Old 04-08-2012, 11:59 AM   #62716
shaddix
Oddometer: 586
edit:r emoved bad photos
e
I may be wrong about them being black, so I took some photos!
The other plug is like grey on one side and black on the other..
Originally Posted by ER70S-2 View Post
How old is your bike and how many miles? What's your gas mileage, has it gotten worse? If you've had the bike for a while the jetting may be fine. The two o-rings in the carb may be failing causing a rich mixture at all throttle settings. We spend most of our time on the needle circuit, so this would be the one start with. Since the USA bikes don't have an adjustable needle, you can't drop the needle one clip. This means that I'd check the needle for wear (smaller diameter would flow more gas) and check the needle jet for 'ovaling', another wear point on some bikes (larger hole, more fuel).
The bike is an 09 with 11k miles. I get about 38mpg city, 46 highway ~70mph, moderate hills. I've only had the bike for three weeks. The previous owner rejetted it, I am not very familiar with carb construction and function even though i've read many articles. When I take it apart I'm sure the rest of your post will make sense to me!
Originally Posted by sagedrifter View Post
Plugs should be a grey color, reminds me of graphite.
Sent from my GT-S5690L using Tapatalk
They might be grey, but they looked black to me
Originally Posted by sandwash View Post
Tunning by spark plug color is alittle tougher these days,gas burns alot cleaner.Google it,alot different these days:arc(where,timming),) on eletrode,color (how many,heat range) on threads and the color on the base(inside,wide open) of the insolator.
doh........ I have more reading to do then :x
Originally Posted by Adv Grifter View Post
You are running too Rich. Forget about Full throttle and all that. Black plugs means you are WAY on the rich side and wasting lots of fuel. After you solve the puzzle ... treat your self to NEW PLUGS.
What is your current jetting? (untouched from new?)
What is current altitude?
What air box configuration do you have? (Stock, modified ... or ?)
What exhaust? Stock or other?
An older/high mileage bike could have worn O rings (in float bowl, in float needle) Or could be restriction in air box or non stock Jets, clogged jet, torn rubber diaphragm, fuel or air leak.
Many put in a bigger (richer) Pilot jet. This is wrong. For the stock carb in almost any tuning configuration, the stock Pilot Jet is retained.
A totally stock DR650 will run very very lean. Plugs will be nearly White no matter the throttle opening. This is how the bike was meant to run to pass EPA and such. A Dyno Jet needle/Jet kit will let the Carb be the best it can be and still get decent fuel economy.
I would remove the Carb. Replace the nasty Phillips screws holding float bowl on with Allen head screws. Work slowly and carefully. Choke and Throttle cables come off. All vent hose removed, put out of way. Take Pics so you know how it all goes back.
The current jetting is unknown to me. The previous owner told me the previous previous owner had rejetted it and cut the airbox(the whole top of the airbox under the seat is gone, k&n filter). And after this the first previous owner(guy I bought it from) told me he put the next biggest main jet in. So I really have no idea how it's setup currently, and no way to find out unless I'm lucky enough that the parts are labeled what they are.
I'm probably 500 feet over sea level, central alabama.
Stock exhaust
I will give a shot at taking the whole thing apart today and maybe I won't tear it up
shaddix screwed with this post 04-08-2012 at 01:40 PM
shaddix is offline   Reply With Quote
Old 04-08-2012, 12:52 PM   #62717
TonyTooTall
Oddometer: 20
DSC00083 by TonyTooTall, on Flickr
New to me, so much more fun that the street bike I use to have.
TonyTooTall screwed with this post 04-08-2012 at 06:27 PM
TonyTooTall is offline   Reply With Quote
Old 04-08-2012, 01:07 PM   #62718
ER70S-2
ER70S-2's Avatar
Oddometer: 2,556
shaddix:
Good pics, well lit, sharp focus, good macro.
But we want to see the porcelin coloring, please. Smaller would be good, for the guys still on dial-up. I think this is one of my original DR plugs, still lying on my desk.
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-08-2012, 01:22 PM   #62719
jon_l
Southern Ontario
jon_l's Avatar
Oddometer: 1,990
Originally Posted by Aerocycle View Post
I could be wrong here, but doesn't the axle shaft go through the other direction? Just something I noticed. Guess it wont make a difference if the spacers are placed correctly. But my Axle shaft is running through from the other direction. Maybe I screwed up....
You're right, the castle nut is on the right side.
'09 Honda CBF1000; '09 Yamaha WR250R
jon_l is offline   Reply With Quote
Old 04-08-2012, 01:29 PM   #62720
AST236
AST236's Avatar
Oddometer: 1,413
I put it back like it was when I got it.
Everything slid in place w/ no issues so I'm not sure if it makes much difference or not since the axle is just riding fore/aft in the slot in the swingarm.
Smarter people than me please jump in and tell me if I need to turn it around to avoid damage or falling on my arse....
Front sight, press.
AST236 is offline   Reply With Quote
Old 04-08-2012, 01:32 PM   #62721
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,382
idle:
half throttle:
full throttle:
Stock exhaust
Those plugs aren't too bad at all Maybe a tad rich? but far from BLACK. You could go down ONE main jet size (leaner) ... or go UP on the needle clip position to lean out a bit. But you don't need much. You are fairly close, IMHO.
If your air box is stock (top not cut open) then you could open it up and leave jetting as is. Doing this will also lean things out a bit. This may put you spot on jetting wise and MPG may improve too. Lots of back and forth, give and take balancing air / fuel mix.
Have fun.
Old 04-08-2012, 01:42 PM   #62722
shaddix
Oddometer: 586
shaddix:
Oops. I didn't realize the porcelain was what we were looking for. I am probably in good shape then because they'r epretty damn white:
I was able to get the carb out.. I'm gonna take some pictures of it and post them and perhaps someone can tell me what's been done to it.....
Old 04-08-2012, 02:22 PM   #62723
shaddix
Oddometer: 586
slide is drilled, and it has the funky screws and someone already changed the phillips head screws out with the hex screws
edit.. I'm a moron it says right on the jet what size it is.... 145 main jet bbut don't know if it's DJ or that other one... pilot jet says 52 PI... does that make sense?
This last photo is showing a port that had no hose connected to it when I was removing it from the bike, however in the guide I was following, i think it shows there is a hose connected to it... I do not know what this is for or what hose I am missing
Old 04-08-2012, 02:24 PM   #62724
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,175
Crank acces cover stuck
Originally Posted by mercenario27 View Post
I was trying to adjust my valves last fall when I stripped the crank access cover, not a big deal since I can spin the rear tire to find the timing mark. Problem is I couldn't find the "T" stamped on the crank. All I could find is this:
Mercenario, my crank access cover was stuck (PO had it too tight). Using the tire to turn the engine works, but is a pain in the wazoo.
Decided to use a cold chisel and a 2 pound hammer. Tapped the cover lightly around the perimeter to loosen the stuck threads.
Tried the big Allen wrench again but still stuck. Used the hammer and cold chisel to make a 1/2" long cut at the edge of the cover, in direct line toward the Allen hole. Then leaned the chisel so when struck with the hammer, it would unscrew the cover. Only took a few taps and it was loose.
After using a socket to turn the crank and adjust the valves, some anti-seize compound was put on the threads and went for a ride. A new cover is under $20, so may someday get a new cover... or not.
Dave
smilin jack is offline   Reply With Quote
Old 04-08-2012, 02:58 PM   #62725
shaddix
Oddometer: 586
So I'm reassembling the carb, and I have some extra parts >_>.. specifically an o-ring that I didn't see where it came from and have no idea where it goes. The service manual shows three o-rings, I know where two of them go. The third one the service manual doesn't specify where it goes in the assembly of the carb...... please help
Old 04-08-2012, 03:10 PM   #62726
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,110
Standard the nut is on the right which puts the adjusters up out of the way.
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780.
ADV8 is offline   Reply With Quote
Old 04-08-2012, 03:12 PM   #62727
AST236
AST236's Avatar
Oddometer: 1,413
Makes sense. I'll swap it around tomorrow.
Front sight, press.
Old 04-08-2012, 03:17 PM   #62728
ADV8
ADV8's Avatar
Oddometer: 2,110
I went and uploaded a pic encase you didn't see the edit...
Old 04-08-2012, 03:18 PM   #62729
zdiver1
zdiver1's Avatar
Oddometer: 338
http://www.bikebandit.com/2011-suzuk...2590#sch699793
go to link, ome, click on fuel and get the carb picture and blow it up.
zdiver1 is offline   Reply With Quote
Old 04-08-2012, 03:22 PM   #62730
ER70S-2
ER70S-2's Avatar
Oddometer: 2,556
Edit: The DR is happy with the stock 42.5 pilot jet.
If you took this out:
It might be this o-ring:
Yes, there's supposed to be a hose on that nipple.
It goes here (right side frame rail, next to snorkel), no filter, open end:
ER70S-2 screwed with this post 04-08-2012 at 03:40 PM
Times are GMT -7.   It's 12:55 AM.
