06-06-2012, 05:01 PM
#65671 | |
Buell me
Oddometer: 2,023
with my pampered DR roadie. ![]() 996DL |
#65672 | |
Oddometer: 1,066
06-06-2012, 05:37 PM
#65673 |
Oddometer: 1,642
OPIUM89...Brake lever, my son also has a DR650. He rode mine and liked it so much, he got one also. He didn't like
the brake lever, and I was in Seattle and went by TOURATECK and got one of their bolt on brake lever extensions. He likes that it adds about 3/4 of an inch to the outside of the brake lever. I believe it was for a BMW R 1200 GS. When I say, "I believe" that means I don't really know, and he doesn't I either. |
06-06-2012, 06:49 PM
#65674 | |
Oddometer: 1,144
There must be some different setups depending on region the DR is sold in. I know there are needle and jetting changes, but I suspect it goes deeper than that. I bought a second hand DR carb from the US and it had some major differences, which may just point to the seller not knowing what year model it came off. Buyer beware. My trail version of the DR has the best idle, return to idle, and pick up of any DR I've seen. It took about 20 comprehensive test runs and fiddling to get it there. I only got there because I ignored "advice". Not to say I don't appreciate the advice and contributions, they are generally well meant. But sometimes you need to rethink things and look outside the box. The traditional stalling off idle is caused by too rich idle and fuel puddling in front of the butterfly. The stall occurs as you OPEN the throttle, not as it closes. I experimented extensively with this. Leaning makes it much worse. I fixed it on one DR accidentally, and now I'm struggling to replicate it. The vacuum port filter is one of the usual suspects and something I'd forgotten completely about. I replaced it with a washable K&N filter on my trail version to eliminate it as a suspect very early on. So with my 2nd DR I've probably chased the problem in a circle. I'll change the vacuum filter and see how it goes. Thanks. Sometimes "radical" tuning needs a traditional conservative and systematic approach to problem solving. Sometimes you just forget a step, or jump too far ahead. |
06-06-2012, 06:57 PM
#65675 | |
Oddometer: 1,144
40,000kms on it. The last 20,000 has been pure trail riding. Never adjusted the valves. Checked them twice. Now I just listen to it when cold....valve clearance noise...it's ok. I haven't modified anything in the engine. It's never had any mechanical issue. Never touched the clutch, and I work the daylights out of it. Every now and then a large rock lets some of the oil out. Change the oil and filters when you replace the cover. Off you go. The ultimate trail bike. |
06-06-2012, 07:37 PM
#65676 |
UberNoob
Oddometer: 72
32mm open end is right so that narrows it down to 46mm on the Honda and 38mm for the Kaw on the ring nut size. The Yam open end is 30mm so that leaves that out. I think the DR ring nut is around 42mm so the answer is not exactly.
Sorry for being a smart ass.
My Smugmug, it's how I roll. |
06-06-2012, 08:06 PM
#65677 | |
Oddometer: 1,134
http://www.motosport.com/dirtbike/HP...TEM-NUT-WRENCH It's rather inexpensive too =)
Tea parties are for little girls with imaginary friends. |
06-06-2012, 08:34 PM
#65678 | |
BornAgainDirtyRider
Oddometer: 233
Your right none in your state, the states are small back there though so? Good Luck
Socialism Tax dollars at work for those who dont |
06-06-2012, 09:45 PM
#65679 |
ADV in training
Oddometer: 610
Procycle Supermoto Tires
So I was looking into doing a supermoto conversion, and sending my hubs to Procycle seemed like the cheapest way to do it (assuming I couldn't find the wheels second hand elsewhere). However, when I was looking at the tire sizes on the 17" Excel rims and converted that to metric, I could barely find any tires that would fit those rims. According to motorcycle-superstore, the only tires they have that fit a 3.5" wide 17" rim is a single Avon tire. I thought that half the point of going with supermoto tires is that it allows you to run regular street/sport bike tires. Am I looking at an incorrect tire size chart (using the WebBikeWorld one currently), or are the Excel rims not the right ones to get. Just looking at street tires that fit my stock DR650 rims seems to produce more options on almost every site I've checked. For anyone out there that's done the supermoto conversion, I'd love to know what rims you're using, what size they are, and what tires you run on there. Since I don't hardly do any real dirt riding with my 650, putting longer lasting and better handling road tires on it seems like a step in the right direction.
_________________________ Ride videos '01 DR650 "The impossible often has a kind of integrity which the merely improbable lacks." |
06-06-2012, 10:14 PM
#65680 | |
Oddometer: 418
Tech23
CRF 150/230/ Supermoto Conversion 2004 Suzuki DR 650SM 2000 Harley Davidson FXDWG |
06-06-2012, 10:22 PM
#65681 | |
Taumarunui..Darwin..
Oddometer: 2,110
A 150/70/17 rear as Tech23 says is the usual tyre for a 4.25 inch rear rim. I have been running Michelin pilot road 2's for some time which are a good all rounder,the new 3's may be even better. They are also OK off road if it is dry.
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780. |
06-06-2012, 10:50 PM
#65682 | |
Oddometer: 418
Tech23
06-06-2012, 11:06 PM
#65683 |
Oddometer: 2,110
Yes,but before the RMZ450 forks so 2010 or earlier.
I liked the steering better with the shorter DR forks over the longer RMZ items. There will be a few pics in here somewhere.... fwiw if anything. http://s30.photobucket.com/albums/c345/manurewa/
06-06-2012, 11:19 PM
#65684 |
Oddometer: 1,144
The disadvantage of MotoX forks is they are longer. Not much good for the vertically challenged. Makes the steering angle super slow.
On my trail DR I fixed this by cutting off the standard rear end and starting from scratch with a book on frame design and having measured up the donor bike (RMZ450). So it sits high in the rear now, with about 340mm of rear travel...about 295mm front. The first thing I noticed on my 2nd DR with an RM front end and the Racetech/DR rear end is that it steers like I'm riding a cruiser. Once under hard brakes it feels better. But I have it sprung for a load that isn't on it at the moment (I planned for a 30 litre tank, and tank bags etc). It does feel rock solid on the highway, where the trail version rides like a trail bike on the highway. On the 2nd DR I dropped the triple clamps on the fork tubes by 20mm, and set the preload harder to lift the rear. It's very firm, I'm running the old Scorpions off my BMW (150/70-17 rear and a 90/90-21 front) and it sticks like shit to a blanket. Having super firm suspension and sticky tyres is so much fun. I love it as an around town bike. I'm going to build a motard front and rear wheel for it, and run some motard brakes. It'll shame the sports bikes around here easy then. Nothing upsets a sportsbike rider more than a DR going around them in the twisties. You can actually see the steam coming from their helmets. |
06-06-2012, 11:35 PM
#65685 | |
Oddometer: 418
![]() Tech23
