Old 05-04-2012, 01:03 PM   #63781
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,732
Originally Posted by Xplorr View Post
That's a great idea; and one I would be all over if I had the cash. It's hard enough to come up with $500 for the shock. Earlier this winter I planned to get the Cogent treatment while the bike was hibernating, but that didn't work out. Me and the missus had a son a few months ago; and strangely enough there is less $$$ for moto upgrades . (I told her she better start budgeting for two riders in the house! )
Cheers, matt
Do the work yourself, that way you don't have to waste the money paying someone to do it, and you get it done the same day.
Old 05-04-2012, 03:40 PM   #63782
Nibis
Where to next?
Nibis's Avatar
Oddometer: 844
Originally Posted by Rusty Rocket View Post
Replace the 2 O-rings on the float assy. It's possible that you are getting extra fuel in the float bowl while running. It doesn't show up as a problem while the bike is off because the petcock is vacuum operated.
This was a almost brand new carb sold by Zdiver to putzy, zdiver was getting like 50 mpg on his bike, and upgraded to the TM40, putzy bought his BST in hopes to fix his mpg problems
Jim
2008 DR650
Nibis is offline   Reply With Quote
Old 05-04-2012, 03:59 PM   #63783
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,384
I wonder if it came with the choke plunger and if it is seated properly.
Any DR should be able to get 20 kms (12 miles) per litre. (56 mpg / imperial = 4.5 litre) easy.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 05-04-2012, 05:16 PM   #63784
jon_l
jon_l's Avatar
Oddometer: 3,307
Originally Posted by msanna View Post
as far as bags go, i love my giant loop, can't even tell its there, the weight stays low and tight to the bike.
i rode in this morning through a rainstorm and all is dry
Size looks right on the DR. Which GL is that? Great Basin or Coyote?
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 05-04-2012, 06:35 PM   #63785
TrophyHunter
Oddometer: 2,253
Coyote. I have the same one. Don't use it for a daily bag though, mostly an overnight or weekend. It's sturdy when mounted up and survived with just a rub when I rode it into the ground going about 30 on the dirt.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 05-04-2012, 07:32 PM   #63786
notarat
notarat's Avatar
Oddometer: 340
You can now add me to the list of expectant DRs.
Can't even really tell the extra weight is there, but I can definitely feel it when I'm trying to grip the bike with my knees.
notarat is offline   Reply With Quote
Old 05-04-2012, 08:04 PM   #63787
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,418
Tank & Panniers
The Tank looks great ...
How do you like those panniers ??
Thanks ...
Honda
GsVs is offline   Reply With Quote
Old 05-04-2012, 09:15 PM   #63788
notarat
notarat's Avatar
Oddometer: 340
Thanks ...
The panniers are pretty nice, actually. I only use them for day trips, but they do very well in that role.
Old 05-04-2012, 09:32 PM   #63789
ER70S-2
ER70S-2's Avatar
Oddometer: 6,780
Originally Posted by zdiver1 View Post
Hi Paul
So on the 1st full tank since I installed your carb, i still only got 36 mpg, all commuting to work at 35-60 mph on city streets and knobby tires. I just dont believe all you people saying you getting 50+ mpg! :(
So not sure what to think now. I will say it seems to be idling quite high. I don't know how to see what RPM its running at though.
Anyway, I guess my problems are continuing. Too bad.
I was getting 45 to 50 mpg when I took it off and I am getting 50 mph with the tm40.
So I do not know what to tell him.
Any Ideas to help Putzy?
Bump, let's get Putzy fixed............oh, wait.......... Let's find his gas leak. Nibis covered driveline friction, ADV8 hit the possibly stuck choke cable assembly (whatever type is on the bike), zdiver1 supplied a known good BST carby (eliminates the two o-rings), didn't someone mention the petcock? Putzy: do you have a stock tank and petcock (sorry, I don't remember)? It will look like these following pics. ON PRI RES If so, remove the fuel line at the carb or petcock with the petcock set to ON, bike off. Fuel should not flow, rotate petcock to PRI, fuel should flow, quickly (so you don't burn down yer house), rotate to RES. Fuel should not flow.
Stock petcock pics:
ON:
PRI:
RES:
Stock choke assy, the black plastic is, well it's plastic and has been known to break; murdering fuel mileage and difficult to diagnose.:
Lower your idle rpm, is the idle fuel screw stock? If stock, it won't look like this:
Can you post pics, starting with the chain and sprockets?
Bad juju: (NOT MINE)
Almost forgot; what year, mileage and color?
Originally Posted by ADV8 View Post
Holed engine cover on the Buchanan Highway,no biggie.
http://en.wikipedia.org/wiki/Buchanan_Highway
401 kilometers, 260 miles of dirt; rock and roll.
Originally Posted by jon_l View Post
Mr. DR - No idea re: Jesse's whereabouts, but if you can find a square drive "Robertson" #2 stove bolt, double-nut it, I believe it is the same size. Someone here will confirm (or deny).
I don't know what it's called but this is pretty much correct. If in the USA, Home Depot has square drive deck screws. The hole is 'about' 1/8" square. Buy a screw, grab it with a vice grip and bingo, a rocker adjustment tool.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 05-04-2012 at 09:46 PM
ER70S-2 is offline   Reply With Quote
Old 05-04-2012, 09:33 PM   #63790
Fire Escape
Fire Escape's Avatar
Oddometer: 1,601
New Sneakers ... almost
New MT-21 front and T-63 rear. They are mounted on the wheels in place of the worn out TKCs. Now I just need to get those wheels and the pile of parts I bought last year applied to the bike. Front springs, rear springs, 43T sprocket, I think there are some LED directionals and some maintenance fluids as well. I bought the T-63 a year and a half ago after reading good comments about it, the MT-21 was favorably reviewed in print, we’ll see. At this point anything should be an improvement and as my parts guy (pusher) says, ‘If you don’t like it try something different next time – tires aren’t forever’. Probably going to be a big change from the sm wheels and RoadSmarts I have been riding on!
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape screwed with this post 05-04-2012 at 09:40 PM
Fire Escape is offline   Reply With Quote
Old 05-04-2012, 09:36 PM   #63791
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
New pick-up coil ordered
Originally Posted by joefromsf View Post
Welcome to the failed pickup coil club. That's 3 of us in the last month; WilderRider being the third. FYI, new coil will probably test at around 350 ohms; which is higher than the spec in the manual.
The leads on the new one are now red and white. WilderRider told me he connected red to blue and white to green. I did the same but it didn't work for me. Had to swap green/blue spades in the connector at the CDI unit to get it to start & run.
Measure how long the old leads are between the old coil and the rubber grommet, and make sure to have the same length on the new one. Also, I was able to easily push the new leads thru the rubber grommet so that the soldering was done on the other side of the grommet (outside the stator cover).
You can PM either one of us for questions, though I will be out of town this weekend.
Good luck.
Question to the collective: What are the possible causes of pickup coil failures? Just wondering.
Our electrical engineer at work said bring in the old pick-up coil for him to autopsy and possibly rewind. Sounds good to me.
The new coil is coming from California and the new gasket is here from ProCycle in one day. Can't beat fast delivery from PC! Thanks Jeff and crew.
Guess the lawn can be mowed while waiting on parts.
Dave
smilin jack is offline   Reply With Quote
Old 05-04-2012, 10:16 PM   #63792
ER70S-2
ER70S-2's Avatar
Oddometer: 6,780
Originally Posted by NumberCruncher View Post
Great bag and great signature line.
You are Denverish?? I'll be taking my DR650 and TXC250 to Colorado this summer. Looking forward to taking the DR650 up Engineer Pass, Imogene Pass, Crystal Mill, etc.
NC
It's funny, when you live in a state it seems the grass is greener somewhere else. I'm a southern Utah junkie, ridden thousands of miles over there and it will be my next trip. Yes, SE Denver, I throw rocks at Park Meadows Mall. When you get to Crystal Mill, be sure to take the walk up to the Marble marble mine. It stunned me....................wow this is big. Then the selling market changed and they just shut it down.
Yep, this should work. TXC250:
I've used them both and like 'em.
Bruce
This is so true. I got absorbed by the internet ADVrider tire posts. This one's better, no it izzn't, and on and on and..............Buy a tire, wear it out and buy a different one next time.
Dave
That's cool that you have an engineer willing to look at it. I didn't have a clue that something like that could be rewound. Screw the lawn, the neighbor won't keep his effin' dogs quiet, so I quit working out there.
PS: Today's 228 miles sucked.
2013 WR250R
ER70S-2 screwed with this post 05-05-2012 at 10:02 AM
Old 05-05-2012, 04:43 AM   #63793
xKLR_John
xKLR_John's Avatar
Oddometer: 885
My 2 cents. Based on the video, you and your DR650 kept up with your 2 buddies on their DRZ400s. The DR650 did fine. You needed just a hair more speed/momentum in a couple of rocky spots but you made it through with you and your bike in one piece. On a more philosohpical note, I reckon it's the human condition to compare and contrast what might be "better." I say relax and enjoy the ride, looks like you had a fun day!
Originally Posted by Trailrider58 View Post
Will try this again. Just wanted to share my two cents on the topic of which bike to buy - DRZ400 or DR650? Know this may make some viewers mad here, but truly if most of your riding is on rough trails go with the DRZ. Don't get me wrong, I love my DR and won't ever part ways, but for our future trail adventure excursions, I'm going with something lighter and more trail worthy. The DRZ will be my first option. The DR will just have to get used to another stable mate in the garage along with the two MX bikes.
http://www.youtube.com/watch?v=gC86OTxX6bE
xKLR_John is online now   Reply With Quote
Old 05-05-2012, 05:05 AM   #63794
thetable
thetable's Avatar
Oddometer: 1,458
I love the T63 for what I do. It wears better on the asphalt, and hooks up better on wet pavement. The only place where the MT21 was superior was greasy, muddy trails. Loose dirt, hard pack, and gravel, they're pretty equal.
thetable is offline   Reply With Quote
Old 05-05-2012, 06:51 AM   #63795
nat_han
2 Wheelers By Choice.. =]
nat_han's Avatar
Oddometer: 200
Originally Posted by ER70S-2 View Post
I found it entertaining, thanks. I had no idea there were that many rocks 'back there'.
Once the wives see whut yer up to, there will be no more pardons. Since no animals were injured, what did ya eat??
Here's a pic of 4 needles. The top two have 5 clip positions, the third only has one (stock DR650), look closely, the bottom one has 6. Lying on their side, the positions count from the left to the right (top to bottom). If you put the clip in #1, the needle drops further into the needle jet (a replaceable part in the carb). This restricts the flow and leans the mixture.
The opposite is true, if you put the clip in #5, the needle is raised to a narrower point on the taper and the mixture gets richer (more fuel).
Ok, I did my part, your turn: I'm honestly not trying to be a butt head (and I was in your shoes a very long time ago). If you don't know a lot about the bike, why are you screwing with it? Reading stuff on the internet will make you nutz if you try to do it all. The only thing a stock DR needs is a new seat. Read less, ride more.
It took me an hour to find this photo is courtesy of mx_rob: (could not remember) Crap, it's midnite.
Thanks alot for your help!
Well, I've read many reviews that the TM-40 is pretty much the 'holy grail' of mods- that you'll have no regrets on...
So i saved up and put the trigger! Still have yet to install it but I'm particularly concern about the fuel consumption thereafter.
I'd opened the top cover of the TM40(with reference from the manual provided by PC) trying to gain access to the needle and clip for adjustment, but I just couldnt reach it with the needle and clip so far down inside the Carb...
To adjust the clip, what components/parts of the Carb do I have to unscrew to have access?
Thanks again!
nat_han is offline   Reply With Quote
Times are GMT -7.   It's 11:44 PM.
