Old 05-14-2012, 05:22 PM   #64291
notarat
notarat's Avatar
Oddometer: 349
Originally Posted by epix1718 View Post
What are you guys doing to reduce handlebar vibrations?
I recently switched to the Fly Aluma-Steel 7/8" bars and vibrations get a bit strong. I want to stay with 7/8" bars as I already have the HDB Clamps for them.. Did purchase just a moment ago the Vibranator (www.vibranator.com), are there any other things I could use as well? Do they make rubber pads for the bar mounts?
I'm re-using my stock bar end weights on the aftermarket bars. I drilled them out to accept the larger diameter bolts that are used by the bark busters.
That is, as soon as I can locate a longer bolt that secures the bark busters.
notarat is offline   Reply With Quote
Old 05-14-2012, 05:30 PM   #64292
Olas
the darkness
Olas's Avatar
Oddometer: 4,064
Here's some nice, USA made, anti-vibration inserts:
http://www.highwaydirtbikes.com/HDB_...f=Th_insert_av
Aluminum bars vibrate much less than steel does also...
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 05-14-2012, 06:06 PM   #64293
jungleplant
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
channel locks go the other way to cinch when slip occurs , but you might know that and want it to slip
www.manracks.com
jungleplant is offline   Reply With Quote
Old 05-14-2012, 06:30 PM   #64294
sagebrushocean
Harris's hawker
sagebrushocean's Avatar
Oddometer: 180
Originally Posted by Tech23 View Post
How is that R6 throttle tube working out? I've wanted a quick turn throttle for my DR but I've read mixed reviews on how that R6 tube fits and functions with some experiencing sticking (idle stop) issues.
Tech23
I got one (5SL-26240-01) from ronayers.com, 2006 Yamaha R6 (with a matching left grip). I didn't have any of the fitment problems that others have reported -- it was plug 'n play. Just had to adjust the throttle pull cable to its maximum length. It's a very worthwhile, cost-effective modification for a street-ridden DR.
2008 DR650SE supermoto
2009 CRF230M
sagebrushocean is online now   Reply With Quote
Old 05-14-2012, 07:43 PM   #64295
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,229
Too Much Pressure
Originally Posted by Mambo Dave View Post
Anything wrong with 30 or the max 33 psi in the rear to keep the rubber cool? Heat kills out tires down here in the summer time.
Found on several bikes in the barn that when you run a little too much pressure in the tires, the front cups quicker and the rear gets a nice flat spot down the middle much sooner. Figured out that it doesn't help to have too much pressure.
Just start at what Suzuki says and raise ONE TIRE about 2 psi and ride a while to see if you like it. If that helps, do the other tire up 2 psi and ride. That's how it's done for me. I carry the bicycle pump and air gauge all the time.
Dave
smilin jack is offline   Reply With Quote
Old 05-14-2012, 08:57 PM   #64296
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
Dave
I'm going to agree with you on that front tire observation - but my experience was after running a front tire low (like, at 18 psi) on a streetbike for a good while, then finally checking the pressure and upping it... so i wasn't sure if that was what caused the cupping.
Thanks guys, I am probably headed 174 miles north to buy my first DR650 in about 14 hours here... I will remember the input your guys gave and not over-pressure the tires.
I'm nervous about it because it certainly isn't a set-up bike like all the recent DR's that have been sold through the ADVrider Flea market recently (so I'm looking at investing more money into it for suspension, seat, bars, luggage of some sort, chain sprockets, tires, etc.), but it is mechanic-owned, a 2002, and the whole reason he owns the bike is because the previous owner gave up on it after the base gasket leaked badly after an overfill of oil... so it purportedly has the new-style metal-like base gasket on it. I hope to get the bike for under $2800 or so... aftermarket exhaust, jetted, and that's about all of the mods I think.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave screwed with this post 05-14-2012 at 09:04 PM
Mambo Dave is online now   Reply With Quote
Old 05-14-2012, 09:28 PM   #64297
Tech23
Tech23's Avatar
Oddometer: 470
Thanks sage, If you let the throttle snap back under it's own spring pressure it doesn't want to stick at idle? I sometimes wonder what was done to cause the malfunction during the install. Some have reported a difference in the two throttle tubes and some have found grinding on it necessary. I can't seem to get any clear cut answers. Wouldn't happen to have any pictures comparing the stock DR throttle tube to the R6 tube would you? I suppose the part is only available with the grip already mounted to the tube. Is the R6 grip is glued on, I would rather mount my Pro grips to the new throttle tube. I would be nice if Pro Cycle would offer a plastic version of their (aluminum) quick turn throttle specifically for the DR 650. Does the R6 part have flanges molded into the tube at each end for grip retention like the stock DR tube?
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 05-14-2012, 09:44 PM   #64298
Tech23
Tech23's Avatar
Oddometer: 470
Originally Posted by BergDonk View Post
A story from a good mate who does among other things, suspension setup professionally. He was working for the Yamaha Aus road race team a few years ago, doing suspension and rider 'coaching'. Must have been about Jan/Feb 2006 when the then new Yam R6 came into their hands and they were at Eastern Creek testing in preparation for the season.
He had previously installed, among other things, the latest Ohlins fork kit to suit and was amazed that the single bolt bottom triple clamp was specced by Ohlins at 10 nm. 16nm is stock, which isn't a lot, and 10 is not much more than finger tight. He confirmed with Ohlins in Sweden that it wasn't a typo.
For safety sake, and for intial testing, he set the torque at 16 nm. His riders came in to the pits and the main feedback was that they weren't getting enough feel from the front end. We're talking national championship podium level riders, so they are fast, and know what they need.
The bikes were wheeled to the garage and the only changes made were to reduce the torque settings on the bottom triple clamp. The riders were not told what was changed each time, just go and have another go. 16-14-12 and when they went from 12 to 10, the Ohlins spec, the riders were happy, as were the crews. They were suddenly on or below lap record pace bringing the lap times down 3/4 secs and could feel the front end.
2 nm and nothing else, no clickers, nothing else!
Bike setup can be tricky, just ask Vale and JB.
Steve
Interesting Steve thanks, These were inverted forks I'm sure...I could see improper (over) torque binding things up for sure. From what I've gathered over the years is the major difference between a race bike and production bikes (besides exotic materials) is closer tolerances.
Over the years in the auto industry I have seen product recalls for nothing more than checking or changing a specific torque value for a specific fastener.
Tech23
Old 05-14-2012, 09:54 PM   #64299
BergDonk
BergDonk's Avatar
Oddometer: 3,809
Tech23
Yep, USDs.
Its common to see USDs over tightened, Blue torque as noted previously, or BFT (Bloody F**** Tight) and that of course crushes the outer tube and if nothing else, results in a tight spot when the inner tube bush goes past and puts a 'spike' in the fork's travel. It also helps to have all the threads clean and lubed to get accurate torque settings, especially for low torques.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 05-14-2012, 09:56 PM   #64300
notarat
notarat's Avatar
Oddometer: 349
I figured if the bit seized in the drilling process the slippage would save my wrist from snapping.
Old 05-14-2012, 10:10 PM   #64301
Rainier_runner
Epic Adventurer
Rainier_runner's Avatar
Oddometer: 312
Yep, USDs.
Steve
So this being said, what would be the torque spec for the triple clamps on my '03 Rm 125 forks I swapped out onto my 650? I can't say that they're not currently blue torqued with a short wrench. Which I'm guessing is extremely incorrect after all the previous posts.
2014 KTM 1190 Adventure R
2006 Suzuki DR 650 ADV
Rainier_runner is online now   Reply With Quote
Old 05-14-2012, 10:16 PM   #64302
Tech23
Tech23's Avatar
Oddometer: 470
Yep, USDs.
Steve
Yep clean threads a dab of anti seize compound or oil (where a locking agent is not preferable) and a good torque wrench, besides giving a more accurate and uniform torque, it can mean the difference between a pleasant disassembly or a fight.
You bet it pinches the tubes...I learned that at a very early age. First time I went to remove a fork cap on an old Kawasaki G5 enduro....I fought to remove the cap with the top triple clamp still tightened down...LOL, live and learn.
Tech23
Old 05-14-2012, 10:25 PM   #64303
Tech23
Tech23's Avatar
Oddometer: 470
I would think the torque spec in the factory RM service manual would be applicable. Don't know what that spec might be but that should be the basis for your search. When you get the correct torque spec write it down somewhere like in your DR service manual under front suspension or somewhere in your owners manual.
I used to write the torque specs of all the common fasteners on a piece of making tape and place it inside my torque wrench carrying case.
Tech23
Old 05-14-2012, 10:57 PM   #64304
ER70S-2
ER70S-2's Avatar
Oddometer: 6,935
Why do I keep finding these posts at bedtime?
Tech23
Throttle stops. This matters because the stops in the stock alum housing are on the outside diameter of the throttle tube. The smaller diameter R6 tube has slid past the stop under a high load (throttle off, landing from a bad jump for instance). Once that's happened, it easier for following hits to pass the stop. So far, so good for me; but I don't do airtime on the DR. Since it's slipping past the stop in the 'throttle off' direction, I'm guessing that you just force it back to the correct 'throttle off' position. I hope.
The difference between the outside diameter of the stock DR and the Yamaha.
I couldn't adjust the cables to get full throttle, I had to 'relocate' the WFO corner. I don't recommend a chisel, that plastic is really hard. I'm lucky it snapped where I wanted. The red arrow shows the oblong hole on mine, I don't know if they're all like that or mine was defective; anyone??
Motodeficient mentioned another Yamie part number in post 64321 on May 11th. I'll be curious to hear his feedback.
obtw: I'm still running the stock R6 grip on the right and the stock DR grip on the left. The only time I notice it is in the garage. The R6 grip looks like it could be slippery if wet.
Sorry, couldn't help myself.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 05-15-2012, 01:45 AM   #64305
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
Originally Posted by FatChance View Post
It gets real miserable here in the summer. Sometimes it gets to almost 90 degrees and the humidity can climb to 10%.
LOL, I just read this.
Yeah, I hate you, too.
their motorcycles
RyanR
Times are GMT -7.   It's 01:49 PM.
