Old 05-06-2012, 12:27 PM   #63856
ER70S-2
ER70S-2's Avatar
Oddometer: 6,108
Both Metal Head Gasket Rivets
FWIW: If something like our metal head gasket is riveted, two rivets would have to be used the keep the two layers aligned. One is on the lower, right front corner of the cylinder, the other is at the left rear. This is a good pic of that second rivet.
For the curious, right front corner.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-06-2012, 12:44 PM   #63857
ER70S-2
ER70S-2's Avatar
Oddometer: 6,108
Originally Posted by procycle View Post
Those are shrinkage marks from the casting process. Perfectly common and normal on many cast aluminum parts. Look at any other bike (not just DR650s) and you'll see the same thing.
My front hub:
Someone else's front hub (ignore the incorrect seal position).
2013 WR250R
Old 05-06-2012, 01:57 PM   #63858
LexTalionis
Inciteful
LexTalionis's Avatar
Oddometer: 441
Have you got a folder in your computer containing every picture posted in this thread???
Lex
Originally Posted by ER70S-2 View Post
My front hub:
The older I get, the better I was.
LexTalionis is offline   Reply With Quote
Old 05-06-2012, 02:08 PM   #63859
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
You don't?
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 05-06-2012, 02:16 PM   #63860
ER70S-2
ER70S-2's Avatar
Oddometer: 6,108
Talking
Most of the good ones. Tryin' to get the new guys up to speed.
Pics are easier than splainin'.
I was in the carbie last night (pilot jet replace, just in case), they'll get posted as the subject comes up. [flash bulb smilie]
Hope I'm not murdering the bandwidth thingie.
Originally Posted by NordieBoy View Post
You don't?
Two words.
2013 WR250R
Old 05-06-2012, 03:14 PM   #63861
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Broken Arm
Originally Posted by Putzy View Post
well i dont need to worry about my fueling problem for a while. broke my arm just below shoulder today after departing my DR. :( but thanks for the tips.
Dang, sorry to hear about the hurt wing. You will heal quickly, right? In the mean time, learn everything about your DR so you can help us fix stuff.
Get better soon.
Dave
smilin jack is offline   Reply With Quote
Old 05-06-2012, 03:21 PM   #63862
mslow
Faccia Brutta
mslow's Avatar
Oddometer: 523
Acerbis Tank update, had the DR out playing in a silt basin yesterday and got to crash test the tank...
It held up perfectly, barely a scratch, haha!
Looks good, performs well and crashes much much better than stock
pin it!
mslow is offline   Reply With Quote
Old 05-06-2012, 03:24 PM   #63863
smilin jack
Grandpa Adventurer
Oddometer: 1,228
Good Oil
Originally Posted by fbritt5 View Post
2001, 40,600 miles and just did my first oil change..... and new air all around too!
Frank, glad you had good engine oil in there to last 40K miles (know you joke). Don't forget to stop over and get that rear tire.
Dave
Old 05-06-2012, 03:25 PM   #63864
shaddix
Oddometer: 647
Hey how come this bike can go just as fast in 4th as in 5th?
shaddix is offline   Reply With Quote
Old 05-06-2012, 03:45 PM   #63865
Fire Escape
Fire Escape's Avatar
Oddometer: 1,553
Eh? Top Speed
5th is just an overdrive for many of us. Speed is limited by horsepower, rolling resistance and aerodynamic drag. If you put a big enough front or small enough rear sprocket it would go just as fast in 3rd as it does in 5th. More gears certainly help with acceleration but after reaching the balance point between power and drag you would not go any faster with 20 gears.
The preceeding simplification presumes that you have enough gears and clutch to get the load rolling and reach your horsepower peak. It also neglects wind and hills for those of us who have to deal with them.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 05-06-2012, 03:52 PM   #63866
ER70S-2
ER70S-2's Avatar
Oddometer: 6,108
2013 WR250R
Old 05-06-2012, 04:04 PM   #63867
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 7,252
Because it runs out of power before it runs out of revs in those gears, and dirtbike aerodynamics suck.
Gear it down so that your max cruising speed in top gear is not screaming the revs, but much higher would start to. This will also improve your gearing for offroad and for starting from a stop with a heavy payload. The stock gearing (USA) is pretty tall for a dirty bike, and the stock power output is ho-hum for a 650. Bump up the power and use a flat-slide pumper carb to improve the low-rev manners.
I wouldn't want to be able to hit the rev-limiter in top gear, but re-gearing and uncorking might get you there in 4th.
Why worry about it though? Get a sportbike and go to the track if you want to go faster than a DR will go. If you really want to know if the DR is fast enough to hurt though, take it on some tight singletrack and hold it WFO in 5th for a while. This bike has more than enough mojo to kill you.
Kommando screwed with this post 05-07-2012 at 12:57 AM
Kommando is offline   Reply With Quote
Old 05-06-2012, 04:08 PM   #63868
Rugby4life
Rugby4life's Avatar
Oddometer: 705
Because the speed limit sign still says 70 after you shifted?
"Before attempting to beat the odds, first determine if you can survive the odds beating you."
Rugby4life is offline   Reply With Quote
Old 05-06-2012, 04:37 PM   #63869
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,845
It's interesting to me to read about the DR650 needing a sixth gear. Seems plenty fast (top end) to me with five gears. I want a lower gearing overall for offroad, knowing that gearing down a bit will still leave me with the top end I need for commuting to and from work during the week. I don't think I've ever had it on the Interstate, but highway speeds I want for naught, and seldom use fifth for very long.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 05-06-2012, 05:52 PM   #63870
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
What was your top speed in 4th gear?
The DR will rev quite a bit in 4th ... if you're not going up hill and you stay on it. It takes a while, but I've hit 90 or 95 mph indicated in 4th (prone).
Shifted to 5th, saw about 110 mph indicated top speed.
190 lb. rider, light load, street tires, NO wind, Stock carb (jetted), open air box, stock exhaust.
Watch that front end weave at that speed. Gentle grip.
Times are GMT -7.   It's 06:15 AM.
