08-2012, 02:42 PM   #62594
shaddix
Oddometer: 647
shaddix:
Oops. I didn't realize the porcelain was what we were looking for. I am probably in good shape then because they'r epretty damn white:
I was able to get the carb out.. I'm gonna take some pictures of it and post them and perhaps someone can tell me what's been done to it.....
Old 04-08-2012, 03:22 PM   #62595
shaddix
Oddometer: 647
slide is drilled, and it has the funky screws and someone already changed the phillips head screws out with the hex screws
edit.. I'm a moron it says right on the jet what size it is.... 145 main jet bbut don't know if it's DJ or that other one... pilot jet says 52 PI... does that make sense?
This last photo is showing a port that had no hose connected to it when I was removing it from the bike, however in the guide I was following, i think it shows there is a hose connected to it... I do not know what this is for or what hose I am missing
Times are GMT -7.   It's 05:34 PM.
