Old 05-01-2012, 05:31 PM   #63631
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Geared up, I'm 205#. 1/2" spacers were too stiff and 1/4" were still too soft.
Both made a major improvement in brake dive.
Are your fork tubes flush with the top triple or slid up some.
Edit: Also about the lowered suspension: My stock forks (full extension) are 35 1/4" from the fork cap to the axle centerline. Factory lowered should be 33 3/4".
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 05-01-2012 at 05:42 PM
ER70S-2 is offline   Reply With Quote
Old 05-01-2012, 06:41 PM   #63632
Monroe
Monroe's Avatar
Oddometer: 657
Originally Posted by dljocky View Post
I've had three of those filler caps in the past two yrs, 30,000 miles, and all three have leaked. Rubber gasket failed in each. This last time, I was over 800 miles away from home, stopping at each motorcycle store, NAPA, lawnmower shop I could find to try and get another gasket. I think I ruined my brand new Wolman Small Enduro tank bag from all the fuel it took on. How do I get the smell of fuel out?
I don't think I'll use this cap again.
I also had a leaking locking cap for my IMS tank. The rubber gasket appeared to swell and deform, not fitting in the cap. I contacted Acerbis with pics of seal and cap and they sent me a complete new cap and have had no issues with the replacement: leaking or venting
Steve
Monroe is offline   Reply With Quote
Old 05-01-2012, 06:41 PM   #63633
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,260
Originally Posted by ER70S-2 View Post
Are you doing the 780 now?
Did you find out how much our DR motors weigh? That red cushion would make a nice seat.
There are no scales available so not sure of the weight,perhaps 50 something kgs (100+ lbs)
Mission today is strip the DR engine and get three of the gears in the post to Nova Racing Transmissions then prep it for reassembly and yes all the new upgrade parts.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 05-01-2012, 07:05 PM   #63634
Nibis
Where to next?
Nibis's Avatar
Oddometer: 844
Originally Posted by sirpy View Post
Hey guys,
So I have been eyeing off dr650s for a while, and last weekend dropped some cash for an old '96 dr that was turned into a nice looking motard. Little bit of a shame, is it looks really nice as it, but I plan to take it around Australia and will be decked out with camping gear and the like I plan on a long, trip around the coast line and through the middle, no time restraints. But as such I need to setup the bike to give me the least amount of grief as possible.
It seems to need a new clutch as it slips a little around 4k+ when given some right wrist. Ive been trawling through the net and this thread trying to get an idea of the most reliable clutch, and so far all I have got is steer away from EBC units, can any one give me a recommendation for a new clutch? OEM, Barnett? It has a dynojet kit and a little work done.
Im looking at rebuilding the engine, for piece of mind, I am a little unsure of how many ks the engine has on it, it feels good, will have a little look in a week or so. Im not too keen to replace the piston, but it seems people say they are cheap and might as well do it if the rings are being swapped. Ive been looking at after market pistons (havnt got price for oem always seems expensive) and so far only the 10.5 comp comes up. How much hotter does the high comp piston run? Does it need high octane fuel?
It currently has a 17inch front rim on, I havnt done any off roading with motorbikes as of yet, but I want to start, it seems people dont/fear smaller rims. Im sure there is a reason, but im not experienced enough to see why? Does ruts and so on through the handles around? Since Im sure i will be doing more road than offroad, im keen to keep the wheel size down? Seems a good compromise is 19inch What do you guys recommend?
Cheers,
Jason
Barrnett makes good clutches, you won't need the heavier springs though, IMO the stock clutch is the way to go
Jim
2008 DR650
Nibis is offline   Reply With Quote
Old 05-01-2012, 07:11 PM   #63635
ADVwanaB
BOLD NEW AVATAR
ADVwanaB's Avatar
Oddometer: 858
I just measured my forks with the bike on a stand. the forks are stock length at 35 1/4". HUH??? my kick stand has been welded so i thought the bike was lowered. I recall sitting on a bike in the showroom and it felt much taller. Now i need to look deeper. the rear shock bolt was in the bottom hole, and the "links" have a stamping on them of "32E". Are the links not stock????
2014 FZ-09
2005 CRF230F
2003 DR650
ADVwanaB is offline   Reply With Quote
Old 05-01-2012, 07:14 PM   #63636
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Do you think the new 3rd gearset will be ready in time for your reassembly?
Bottom hole is stock (high) and 32E is also stock. 32E is stamped all over the bike, on different parts. You may have the gel seat, it's shorter (don't remember how much). About the welded stand, mine is just a bit too long, I have to plan my stops, so someone may have corrected that.
2013 WR250R
ER70S-2 screwed with this post 05-01-2012 at 07:43 PM
Old 05-01-2012, 07:17 PM   #63637
notarat
notarat's Avatar
Oddometer: 333
What comes in a box marked "Medium" and is anything but?
My Acerbis tank! (damned if I didn't forget to check the petcock, lol)
And yet I didn't get to install it.
Why?
Because I was installing my other farkles like the Wolfman Luggage Racks, Moose Racing Day Bags, and Windscreen.
I have the Wolfman Expedition Bags in Yellow in the garage for later on.
I'm saving the tank for an upcoming wrenching day when I do my first oil change/filter change on it and check the valves (No. I still don't have 600 miles on it yet. I'm getting there. Don't rush me)
notarat is offline   Reply With Quote
Old 05-01-2012, 07:32 PM   #63638
mslow
Faccia Brutta
mslow's Avatar
Oddometer: 523
The Acerbis tank saga continues...
I finally got the right petcock from Acerbis after more than a weeks wait.
In reading previous posts, there were pretty clear instructions on how to pivot the fuel intake to the carb from 12 o'clock to 9 o'clock so there is no rise in the fuel line.
I followed it to the tee, heated it up, used a vise and all. Well the fuel inlet twisted like a twist tie. The base stayed put and the neck twisted.... It didn't break, but it does look like it got pinched some, but not closed.
So now what?
Do i drill it out and screw in a fitting? If so, what size and where would i get it?
Next, the petcock they sent does not have a connection for the vacuum line that was fitted to the stock petcock, what do i do with that to keep everything running as it should?
pin it!
mslow is offline   Reply With Quote
Old 05-01-2012, 07:35 PM   #63639
Rumlover
Ed
Oddometer: 707
Those are stock links. If it is in the bottom (lower) hole it is at the stock raised height. Probably the previous owner has taken preload off the rear shock (by way of the adjusting nuts on top of the spring) and lowered it a little that way, and shortened the kickstand because of that.
Might check if it is a "stock" shock\spring
Rumlover is offline   Reply With Quote
Old 05-01-2012, 07:43 PM   #63640
zdiver1
zdiver1's Avatar
Oddometer: 470
Vacuum line
So now what?
Remove the vacuum hose/tube and put a rubber cap on the carb fitting and on the fuel inlet you should of been ok, I would have left it alone and waited to see if I had a problem.
zdiver1 is offline   Reply With Quote
Old 05-01-2012, 07:49 PM   #63641
ADVwanaB
BOLD NEW AVATAR
ADVwanaB's Avatar
Oddometer: 858
How do i see if the rear shock spacer is in the TALL position by looking at it?
Or, do i need to take it apart to tell,,,,,,,,,,,,
2014 FZ-09
2005 CRF230F
2003 DR650
Old 05-01-2012, 07:50 PM   #63642
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Man, you are so '21 minutes ago'.
Hang on, I'll go measure mine. Oops, can't, I have a Cogent.
Measured anyway, there is 1-7/8" between the end of the shock body and the bumpstop. Maybe someone is bored and can measure the stock shock distance. If the spacer is flipped that distance is what's changed.
2013 WR250R
ER70S-2 screwed with this post 05-01-2012 at 08:01 PM
Old 05-01-2012, 07:54 PM   #63643
mslow
Faccia Brutta
mslow's Avatar
Oddometer: 523
When i dry fit the tank, there was just too big of a loop. All the posts made it so cut and dry to move the inlet....i must have worn out my mechanical mojo or something...it just didnt work. It twisted with very little pressure too, so bizarre.
So any thoughts? Anyone?
pin it!
Old 05-01-2012, 07:58 PM   #63644
ADV8
ADV8's Avatar
Oddometer: 2,260
The new Nova third gear set will be based on the gears I send Nova.
I will most likely get and test the first set so the engine will be prepped and waiting.
In the mean time I will go back to what I was doing in prepping the TR5T to trans Australia spec (full engine rebuld,Kibblewhite,SRM etc)
Once that is done it will be the Eldorado's turn.
After that it will be getting ready for India.
Old 05-01-2012, 08:00 PM   #63645
Rumlover
Ed
Oddometer: 707
Page 5-53 of the manual has a good picture, wish I was better at posting pics -- maybe someday I will get off my lazy but and try it.
ER70S-2 is good at it!! He is my hero for posting pics.
Anyway that will only effect shock travel not height. I Highly suggest getting a manual if you don't have one.
Times are GMT -7.   It's 08:03 AM.
