Old 04-26-2012, 07:14 PM   #63436
Tech23
Tech23's Avatar
Oddometer: 470
Originally Posted by DockingPilot View Post
Is this normal ? I have done an 07' and an 09' NSU screw locktite job. Both were typical jap philips head type screws.
Today I opened up a 2012 with only 200 miles on it and saw these screws.
Unheard of or no fellas ?
I would be curious enough to remove the lower allen bolt and see if the NSU has a metal insert/sleeve in it now. That would likely keep them tight. If there is no metal insert/sleeve that the bolt passes through I would still remove one bolt at a time and either apply loctite or drill the bolts and safety wire them. It's hard to tell from the pic...are those allen flange style bolts or allen bolts with washers or maybe allen bolts with captive washers?
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 04-26-2012, 07:24 PM   #63437
notarat
notarat's Avatar
Oddometer: 349
Went for a spin down to the river and took this one. It's like the bike absorbs light and just looks "meh" no matter where it is.
I'll see how well the white version looks when they arrive.
notarat is offline   Reply With Quote
Old 04-26-2012, 07:35 PM   #63438
Tech23
Tech23's Avatar
Oddometer: 470
Originally Posted by ER70S-2 View Post
On another post I remember someone saying they went into Autozone with the part#/sku and the counter guy disappeared into the back and returned with the plug. Probably the last guy to ever try to help.
Procycle has them for $11.95. That won't help you today though.
Edit: Maybe O'Rielly(sic?), Pep Boys, etc may show something locally.
From my personal experience, I was able to locate the proper size and thread pitch oil drain plug from and auto parts store. Sorry I can't remember which auto parts store it was. First off the magnet was very weak. The magnet would barely support the weight of the drain plug when I stuck it to the side of my tool box, the plug slid right down the side of the box. Also the plug threaded in half way and got tight like it was a tapered pipe thread. The threads looked fine?! I didn't want to risk wiping out the the threads in the crankcase so I put the stock drain plug back in it. I returned the plug to the auto parts store for a refund and ordered one from Pro Cycle. I believe it was a bike master brand magnetic drain plug. It fit properly and had a much stronger magnet on it. Also using PC's oil filter magnet.
Tech23
Old 04-26-2012, 09:11 PM   #63439
Ride-til-sore!
still 20 in-my-mind
Ride-til-sore!'s Avatar
Oddometer: 383
Originally Posted by fizzerfz1 View Post
It is easier than it seems, Like msanna said, start from the front and then go towards the back with staples about 8-10 inches apart and then you can come back and put some staples in between. It helps if you have somebody to hold the seat when you try to pull and staple the cover. A good stapler helps too.
I did it in about half hour.
Finally got it all done. It started out as a nightmare as neither the heavy hand stapler or my buddies electric would do the job! Had the wife giving me a hand and a little way into it she got tired of me swearing at the SOB crappy staplers and told me just to run over to Harbor Freight and buy the air powered one! So with about 20 mangled staples sticking out all over my little project it was a trip to Harbor! 20min's after getting the right tool the job was done and looks great!
Two words of advice I would give to anyone else going to do this job. Either get an air stapler right away and save yourself some headaches and a crappy stapling job. Or have your wife help you and swear up a storm until she tells you to go buy one! Thanks for all the ideas and help from everyone on here!
Ride-til-sore! is offline   Reply With Quote
Old 04-26-2012, 09:28 PM   #63440
Tech23
Tech23's Avatar
Oddometer: 470
Good advise, I've tried manual staple guns and even an electric stapler, neither one would sink the staple all the way home into the plastic seat pan. The electric gun would on occasion sink a staple properly but it took way too many attempts on each and every staple. That was one reason I sent my seat out. I would have no use for an air stapler with a manual staple gun and an electric staple gun around the house. Having the right tool makes all the difference.
Tech23
Old 04-27-2012, 02:59 AM   #63441
TRAVELGUY
Old Traveler
Oddometer: 699
+1
Originally Posted by ungeheuer View Post
to me..... It sounds like they put a lot of b&s into this to run one petcock. I reckon (based on nothing but the smell of it ) that this tank was originally engineered to be sold with dual petcocks, but that they bottled out and deleted the rhs petcock so they couldnt be dragged thru the courts if some buffoon allowed the rhs fuel line to leak/contact the exhaust header and .
"we only have one petcok coz we went to so much clever design effort to leave it out" (even though the internal boss for the second petcock is still moulded in - by all accounts).
I smell spin .
Regardless, if the acerbis was 6.6 gal as originally thought, i'd have me one in a heartbeat.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 04-27-2012, 04:04 AM   #63442
Go Irish75
Go Irish75's Avatar
Oddometer: 363
Cool2
Spin or not, its still a decent tank, looks good and holds alot of fuel. As with all the other plastic tanks, its going to stretch and will hold more than 5.3 gallons anyway.
Here's my signature
Go Irish75 is offline   Reply With Quote
Old 04-27-2012, 05:23 AM   #63443
nzrian
nzrian's Avatar
Oddometer: 375
No joke. Brand new bike. Last time that saw daylight was in Japan.
Im not sure if they are locktited in or not as I stopped after removing the cover. Worked all night so Im beat. But I guess Ill try and remove the closest one 1st to see what I find. I didnt even look to see if its a allen or torx yet. Cant quite tell from my pic. Also look at what appears to be an aluminum ring under the screw. I dont recall that either.
my aussie 2010 model had the allen head screws, when i checked trhem one was finger tight, i would be removing them and loctiting them if i was in your shoes.
[IMG]http:/
IMG_0160 by Rian2008, on Flickr[/IMG]
If you don't know where you are going, any road will get you there.
-Lewis Carroll.
nzrian is offline   Reply With Quote
Old 04-27-2012, 05:29 AM   #63444
mslow
Faccia Brutta
mslow's Avatar
Oddometer: 523
Originally Posted by Rotten Ronnie View Post
I don't need a second petcock if I'm willing to to lay the bike on it's side to slosh to the left hand side, correct?
That is my understanding as well, however the stock petcock will not fit the new tank without modifications to the tank.
Been waiting a week now for the new petcock to get to me and no sign of it yet...getting a little frustrated.
pin it!
mslow is offline   Reply With Quote
Old 04-27-2012, 05:40 AM   #63445
Ride-til-sore!
still 20 in-my-mind
Oddometer: 383
Tech23
I picked up a 2000 with only about 5,500 miles on it. Thought I should check this out some time. How long of a job is it and are there any little tricks or things to watch out for when doing it?
Old 04-27-2012, 05:58 AM   #63446
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,833
absolutley. i will so that today and report back.
Tech23
Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 04-27-2012, 06:16 AM   #63447
Potosi Joe
Oddometer: 324
It looks very nice! Is that a Corbin seat? How is the fit? How about a side shot.
Potosi Joe is offline   Reply With Quote
Old 04-27-2012, 07:18 AM   #63448
TrophyHunter
Oddometer: 2,270
NSU - One riders answer - http://www.advrider.com/forums/showp...ostcount=15044
If I didn't already have the IMS tank, which has been flawless, I'd have that Acerbis in a second.
'07 WR450 2013 HD Road King '73 Hodaka Wombat '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 04-27-2012, 07:45 AM   #63449
Go Irish75
Go Irish75's Avatar
Oddometer: 363
Yes it's the Corbin for the stock tank.
Here's my signature
Old 04-27-2012, 08:25 AM   #63450
bradrh
Oddometer: 433
acerbis tank
Originally Posted by msanna View Post
Anyone with the new Acerbis Tank just released...or anyone in general actually...
I spoke to the rep at Acerbis and he mentioned that an extensive amount of research and design went in to the design of the new tank to eliminate the 'need' for a second petcock. He spoke about how the design promoted the fuel to move to the left side.
I'm very curious about these new tanks & very sceptical about the fuel moving to the left side on it's own. I assume just by looking at the tank you can see that some will be isolated on the right side? Any guess as to how much? A couple of liters? A few gallons ? Would you have to lay it all the way down to get it to the other side?
- DR650
- WR250R times 2
bradrh is offline   Reply With Quote
Times are GMT -7.   It's 04:14 PM.
