Old 04-11-2012, 01:20 PM   #62731
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Ride-til-sore! View Post
What! Who wants to play Fred Flintstone! Battery=Key part of ignition system!
His point is that you can BUMP START your DR650 ... even with a dead battery.
Old 04-11-2012, 01:25 PM   #62732
jon_l
jon_l's Avatar
Oddometer: 3,303
Originally Posted by Rusty Rocket View Post
I only get 2 seasons out of a battery. When they are marginal, even though they will turn the motor over, they won't fire up. Mine was to the point this spring, that unless I had it on the charger right before I tried starting, it wouldn't start up. New battery, touch the button and it's running. Must need plenty of juice to spin the motor and feed the ignition.
I would do whatever it takes to avoid pushing a DR for 3 hours on hilly single-track!
2 years is terrible. Do you buy good batteries? I buy Yuasa because they seem to be the best, and batteries are 1 thing I don't worry about getting a cheaper alternative. I shop for the best price on the best battery, but not the cheapest battery.
Our bikes stay on a Battery Tender Junior year-round, unless parked away from home. The previous owner said my 2006 had the original battery in it. I bought it in Aug 2011, and it has never missed a beat. I will replace it regardless, if the bike decides to stick around in my garage after this season.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 04-11-2012, 01:28 PM   #62733
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
Speaking of, what is the best brand to buy? I heard Westco is good?
http://www.techbatterysolutions.com/...Search=PTX9-BS about $45 shipped. with one year warranty.
I bought this same battery from another vendor, almost 3 years and still running strong...
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
fizzerfz1 is online now   Reply With Quote
Old 04-11-2012, 01:40 PM   #62734
jon_l
jon_l's Avatar
Oddometer: 3,303
I'd buy the Yuasa YTX9-BS
Here is the first vendor I found price is decent:
http://www.atbatt.com/product/23902/...tx9-bs/battery
CBF1000 & PCX150
jon_l screwed with this post 04-11-2012 at 01:46 PM
Old 04-11-2012, 01:58 PM   #62735
M1Jeep
M1Jeep's Avatar
Oddometer: 1,956
Upgrade your springs...OEM springs are too soft
Originally Posted by TRAVELGUY View Post
There was a post sometine back or on another forum where the guy was selling his brace because it hit his fender. I haven't mounted my brace yet but will be doing so in about a week. Will try to post if there is a problem of not.
TravelGuy
Originally Posted by procycle View Post
None of the DRs around the shop have a Superbrace installed so I can't take a close look. I haven't ever heard about an interference problem and after reading many thousands of forum posts I believe this is the first time this has been mentioned. I'm interested to know what the manufacturer says but I suggest you get their permission before repeating their private reply to you in a public forum.
I have a Superbrace on my 2005 DR650. It broke my Acerbis supermoto fender after bottoming out a few times. I am 180 LBS without gear and have the IMS 4.9gal tank along with tank panniers (tubes, irons, & small pump inside). I have Ricor Intiminators and was running Eibach .48kg straight rate springs (I think stock is .45kg?), which still is under sprung. I have since upgraded to the big boy .55kg straight rate springs found on the ProCycle website (the item description states it is for aggressive riders). The difference is night & day! The on-road plushness is no longer there but it rides and tracks so much better off-road. The fork eats up the rocks, bumps, and ruts without much notice compared to before.
If you are looking for improved off-road manners and are willing to sacrifice on-road plushness, get yourself some stiffer springs. It will transform your machine into a more dirt-friendly one. It worked for me, YMMV.
Just my .02cents
M1Jeep is offline   Reply With Quote
Old 04-11-2012, 02:03 PM   #62736
maynard911
Oddometer: 142
Originally Posted by maynard911 View Post
I purchased a Superbrace from Procycle and installed it per instructions. Measuring between the brace and the fender mounting bosses (fender removed) with the front supported off the ground there is 8 1/4 inches of clearance.With the fender installed it would be an inch or so less. My bike is not lowered. The front suspension travel is supposed to be 10.2 inches, so the brace is going to be hitting hard parts long before the fork gets to the end of travel. If you look closely at DirtySumo's picture (post 62853) you can see that there is nothing like 10+ inches of clearance. I have emailed both the maker and Procycle about the problem, but have not yet received a reply, when I do I will post it here.
The replies are in.
Superbrace says that they are aware that the travel is somewhat reduced but that in the five years they have been selling them no one has complained about bottoming. They where sorry that I was unhappy with their product and said if there was any problem returning it to the dealer to let them know and they would take care of it.
Procycle also said that they had been selling this product for years and had no complaints. They were very helpful, as always, and arranged for a merchandise return.
After removing the brace and remounting the fender I got out the tape and it looks like there would be about 7 1/4 inches between the brace and the stock fender flange. Then I put a wire tie around the fork tube and went out and did a couple of threshold braking runs from 65 mph. Back at the garage, front end up off the ground, the tie was at 7 3/4 inches. So with the set up I have I would be bottoming. This is with a nice sticky 110/19 Dunlop 607 on good pavement, stock springs, Intiminators, 320mm disc, HH pads, stainless brake line, and a 175 lb rider.
Things could be done to minimize the problem, like trimming the flange on the stock fender, a different fender, increase the oil level in the fork, or put in stiffer springs.
Or maybe it's just me, apparently no one else has any issue with the brace.
O well now I have a $159 Procycle store credit, shouldn't be to hard to decimate that.
Maynard " Youth is fleeting, immaturity is forever"
maynard911 is offline   Reply With Quote
Old 04-11-2012, 02:05 PM   #62737
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,438
Originally Posted by doug s. View Post
add a set of 'motard wheels to your dr650; a 'tarded dr650 makes a pretty sweet sport bike...
doug s.
yeah but do I haf'ta flip my forks??
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-11-2012, 02:09 PM   #62738
Rusty Rocket
Life behind "Bars"
Oddometer: 9,438
I just checked my records and I got 3 years outta my last battery. It felt like 2 I guess.
2009 DR650
Old 04-11-2012, 02:40 PM   #62739
Adv Grifter
Oddometer: 6,128
Just my .02cents
Stock Suzuki DR650 front fork spring rate is: .40 kg.
There are lots of variables to getting decent performance out of the forks.
And when your doing the front ... don't neglect the rear. Overall front to rear balance is important.
I've never heard of the .55 kgs. springs. wow! Those are super hunky ... glad they are working for you. But there are lots of other things to do to achieve both good performance On Road and Off Road.
For Off Road, I would try Race Tech Emulators over Ricor's product. Drilling holes in damper tubes can really help you adjust and fine tune your DR650 forks. Also, swapping the little rebound springs Race Tech provide and varying pre load spacer length.
Next, you can vary oil weight (from 5W to 15W) and the oil level in the tubes can be adjusted to suit. These changes give you even more fine tuning to get the forks where you want them.
Obviously, there is always some compromise regarding perfection of both ON and OFF road. But you can get close if you're willing to fiddle a bit and if you KEEP GOOD NOTES .... and have a CONSISTENT test ride routine that you know well.
Old 04-11-2012, 02:48 PM   #62740
heirhead
Oddometer: 581
swing arm bolt
Hello,
Sorry I couldn't find this! Switching shock spring. Does the bolt to the swing arm and link unscrew or do you use a drift to get it out after taking nut off? Have Kouba instructions but it does not say.
Thanks in advance for your help.
Heirhead
heirhead is offline   Reply With Quote
Old 04-11-2012, 03:26 PM   #62741
Tech23
Tech23's Avatar
Oddometer: 471
doug s.
I have to agree with you... I think the frustrated sport bike riders that frequent my favorite set of local twisties would too.... There just doesn't seem to be enough long straight aways back there for them to catch me.
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 04-11-2012, 03:30 PM   #62742
M1Jeep
M1Jeep's Avatar
Oddometer: 1,956
The rear was upgraded over a year ago...Cogent Dynamics and heavier spring. In retrospect, I should have upgraded the suspension first, then farkled it with a muffler, seat, and electronics last. I hear I am not the only one to see the light, late.
Thanks for the info on the RaceTech emulators and oil weights.
Old 04-11-2012, 03:46 PM   #62743
M1Jeep
M1Jeep's Avatar
Oddometer: 1,956
Originally Posted by heirhead View Post
Hello,
Heirhead
I believe you would use a drift to punch it out. Check out the image below...
Old 04-11-2012, 03:46 PM   #62744
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
I use Deka batteries made by East Penn Mfg. Their replacement for the standard Yuasa YTX9-BS is the ETX9.
I haven't tried it myself but I have found out that there are three Yuasa Batteries that are almost exactly the same physical size, but more Amp Hours/Cold Cranking Amps. I was really tempted to try one in my '09 when I replaced the battery this spring, but ended up going with the Deka.
The stock YTX9-BS-BS is 150x87x105 mm and 8AH/120CCA
The YTX-12A-BS is an AGM battery with the same dimensions and 9.5AH/175CCA
The YTZ 12S is an AGM battery that is 150x87x110 (5mm taller) and 11AH/210CCA
The YTZ 14S is an AGM battery that is also 150x87x110 and packs 11.2AH and 230CCA
I went to pick up 2 of the YTZ14S for me and my riding buddy and when tested one of the only two in stock had a bad cell. That made me uneasy, so I had him bring out a Deka ETX9 and test it and it exceeded the CCA of the YTZ14S so I bought the American made Dekka this time. (the salesperson told me Deka is known to be conservative in rating their batteries) I'd still like to do a side by side comparison of the YTZ battery and see if it spins the DR any better, but I've always had good service from the Dekka, so I'm not sure if I'll switch next time or not.
It sure looks like the YTZ14S might be an interesting replacement for the YTX9. It;s only 3/16" taller (5mm) and with a couple of washers under the battery retainer it apparantly fits under the seat just fine. However, if you are really concerned about weight, it does weigh about 2 pounds more than the stocker.
The only concern I might have is that there are probably more plates in the higher capacity battary in the same (relatively) size package. I've read before that this could cause a problem due to the plates being closer together.
Having said all that, I'm REALLY satisfied with the Deka ETX9. Also made in the U.S. of A. if that matters to you.
Here's the article I found this info in and a big THANK YOU to "Scott", wherever you are!
http://www.cs.clemson.edu/~westall/8...ki-battery.pdf
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 04-11-2012, 03:51 PM   #62745
Harpua
formerly josdavlar
Harpua's Avatar
Oddometer: 166
I'd guess lack of technique regards bump starting. Off road, bumping is a learned skill ... and having assistance helps. I would never push that bike ... that is insane. Tow Rope, Foot peg push, anything but you pushing. Get it running. You do realize the DR650 will bump start and run fine ... even with a dead battery?
I tried bump starting it at least a dozen times in 3rd, 4th and 5th gear. I got it once, but I had popped the clutch so late that I had to crash to avoid a tree. Then it died.
The guy I was with was a much more experienced rider, and he even tried to bump start it. No dice. Oh well... it was a lesson to be sure. Thanks for the sympathy.
ps-what is a foot peg push?
Harpua is offline   Reply With Quote
Times are GMT -7.   It's 12:25 AM.
