Old 04-14-2012, 11:08 AM   #62836
Flashback
Mommys Lil Monster
Flashback's Avatar
Oddometer: 3,096
Engine oil weep
Purchased my 2009 DR used in January with an oil drip @ the shift lever. The seal had popped loose and that was an easy fix.
After I fixed the shift lever seal, the engine started weeping higher up. I narrowed it down this morning to a leak originating from the circled spot in the photo.
I've tried tightening the screws with an allen wrench (very difficult to get to) but it is still weeping.
Can someone tell me what this thing is/does and why it is on my engine?. No clue at all and no luck locating an engine diagram that tells me.
Also wondering if this is a common leak area and if there are any suggestions for how to stop the leak.
I've searched and must not be searching in the right places cause I'm striking out on finding the information I need.
- Thanks-
DON'T PANIC
Flashback is offline   Reply With Quote
Old 04-14-2012, 11:14 AM   #62837
zdiver1
zdiver1's Avatar
Oddometer: 471
Originally Posted by Rob.G View Post
The fork brace is long gone. Since I lowered the bike, including moving the fork tubes up about 1", it was hitting my fender regularly, until it finally broke the fender (even after notching the sides of the fender). So I put the stock fender back on and sold the brace. I couldn't tell a difference without the brace either, so I'm not sure it's worthwhile.
Rob
Good feedback on the brace, I have taken it off my list.
zdiver1 is offline   Reply With Quote
Old 04-14-2012, 11:15 AM   #62838
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,269
- Thanks-
That's the cam chain tensioner. Mine leaked too. Order a new seal for it (factory part / cheap). Changing it is pretty simple, though right this instant I can't remember the exact procedure; hopefully somebody will post it again.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 04-14-2012, 11:20 AM   #62839
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
Originally Posted by Slideways#96 View Post
Anyone know of a good rear disc guard that doesn't require it be welded to swing arm? Been doing some searching but coming up empty. Any suggestions much appreciated..
If we could get 50 people to buy one, Scotts would build them. I've got one on my DR350 and would love to get one for the 650. I tried to drum up some interest, but could only get maybe 10 people interested. I had a thread at drriders and TT and posted in this thread a while back. Maybe I'll start a separate thread here and see if we can get more interest.
I believe if it was on Procycle's web site, it would sell.
It's not an inexpensive item, but it's really nice. Yes, it costs more than the rotor it's protecting, but I would still buy one if it was available.
I'm wondering if a complete DR350 rear end would work on my 650 so I can run the 350 version along with an 18" rear wheel for my off road wheel set. Otherwise I may break down and have one welded on my brake carrier. I know the DR350 wheel is a bolt on swap, but I don't know if the Scotts guard/brake carrier would mate up with teh 650 swing arm. I may have to give it a try since I have both here.
It replaces the brake carrier. Here's an example. This is NOT for the DR650.
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper screwed with this post 04-14-2012 at 12:26 PM
GaThumper is offline   Reply With Quote
Old 04-14-2012, 11:30 AM   #62840
ER70S-2
ER70S-2's Avatar
Oddometer: 7,253
- Thanks-
It's the CCT (cam chain tensioner) and a common leak on the DR, but read this before you start.
There have been a few killed motors because guys have just jumped in (looks simple enough), without knowing the potential consequences.
http://www.thumpertalk.com/topic/950..._fromsearch__1
Including this:
http://www.advrider.com/forums/showthread.php?t=715659
Edited to add the short version.
Kezzajohnson wrote:
Oil leak from Cam Chain tensioner at 24,000km roughly-cause unknown but maybe slightly overfull oil and long trip/high revs constantly. Engine to TDC on compression, remove oil pipes and exhaust header, retract and removed CCT, remove old gasket, clean up gasket surfaces and fitted new gasket with gasket goo also. refit and 6000kms later no oil leaks-clean as a babies bottom.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 04-14-2012 at 12:08 PM
ER70S-2 is online now   Reply With Quote
Old 04-14-2012, 11:36 AM   #62841
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 412
- Thanks-
That is your automatic cam chain tensioner (CCT) gasket. It is a pretty common leak spot. Tightening the bolts will probably not fix it. Easiest repair is a new gasket. Check out this thread for some information about it and some links to some write-ups of repairing it:
http://www.advrider.com/forums/showthread.php?t=636395
Tim
3DChief is offline   Reply With Quote
Old 04-14-2012, 11:55 AM   #62842
Flashback
Mommys Lil Monster
Flashback's Avatar
Oddometer: 3,096
Hah...Oh boy.
I just jumped in and removed the bolts that hold it on, then it popped out on its own...all this on an incline in my driveway.
Should have found a procedure first. I'm guessing I created a problem for myself.
But sure enough the gasket is torn under the housing, clearly no amount of tightening of the mount screws would have stopped the leak.
Thanks for pointing me in the right direction. Now to see if I can put it back together.
DON'T PANIC
Old 04-14-2012, 11:57 AM   #62843
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 592
disc guard
Originally Posted by GaThumper View Post
If we could get 50 people to buy one, Scotts would build them. I've got one on my DR350 and would love to get one for the 650. I tried to drum up some interest, but could only get maybe 10 people interested. I had a thread at drriders and posted in this thread a while back. Maybe I'll start a separate thread here and see if we can get more interest. I believe it it was on Procycle's web site, it would sell. It's not an inexpensive item, but it's really nice. Yes, it costs more than the rotor it's protecting, but I wold still buy one if it was available.
That's what I'm talking about. That's a nice piece, thought it won't fit the 650. May have to talk to a few buddies with machine shops and see if we can get something made for mine. Seems like certain after market or non oem parts for the fatchick are had to find.
Slideways#96 is offline   Reply With Quote
Old 04-14-2012, 01:28 PM   #62844
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,493
Front wheel spacer position?
Had my first flat today (nail) and was able to get a tow to a shop that would R&R the tire and put a new tube in but I had to remove and install the wheel from the bike.
No problem, just put it on its side in the parking lot and pulled the front wheel off but since the left hand side was down I didn't get a good look at the positioning of left side spacer. I reinstalled it how "I think" the spacer fits but I'm not sure its right.
Does the larger diameter end of the spacer go up aganist the fork or the wheel hub?
Any day on a dirt road is a great day
blk-betty is offline   Reply With Quote
Old 04-14-2012, 01:49 PM   #62845
ER70S-2
ER70S-2's Avatar
Oddometer: 7,253
The small end plugs into the wheel bearing seal, the large end against the fork.
2013 WR250R
Old 04-14-2012, 02:45 PM   #62846
jon_l
jon_l's Avatar
Oddometer: 3,461
Originally Posted by Aerocycle View Post
Who makes those side cases you got there? Size?
Not my bike, but the side cases look like Givi E21's (21 L).
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 04-14-2012, 02:51 PM   #62847
Heavy
Heavy's Avatar
Oddometer: 137
Hah...Oh boy.
Do a bunch of reading before you start bolting things back up.
There is never enough time or money to do it right the first time.
2008 DR650, 2006 V-Strom 1000, 2014 CB500X
Heavy is offline   Reply With Quote
Old 04-14-2012, 02:55 PM   #62848
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,493
Thanks man!
That is what "I thought' and how I reassembled it.
Now that I'm back home I'll loosen the the axle and clamp nuts and torque all to spec.
Old 04-14-2012, 02:56 PM   #62849
darmahman
"Illogically Deluded"
darmahman's Avatar
Oddometer: 3,100
BikeMaster 6000K HID install
Anybody put one of these on their DR? Any tricks?
ABC# - 4011
“Folks are usually about as happy as they make their minds up to be.” Honest Abe
The last honest politician to come out of Illinois
darmahman is offline   Reply With Quote
Old 04-14-2012, 03:06 PM   #62850
justscoutin
justscoutin's Avatar
Oddometer: 127
This is an old pic not long after I got the bike. Nice tires. I have a new set in the garage to go on when my 705s wear out.
Rob
Sent from my iPad using Tapatalk HD
Thanks Rob, those look better to me than the 705's. Are they louder or quieter than the 705's? I'm running t63's now and they are too noisy since I mostly run street, but don' t want to give up the gravel road ability. I like the look of the 700's.
03 DR650 xo40f muffler, jetted
98 Bandit 1200 in pieces
72 SL125 mid-restoration
72 SL70
Save Aetna Offroad http://www.advrider.com/forums/showthread.php?t=758193
justscoutin is offline   Reply With Quote
Times are GMT -7.   It's 09:15 PM.
