Old 05-22-2012, 10:52 PM   #64726
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by sagedrifter View Post
I would not ride a bike in Miami, too dangerous. My life has enough value to find a car to drive in that crap hole. That said, 80/90 mph will get you in trouble on a DR650, totally wrong for that speed. Can't get out of the way at 80.
A couple times coming home from Miami at 4 or 5am on a Friday night
(movie business work long/weird hours) we'd see running gun battles on the Freeway and get passed by guys going like 120 mph. On those occasions I was driving with a friend. Scared the shit out of us. YOU COULD HEAR THE GUN SHOTS. ... not a cop in sight! It's funny now ... I hope things have calmed down.
Old 05-22-2012, 10:55 PM   #64727
Deadbeat Lebowski
Canuck
Deadbeat Lebowski's Avatar
Oddometer: 35
Originally Posted by ER70S-2 View Post
Somewhere about 60,000 posts ago this was brought up. You shouldn't have any trouble finding it. Seems the solution was a ZX1200 (1300, 1400??) motor mount bolt. That's all I can remember.
G'nite.
Thank you.
Far out.
Deadbeat Lebowski is offline   Reply With Quote
Old 05-23-2012, 02:36 AM   #64728
Bob808
Oddometer: 46
Cry
Originally Posted by jessepitt View Post
Looks like the valves contacted the piston at some point. How do they look. Also it looks like something else hard got in there to cause those dings in the side of the piston. Pic of the cylender and head?
Here are some pictures of the cylinder and head. I found one scratch that I can barely feel with my fingernail, the rest seem like stains or very fine scratches. Can't feel them at all. The longer one is the one that I'm talking about. Is that too much damage that I can't really use it like this? Bike has 30.000 km. I was thinking to put it back in and ride it for another 10.000 then change it. Thing is that I don't know of any good shops in my country that could repair the cylinder and to send it abroad would cost too much.
Bob808 is offline   Reply With Quote
Old 05-23-2012, 02:42 AM   #64729
Thumper Dan
Oddometer: 328
oxford grips question
Hi all,
I just bought a set of Oxford grips and my question is: if I put them onto my current bars, will I be able to get them back off when I order a new set of bars later on (several months away)??
The kit comes with super glue but I don't want to obviously destroy the heater grips to remove when I get new bars. Even without using glue, I need them to come off without damage!
thanks heaps.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan screwed with this post 05-23-2012 at 03:07 AM
Thumper Dan is offline   Reply With Quote
Old 05-23-2012, 03:09 AM   #64730
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,384
If the choices are that limited stick it back together.
What does the piston look like where that scratch is in the cylinder.
One thing I noticed is the DR must have a big squish measurement.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 05-23-2012, 05:05 AM   #64731
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,753
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is online now   Reply With Quote
Old 05-23-2012, 05:08 AM   #64732
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Originally Posted by Olas View Post
Also, I've read that 10W rear shock oil is an improvement for riders that want to ride a little on the aggressive side and that it may be to harsh for regular road/dirt road conditions. True? This is with the stock valving.
I'd say that's way false. Even with a Race Tech gold valve installed, the Race Tech set up called for light (3 WT) oil on my shock. I seriously doubt the stock valving could even begin to handle heavy oil.
Old 05-23-2012, 05:21 AM   #64733
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
I know a lot of you DR guys think I should ge ta street bike, but I'll try to keep running this one (I just sold my larger street bike yesterday). As I wrote earlier, I really don't believe that the 90 to 95 MPH my speedo reads is really what I'm doing. At that speed I still have plenty of power to speed up to over an indicated 100, so this speedo is just way off if you are saying it doesn't have passing power past 85. I would say 80 to 85 is my real cruising speed. (Plan is to put a taller rear tire on, and a 16 tooth sprocket, by the end of this week - that should lower the RPMs a bit.) I am thinking about getting a steering damper for the twitchiness at those speeds, but I'll try new tires first. It really isn't bad enough that I'd slow down for it, but it seems like it would go into a tank-slapped if I fucked up enough.
So far body panels, the rear fender top-bolt, and the chain-guard are what I've found loose. Got lucky with the rear fender bolt since it somehow came all the way out, but stayed on the bike for +30 miles. It's obvious bolts were falling out for the previous owner, too, as there is a make-shift replacement on an exhaust cover that I can only assume fell out. I've only had the bike a few days, so while I can't say critical bolts are loose yet, if the few areas I have inspected or fooled around with are any indication then I'm going to have a lot loose.
Originally Posted by Mongle View Post
When I was doing track days with the GSXR I used one of these for safty wire. Bikemaster drill guide:
Thanks Mongle, that top adjustable jig is just what I'm looking for. I should probably buy both for the allen-bolts that have round heads though.
And Harbor Freight has safety-wire pliers for cheap, so no big deal there. I don't need a professional set that resets itself since I'm not doing an entire aircraft.
I'll be doing a mix of Loctite and safety wire on the bike as I see fit. I understand the concept of how to safety wire (i.e. wiring to keep things tight), so it's not as if it would be pissing in the wind.
I ride north, instead of to Miami. My experience shows these commutes are much faster than those who ride from here, south, into the snarled traffic heading to the big city. Yeah, speeds are still high going south sometimes... and I-595 might as well be a NASCAR track going west in the mornings - actual bumper-to bumper traffic doing 80 or 83 MPH (measured with a car back when I used to do that route - you wouldn't catch me alive on the DR, or any bike, on that route at those times).
I love hearing about how Florida used to be (even crazier) back in the day - thanks for the stories guys. It's still sort of a third-world country, so ...
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave screwed with this post 05-23-2012 at 05:29 AM
Mambo Dave is offline   Reply With Quote
Old 05-23-2012, 05:24 AM   #64734
Motodeficient
Oddometer: 448
Yeah, I think you REALLY need a 16t countersprocket.
Motodeficient is offline   Reply With Quote
Old 05-23-2012, 05:32 AM   #64735
thinairflyer
Oddometer: 161
Old guys
My buddy who also rides a DR650 is 75, so a lot of you guys have many years of riding left I expect! :-) He outrides me (I had Polio when young so don't have much stamina for the rough stuff anymore but he does) He's a tough old guy! LOL!
I mostly just ride gravel roads now.
I'll bet there a quite a few older than my buddy and me.
How about it? Old guys speak up!
L D 'Thinairflyer'
Originally Posted by thinairflyer
A few months ago I ordered the Seat Concepts seat kit for my '02 DR650 and asked for the foam to be a little softer than standard as I only weigh 130 lbs. and am 72 years old so my old rear end is not as tough as it once was.... and I ride some pretty long rides on the DR.
ER70S-2 noted:
72 and still riding a DR!! I have another 8 years. I'm learning about that skinny ole butt syndrome, a 1/4" of body tissue between my pelvis and the 'very firm' Corbin.
thinairflyer is offline   Reply With Quote
Old 05-23-2012, 06:25 AM   #64736
sander
sander's Avatar
Oddometer: 325
The 10W oil makes a great difference. It stops the rear pogo ing up after a bump. I found it not to hard at all.
sander is offline   Reply With Quote
Old 05-23-2012, 06:53 AM   #64737
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
I guess you could put new rings on and have the cyinder honed. My only concern would be blowby into the crank case putting too much contaminates into the oil. I think they make a special hone for the nikasil as it is very hard.
jessepitt is offline   Reply With Quote
Old 05-23-2012, 07:15 AM   #64738
procycle
procycle's Avatar
Oddometer: 2,407
+1
It's not on par with a proper revalve but changing out the stock shock oil for 10w does make a significant improvement.
A proper revalve of the shock will be designed around using light oil to minimize fade due to loss of viscosity from heat.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 05-23-2012, 07:23 AM   #64739
Go Irish75
Go Irish75's Avatar
Oddometer: 363
Originally Posted by Mr DR650 (2011) View Post
Hi all,
thanks heaps.
I have wondered the same thing. I just went ahead and installed with the supplied "super glue". With alot of patience and gentle prying and probably compressed air, you should be able to break the bond to get them off. That throttle side is gonna be a pain to get off, and as with most throttle DR grip issues, just order up a new throttle tube cause I have a feeling it's gonna be destroyed upon removal, being plastic and all. Oh, and FYI, the aftermarket billet Moose throttle tubes that Pro Cycle sells will NOT work with Oxford Heaterz. The tube is way to big in diameter. For regular rubbery and more pliable grips this wouldn't be a big deal, but the Oxford grips are not flexible or expandable enough. Plus the billet throttle tube is knurled, so it makes it even more impossible for a smooth slide on application, especially due to the tight tolerances. Ask me how I now.
Here's my signature
Go Irish75 is offline   Reply With Quote
Old 05-23-2012, 08:05 AM   #64740
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,527
The hair drier is an un-sung hero: peals stickers, softens cold rubber, dries drywall mud quickly etc. I am always finding new uses for it, I've even heard some people use it to dry their hair!
Yeah, I have one in the tool box and have used it for a lot of jobs, especially removing stickers and glue, but softening the carb boot escaped my thinking.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Times are GMT -7.   It's 03:21 PM.
