Old 04-27-2012, 08:25 AM   #63451
bradrh
Oddometer: 414
acerbis tank
Originally Posted by msanna View Post
Anyone with the new Acerbis Tank just released...or anyone in general actually...
I spoke to the rep at Acerbis and he mentioned that an extensive amount of research and design went in to the design of the new tank to eliminate the 'need' for a second petcock. He spoke about how the design promoted the fuel to move to the left side.
I'm very curious about these new tanks & very sceptical about the fuel moving to the left side on it's own. I assume just by looking at the tank you can see that some will be isolated on the right side? Any guess as to how much? A couple of liters? A few gallons ? Would you have to lay it all the way down to get it to the other side?
- DR650
- WR250R times 2
bradrh is offline   Reply With Quote
Old 04-27-2012, 08:26 AM   #63452
mslow
Faccia Brutta
mslow's Avatar
Oddometer: 523
^^^^ Holy Sh!t...how do you keep that so dang clean?
I'd have to dip mine in brake clean and repaint it to make it look that shiny.
pin it!
mslow is offline   Reply With Quote
Old 04-27-2012, 08:39 AM   #63453
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,287
Originally Posted by godwinmt View Post
Got the mermite cans finished and mounted!
don't put your foot down while moving.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-27-2012, 08:57 AM   #63454
poppawheelie
poppawheelie's Avatar
Oddometer: 562
Re. DR650 in Ecuador
First in May 2012 [I]Rider[I] magazine, now a short blurb on SpeedTV web site.
http://motorcycling.speedtv.com/arti...ds-in-one-week
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie screwed with this post 04-27-2012 at 08:59 AM Reason: spelling
poppawheelie is offline   Reply With Quote
Old 04-27-2012, 09:18 AM   #63455
Rusty Rocket
Life behind "Bars"
Oddometer: 9,287
Originally Posted by FatChance View Post
Do they have an Advance Auto nearby? Look HERE.
$4.49. holy crap, I'm not paying those highway robbery prices!!!
If you look at the part # and compare with the part #'s that someone dug up from one of my past posts, the 3 is the same as that old one except the 3 is dropped in the beginning.
65256 vs, 365256 might be a store code for some purpose or even the manufacturer's number
2009 DR650
Old 04-27-2012, 11:17 AM   #63456
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Yea, those look like good leg breakers. But most hard bags are ... especially if you're paddling along in deep sand off road. Those are some BIG bags! One reason I got rid of my GIVI bags was they allowed me to carry too much stuff. If one never goes off road ... those Marmite's look pretty good. I wonder how tough they are if you go over?
My old GIVI set up. I liked them but lost 35 lbs. when they came off.
They sat Low and Forward. But whacked my leg a couple times here:
Old 04-27-2012, 11:35 AM   #63457
procycle
procycle's Avatar
Oddometer: 2,324
The couple times I've run out on my IMS there is has been less than a quart left in the right side. Not quite enough to go 10 miles riding like my grandma. That might be different if you are riding only on smooth straight roads but the little bumps and turns tend to splash over most of the fuel that would otherwise be trapped if the bike wasn't actually moving.
The righthand side of the Acerbis tank is not as deep as the left side.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 04-27-2012, 12:01 PM   #63458
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,356
Yabbut, if you spend another $95.51 you get 15% off so it would only be $3.82 and you would save 67 cents.
Dorman probably sells the same product with the same part number to multiple retailers...
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 04-27-2012, 01:54 PM   #63459
xKLR_John
xKLR_John's Avatar
Oddometer: 884
Now that the Acerbis is out....
The great tank debate... IMS vs. Acerbis, who's the winner? why?
xKLR_John is offline   Reply With Quote
Old 04-27-2012, 02:03 PM   #63460
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,736
Thumb NEW TURNSIGNAL RELOCATOR ready to ship!!
Gang
for those of you who went looking and found my fleaBay posting gone, I apologize. Have stock now on the turnsignal relocator just in time for riding season for a measley 10.99/shipped
Now more importantly I have a Transmission question. My faithful 'ole 97 has been acting oddly ever since I was forced to change the clutch cable.
What happened was it got chafed down at the shaft/case end because it "froze up" in the socket so that it was not rotating freely, metal fatigue set in and it finally frayed apart. In the last day of that process I had some hard shifts.
So replaced the cable and have gone many miles but it has been really crochety about shifting into 1st and 2nd. 1st is Always crunchy unless I roll it forward slowly. 1st to 2nd is dicey - at certain rpm's if I half-shift to neutral then tap 2nd its slick. If not, I get the grind. The clutch is disengaging fully as best I can tell. There is ZERO creep with the lever pulled. I've changed the oil, triple checked the level - all looks good and it barely had a fleck of metal in the oil when I strained it all to check.... so I'm baffled. The bike only has about 8K miles on it.
3rd through 5th, both ways, is slick. Downshifting into 2nd is like dropping off a ledge - there's quite a bit of room there. ???
any ideas or suggestions?
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 04-27-2012, 02:29 PM   #63461
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,736
the acerbis Safari tank for the BRP was terrific - I dunno if they just got lucky or what but it was really tough and acted as 'crash protection' for the radiator on that beast, it held plenty of petrol, and was formed in a way that accomodated a standing rider quite well - I could stand and lean forward just a bit and 'rest' against the wide part of it. plus it looked way better with that tank on.... chick magnet .
too early to tell with the DR tank. I have no complaints about my white IMS, except that the petcock finally became unreliable - swapped out a raptor valve
Zapp
Old 04-27-2012, 02:48 PM   #63462
J1M
StUcK
J1M's Avatar
Oddometer: 32
Cool2 New Tank/ just moved
Finally! i was able to purchase my new IMS tank, i was also able to purchse the corbin seat! woot woot! the tank is on now, im still waiting for my seat to arrive. been in the market for a luggage rack set up, i ran across these guys that had some pretty awesome gear. thot i would post real quick so u guys could check it out.. oh yea btw, I recently moved to Hawaii, any thumpers here in oahu?!? http://www.bboffroad.com.au/dr_6501.htm
J1M screwed with this post 04-27-2012 at 03:46 PM
J1M is offline   Reply With Quote
Old 04-27-2012, 03:05 PM   #63463
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Cool2
Clearly, the IMS is superior.
Because I already have an IMS...
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 04-27-2012, 03:07 PM   #63464
J1M
StUcK
J1M's Avatar
Oddometer: 32
im not too sure which is actually better but i went with IMS for the simple fact i liked the looks of it better over the acerbis.
Old 04-27-2012, 03:13 PM   #63465
MikkSteel
MikkSteel's Avatar
Oddometer: 32
I just moved to Oahu myself. Been here about a month. Haven't been able to do much riding yet besides commuting to work but the weather sure doesn't suck!
2006 XT225
MikkSteel is offline   Reply With Quote
Times are GMT -7.   It's 12:50 AM.
