Old 05-05-2012, 08:30 AM   #63796
xKLR_John
xKLR_John's Avatar
Oddometer: 890
Acerbis tank is sharp. I always thought the IMS tank looked good on the DR650. I'm gonna buy one or the other soon but I can't decide. Probably can't go wrong either way.
Originally Posted by notarat View Post
You can now add me to the list of expectant DRs.
Can't even really tell the extra weight is there, but I can definitely feel it when I'm trying to grip the bike with my knees.
xKLR_John is offline   Reply With Quote
Old 05-05-2012, 11:20 AM   #63797
ER70S-2
ER70S-2's Avatar
Oddometer: 7,248
Originally Posted by ER70S-2 View Post
......ADV8 hit the possibly stuck choke cable assembly (whatever type is on the bike)
Stock choke assy, the black plastic is, well it's plastic and has been known to break; murdering fuel mileage and difficult to diagnose.
I forgot to mention that the choke cable has corroded inside the liner on some DRs maybe caused by humidity, parking outside and age. When you think you've released the choke, the plunger stays partially choked. Remove the plastic nut (gently), pull the cable out and feel how the cable slides in and out. Be aware that the only thing reseating the plunger to choke off, is that little spring. Be careful putting the nut back into the carb, last time I did it, I had trouble getting the threads to start. One of my rules is: if you can't start it with your fingers, find out why! I avoid putting a wrench on something that won't start with my fingers.
Can you post pics, including the chain and sprockets?
Originally Posted by TrophyHunter View Post
Ogio comes with quick release tie downs attached and expands when necessary. Also has a built in pad in case you don't have a rack. http://www.amazon.com/Ogio-110091-36.../dp/B0035JLODK
In times like these...
Hey, I was in Julian in February.....................nobody told me there was Oven Fresh Julian pie?!?!
Originally Posted by nat_han View Post
Thanks alot for your help!
Well, I've read many reviews that the TM-40 is pretty much the 'holy grail' of mods- that you'll have no regrets on...
So i saved up and put the trigger! Still have yet to install it but I'm particularly concern about the fuel consumption thereafter.
..............snip...............
Thanks again!
Thanks for answering my question.
A few observations: It's true that the TM-40 gets a lot of praise (I don't have any experience with one, mostly stock BST). Just remember that learning jetting can be frustrating as many have discovered, so be patient with your conversion. Fuel consumption is high on my priorities too. The 3.4 gallon stock tank is just big enough for my needs. Sure I could get one of the 5+ gal aftermarket tanks, but the DR is already top heavy (and the only reason I replaced the stock exhaust), my 30" inseam is on my tippy toes at stops and I don't want anymore weight fighting me.
Where are you and what are your riding plans? Long distances and camping, like Australia, or shorter stuff like my day rides? Are you a new rider or been doing this for years, on the street maybe?
If you're going to be riding any kind of dirt (fast, slow, far), suspension work will be an nice awesome improvement. I'm running a Cogent rear with the rebound option and Race Tech Emulators + Eibach 4.6 springs in the front, but that's leaning hard on $700.
Originally Posted by NumberCruncher View Post
Great bag and great signature line.
.....Crystal Mill, etc.
NC
I forgot, the walk up to the marble mine is only about 15 or 20 minutes IIRC. It will seem a lot farther if you're wearing something like SIDI Crossfires though.
My sig: my Parents screwed up the first third of my life, my ex screwed up the second third; so I'm going to take care of the rest of it on my own. (actually my Parents were great)
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 05-05-2012 at 11:26 AM
ER70S-2 is offline   Reply With Quote
Old 05-05-2012, 11:43 AM   #63798
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,460
The best thing you can do with a TM40 is to use the Procycle set up. Don't try and reinvent the wheel.
BUT! Do verify the set up of the needle position and the main jet size before installing. It takes very little effort.
Mine had the correct needle position, but the main was a 140, which is stock. I needed a 145 at the time. Now I run a 150 with the GSXR exhaust. Needle has stayed at 3 if I remember right.
I gained an average of 3 mpg over the BST for some reason. I was expecting less with a pumper. The bike averages 50 mpg now, with the jetted BST 47 mpg was my best. I saw 54 mpg on a long interstate run at 65 mph. I'm happy.
Even while hammering the throttle up hwy 28 it still gets around 49 mpg.
Keep in mind fuel blend vary, I do burn rual 87 octane and I seek out non-ethanol go juice as much as possible. Having a big safari tank helps me pick and choose my fuel stops, I rode 300 miles yesterday on 100% gas, still have about 3 or 4 gallons left. ;)
Sent from my GT-S5690L using Tapatalk 2
sagedrifter screwed with this post 05-05-2012 at 11:51 AM
sagedrifter is offline   Reply With Quote
Old 05-05-2012, 12:01 PM   #63799
Olas
the darkness
Olas's Avatar
Oddometer: 4,083
Anyone else with the Utah skid plate notice how close to the engine the nut on the back of the frame clamps sit? Just noticed this the other day while cleaning the bike.. Looks like one good hit and that nut will be making a hole down there. Any fixes for this? Extending the skid plate to use the stock guard mounts seems like the ideal thing to do, like the Pat Walsh plate, but...I don't have the resources to weld aluminum.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 05-05-2012, 12:51 PM   #63800
ER70S-2
ER70S-2's Avatar
Oddometer: 7,248
Olas:
You're right and it has already happened to a couple unlucky inmates. I don't remember where I saw the pics, but there is a recess on both sides of the case that you want those nuts to line up with. You can move the plate front-to-back an inch or so before tightening the front clamps.
Yep, lengthening it to use the rear nuts already in the frame, would be nice.
2013 WR250R
Old 05-05-2012, 01:04 PM   #63801
Putzy
Oddometer: 61
well i dont need to worry about my fueling problem for a while. broke my arm just below shoulder today after departing my DR. :( but thanks for the tips.
Bump, let's get Putzy fixed............oh, wait.......... Let's find his gas leak. Nibis covered driveline friction, ADV8 hit the possibly stuck choke cable assembly (whatever type is on the bike), zdiver1 supplied a known good BST carby (eliminates the two o-rings), didn't someone mention the petcock? Putzy: do you have a stock tank and petcock (sorry, I don't remember)? It will look like these following pics. ON PRI RES If so, remove the fuel line at the carb or petcock with the petcock set to ON, bike off. Fuel should not flow, rotate petcock to PRI, fuel should flow, quickly (so you don't burn down yer house), rotate to RES. Fuel should not flow.
Stock petcock pics:
ON:
PRI:
RES:
Stock choke assy, the black plastic is, well it's plastic and has been known to break; murdering fuel mileage and difficult to diagnose.:
Lower your idle rpm, is the idle fuel screw stock? If stock, it won't look like this:
Can you post pics, starting with the chain and sprockets?
Bad juju: (NOT MINE)
Almost forgot; what year, mileage and color?
401 kilometers, 260 miles of dirt; rock and roll.
I don't know what it's called but this is pretty much correct. If in the USA, Home Depot has square drive deck screws. The hole is 'about' 1/8" square. Buy a screw, grab it with a vice grip and bingo, a rocker adjustment tool.
Putzy is offline   Reply With Quote
Old 05-05-2012, 01:32 PM   #63802
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
After riding my '99 DR650 for seven years and 40k miles it was finally getting worn out... So I bought a new one!
I didn't care for the 2012 grey color so I found a brand new 2011 in white. It is the only 0 mile vehical I have ever bought but after riding my last one so long and hard I knew it was worth every penny. The kicker was the Suzuki Zero intrest for five years deal! I am so excited to have a fresh bike to ride and tinker with for years to come. I think that with all that I have learned from ADV. and this thread in particular that I will be able to get alot more miles out of this one before I am done with it.
jessepitt is offline   Reply With Quote
Old 05-05-2012, 01:41 PM   #63803
doug s.
Oddometer: 1,354
ouch!
sorry to hear this; here's to a full & speedy recovery!
doug s.
doug s. is offline   Reply With Quote
Old 05-05-2012, 01:41 PM   #63804
TrophyHunter
Oddometer: 2,309
Sorry to hear that Putzy. I'm sidelined with some ribs and Vicodin right now too. Hang in there.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 05-05-2012, 01:47 PM   #63805
doug s.
Oddometer: 1,354
wow, new bike - congrats!
but, i can't help but thinking how nice i could make your current bike, w/$5k to throw at it - big bore/bigwalves, usd rm forks, cogent rear shock, sm wheels/tires, big brake rotor, hi-flow exhaust w/gsxr can, upgrade seat, hid lighting...
doug s.
ps - white is the best color!
Old 05-05-2012, 02:06 PM   #63806
zdiver1
zdiver1's Avatar
Oddometer: 471
Pissed Speedy recovery on the wing! Putzy.
If the bike is going to be Idle put some seafoam in the tank 1oz per gallon.Paul
zdiver1 is offline   Reply With Quote
Old 05-05-2012, 02:09 PM   #63807
zdiver1
zdiver1's Avatar
Oddometer: 471
Thumb Did a 106 mile ride today.
Went on a 106 mile ride today and used 1.9 gallons so 54 mpg is not bad. With the Procycle out of the box settings TM-40.
zdiver1 screwed with this post 05-05-2012 at 02:37 PM
Old 05-05-2012, 02:11 PM   #63808
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,385
If the air box is modified.
It might say that in the instructions,can't remember.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 05-05-2012, 02:19 PM   #63809
zdiver1
zdiver1's Avatar
Oddometer: 471
Wicked Er70s-2
When you said lets get Putzy fixed you did not think we would need a Orthopedic surgeon!
Old 05-05-2012, 02:45 PM   #63810
ER70S-2
ER70S-2's Avatar
Oddometer: 7,248
Originally Posted by doug s. View Post
ouch!
doug s.
That's really a bummer Putzy, sorry to hear it. Is it your dominant arm?
Zdiver1: you're right, this isn't quite what I had in mind. And putting in some fuel stabilizer is a good idea. I'd be completely satisfied with 54 mpg with a TM-40. Is the jetting 'as is' from PC?
2013 WR250R
Times are GMT -7.   It's 12:43 AM.
