Old 06-22-2012, 02:27 PM   #66226
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,385
been REAL happy with NGK iridium plugs over the copper version.
bike runs better & starts easier.
http://www.procycle.us/bikepages/dr650.html#engine
Originally Posted by Rusty Rocket View Post
1 - It's time for new plugs. Do I go with the "standard" plug - CR10E or replace the CR9E plugs that are currently in the motor (I don't know why one of the previous owners went with the "hotter" plug)?
2 - Since the motor hasn't run in ~9 months, should I shoot a little WD40 into the cylinder, thru the spark plug holes, so as to provide the rings with some lubrication?
3 - Should I "spin up" some oil pressure, with the plugs out, to get oil circulating thru the motor before attempting to fire it up (I used to do this with my auto race engines after a rebuild - the DR's motor was
not rebuilt/dis-assembled. It's just been sitting)?
Numbers 2 & 3 are good ideas. You should use a couple drops of gearbox oil instead of wd 40 IMO.
as to item 1, one number in heat range on a plug can reall hurt anything. leave it if you want, go back if you have the chance or ar gonna replace the plugs any way.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 06-22-2012, 03:50 PM   #66227
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
I called and talked ot the tech at NGK and he recommended upgrading to the iridium, but not using the dual electrode. I honestly can't remember why he said not to use them, but at the time he convinced me!
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 06-22-2012, 03:58 PM   #66228
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,385
Originally Posted by vfr870 View Post
For those that dont have access to machine tools, simply take an old clutch friction disc and an old clutch steel plate, drill through each one, nut & bolt it together, and now you have your very own clutch hub holding tool.
What stops the engine turning ?
That is a clutch basket to hub locking tool,you still need a arm off that to rest on the crank shaft snout to stop the clutch turning... fwiw.
These were old plates though with the socket accessible through the hole in the plate.
http://i30.photobucket.com/albums/c3...lutch/CLT8.jpg
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 06-22-2012, 04:41 PM   #66229
BergDonk
BergDonk's Avatar
Oddometer: 3,923
Originally Posted by bundy bruiser View Post
I already have lowering plates for the standard pegs, I saw the pro cycle ones.
I dont like the pivot pegs, any other ideas?
I use the Fastways on my DR and Berg. Useful ability to set them up high or low, and can be adjusted for 'camber' too. Nice pegs. Can get them here in Oz from Ballards.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 06-22-2012, 05:11 PM   #66230
johnkol
Oddometer: 136
Originally Posted by GaThumper View Post
Sorry for the late reply, been busy this week and just catching up.
Wow, GaThumper, that was a long note, filled with great information; I know it must have taken you considerable time and effort, so thank you for this, I really appreciate it!
I really enjoy the DR on twisty roads: the power is fine, the suspension behaves reasonably well (as long as there are no stutter bumps), and the tyres are predictable and stick quite well. What I don't enjoy with the DR is droning on flat, straight roads, and unfortunately for me, I have to be on such roads for more than 2 hours before I reach the curvy bits.
The stock seat is fine, I have spent 9 hours on it without any problems -- I could easily do multiple such days with no issues. Having said that, the narrower seat on my KTM is more enjoyable, so this is an additional advantage the EXC potentially has over the DR.
I agree, the right bike makes you feel like a hero. But more than that, it allows you to develop into a better rider. Trying to subdue an unruly bike is not my idea of fun, and not the way to acquire more skills. Once I experienced how big a role the bike plays, I became very uninterested in riding any motorcycle that did not click with me.
I looked at the Huskies you mention, but apart from the 610/630, they all come with very close-ratio transmissions, which severely limits their functionality on the road. As far as I can tell, the EXCs are the only bikes with a wide-ratio box appropriate for highway droning.
I also looked at the latest 250 offerings, and I was ambivalent about their horsepower, particularly for highway use. But you do have a point, that most of the comments about these bikes come from people that are a lot heavier than I am, and for people of my weight a 250 would be adequate.
Which brings me to another problem with the DR that I just realised: I have been setting sag using the well-known guidelines of 30%-35% of overall suspension travel, but these rules are for straight-rate (linear) springs, not progressive ones like on the DR. I presume for progressive springs the sag should be more, but I don't know how much more. Whatever it is though, I already cannot achieve the recommended sag values: at the lowest fork preload the race sag is only 70mm -- and I don't think that anyone makes a linear spring softer than the stock one.
One thing is certain: there's a lot of DR experimentation in my future.
Oh, one more observation for you. I HATE the DR650 on loose gravel.
Yes, loose gravel is what I encountered. I have been on similar roads for all my riding life and I never had a problem with them, but with the DR and the 705s it was an experience that I do not want to repeat -- the slides were not the controlled kind.
Thanks again!
johnkol is offline   Reply With Quote
Old 06-22-2012, 05:22 PM   #66231
N.dica
Oddometer: 109
TM40 resolution
Well the guys at Procycle have repaired my carb and it arrived today. I want to say thank you to them and I appreciate the fast turnaround. I think in all it took only a week for me to send it to them, for them to fix it, and then to receive it back. Sweet. Cheers fellas!
Now naturally I reinstalled it today and hit the road. THAT is what I was expecting to feel from this carb. I definitely wasn't getting a clear picture before. My engine temperatures are down, the jetting is perfect, minimal popping on decel, and wicked throttle response. As stated previously, my old carb was dialed in, and whereas I couldn't tell much difference between the BST and the TM40 before, now that the TM40 has the vacuum leak sorted I absolutely notice the difference. The responsiveness and smoothness is striking. Funny how such a small vacuum leak can throw the whole thing out of whack. Anyway Im stoked.
Still doing the big bore, but it is put off one more week as I just received my X40F0X from an Englishman over Ebay. I swear the thing is immaculate- it looks like it was never even used once. So between that and the jesse adapter kit I just ordered, the 790 will have to wait just a bit longer.
With all the money I have dumped into my bike there could easily be the argument made that I could have bought a KTM or whatever..... But Im happy I went this route. My DR kills it on the tarmac, and Ive taken her on some flat-out gnarly trails and shes devoured them. With the right mods, the performance offroad is superb, especially considering shes like a bat out of hell on the pavement as well. Shes completely customed out to my taste, and I could for the most part tear her apart and fix anything thats wrong myself. I like being able to depend on myself as mechanic when lost in the wilderness. Gives you a great deal of confidence. And above all, its just plain fun to tinker away in the garage. A great, albeit addictive and expensive hobby.
Cheers all, and thanks again to Drum, Carl, and all the guys at Procycle for being so damned professional:)
N.dica is offline   Reply With Quote
Old 06-22-2012, 05:46 PM   #66232
rutsthematter
rutsthematter's Avatar
Oddometer: 176
If you look in the Ballards catalogue (Page 41) they have footpeg wideners that you can weld on. I have some coming to try.
rutsthematter is offline   Reply With Quote
Old 06-22-2012, 05:49 PM   #66233
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,712
Looks like this might be a decent deal on a Safari tank if anyone's looking for one.
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 06-22-2012, 05:50 PM   #66234
GaThumper
Road Less Traveled
GaThumper's Avatar
Oddometer: 514
I haven't found a bike yet that I enjoy long straight roads on. The closest I come to enjoying them is on my Yamaha 1300cc V4 Venture with electronic cruise control, stereo, and full fairing! Around here I realize we are blessed with lot's of great motorcycle roads and the ability to avoid most interstates and other long straight drones with a little route planning.
As far as the dual sports, I can't imagine ANY of them being fun on long boring stretches of asphalt.
It's sounding like maybe a KTM 450exc would be a good bike for you to try, Maybe you could find someone locally to try one out and see. And I wonder how the new Yamaha WR250R might work for you? Seems to be a really popular new entry, but it weighs as much (or more( than the KTM!
Here's an early test I was just looking at. Of course, there are some good threads here to look at, too.
http://www.off-road.com/dirtbike/rev...50r-23644.html
Good Luck with your quest, and remember, enjoy the journey!
P.S. Not due 'till 2013, but check out the KTM Freeride 350. About 220 pounds and Very Interesting!
GaThumper screwed with this post 06-22-2012 at 05:58 PM
Old 06-22-2012, 07:02 PM   #66235
NorCal Jeff
Bold New Graphics!
NorCal Jeff's Avatar
Oddometer: 73
I installed the Iridiums..makes a big difference in the butt dyno..I recommend them..
one Bike to rule them all..
'06 DR 650
If it ain't broke...DON'T FIX IT!!!
NorCal Jeff is offline   Reply With Quote
Old 06-22-2012, 07:09 PM   #66236
bundy bruiser
Super Trucker
Oddometer: 6
footpegs
Thanks for all the replies regarding bigger footpegs.
Thanks for that link Cemony, I went with a set of those
bundy bruiser is offline   Reply With Quote
Old 06-22-2012, 07:35 PM   #66237
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,063
Place the trans in gear, use breaker bar or impact wrench on the nut.
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100
Lil' Steve is offline   Reply With Quote
Old 06-22-2012, 07:39 PM   #66238
Jon_PDX
Oddometer: 1,105
.......snip rest..........
That's great news.....thanks for posting the followup.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 06-22-2012, 08:09 PM   #66239
ADV8
ADV8's Avatar
Oddometer: 2,385
What was the point of bolting old clutch plates together then.
The whole point of locking the clutch hub is to avoid doing that to the transmission and making it easy to remove and refit/torque the nut.
Old 06-22-2012, 08:56 PM   #66240
Snowy
Snowy's Avatar
Oddometer: 1,983
If you have problems with the DR on fast deep gravel sweepers try this:
As you are braking to enter the turn, start trailing the front brake with one finger, enough to make the front squat a little on the springs, keep throttle held on as you do it so you don't actually bleed any speed, pick your line and turn while trailing the front very gently.
I find in deep loose gravel it helps make the front bite down into the gravel and that stops it wanting to understeer. The rear is pushing against a slight load, so it tends to not skate so much and gets better hook up and resists oversteer.
Use the wheel ruts that already exist. I quite often over shoot a loose corner and use the high dirt gutter ( if there is one) on the outside as a berm. Crossing from rut to rut with a high deep gravel center is fun. Ride it like sand, weight up, very slightly rear and grip with the knees, steer with the knees and hips.
I learned this while running D952 front and Mitas E09 rear, and can adapt it to any combo now.
Some dual sports tyres don't like it because they just don't have the knob depth and separation to bite down into the gravel, they just start to skate.
So right tyres for gravel is the first step.
Practice gently gently to start with. You aren't talking significant braking force, just one finger and enough pressure initially that you can feel the front starting to squat.
You have to have a very fine touch, but you will feel the difference. It stabilises the front end and helps to prevent sudden break away on the rear. A rear tyre like the E09 drives and brakes well in gravel but it skates sideways under very little load. So by loading it slightly in the drive direction it settles the sideways skate. A lot of MX tyres work similar. They skate sideways if you enter a corner under too little throttle. But enter the corner and drive it as hard as you can and they propel you forward. Come in under no throttle, or just an elevated idle and the back and is out from under you. They are designed to dig and drive, under no load they slide along the surface.
With the DR you are riding essentially a very big heavy trail bike. It has that classic trail bike geometry, and a lot of weight pushing it. So you have to start using the sort of techniques the pros use on smaller bikes just to get it to do the basics well.
But it will do it.
I've chased Bergdonk through the trees and he does it, I think, without knowing he's doing it. As most old timers like us will. You go through an evolutionary thing when you've grown up with the first dirt bikes and evolved alongside them. The DR is a case of de-evolution to an extent. Modern dirtbikes have been designed and built to NOT have the character traits the DR has. But they are designed for a completely different task, and then used out of context by the majority. They are modern single track race bikes. Part trials bike, part motoX, part scrambler.
The old timers that love and cherish the DR grew up with these traits. It's a part of us. Sometimes it's hard to understand why Suzuki doesn't bring it into the modern dirt bike age, and then you look at the base demographic and it's primarily guys who grew with bikes just like the DR in terms of off road handling. To us, it just "is". It makes sense despite the inadequacies.
It may be a 25 year old design, but it represents what a dirt bike used to represent..."do it all" freedom.
Master the DR and you will truly be free...for as long as that little bullet proof 649cc heart beats. Cherish her. You'll miss her when she's gone.
Snowy is online now   Reply With Quote
Times are GMT -7.   It's 06:25 PM.
