06-19-2012, 02:04 PM
#66256 | |
Knuckle dragger
Oddometer: 1,306
When we dyno our motors (V8 stuff) we make sure the engine is up to running temp BEFORE any type of pull. If the motor happens to cool down between pulls we go throught the warm up process again. We use warm up time to check things like: oil pressures, timing, fuel #s etc. so when it comes time to pull the trigger we are ready. We keep the motors in the 1500-2500 rpm range during initial warm up. Don't let it lug around on idle. Most of our engines idle in the 600-800 range so with a DR that idles at 1500 I would keep the bike in the 2000-2500 range on initial warm up. We don't work our way up on pull % once the motor is warm. If it is acting right and the fuel numbers are right we pull 100% on the first pull. Knock on wood- 20yrs dynoing motors and we haven't had a problem yet. |
06-19-2012, 02:07 PM
#66257 |
Oddometer: 116
That's precisely what I'm concluding -- and what I would like to avoid. I never had any delusions of the DR matching my 2T KTM; I was merely expecting to be able to cruise along fire roads at reduced speeds, but in relative comfort and tranquility. If I cannot relax in navigating these roads then there is no reason for me to carry on down this path: I might as well go back to trucking the KTM, or start shopping for a more dirt-oriented bike.
06-19-2012, 02:13 PM
#66258 | |
Old Traveler
Oddometer: 464
Yes! +1
TRAVELGUY DL1000 '05 black DL 650 '07 ( lives in Costa Rica ) DR 650 "08 .
06-19-2012, 02:16 PM
#66259 | |
Oddometer: 3
92 or 98
92 = $1,300 repack the muffler, screw around with the carb and jetting, replace the worn out knobbies with a decent set of 80/20 tires, replace the signals, add a mirror and I am probably close to $1,800 - if I have to replace the pipe $2,000 98 for $2,200 and I add a $200 gear from kleintech (may not need to do it right away) and have a 6 year newer bike with half the miles and I get a bonus magic starter button and don't have to worry about kicking my brains out every morning (or when I stall at a light). Plan on using mostly as a commuter but have a bunch of land in upstate PA that I would like to ride and also ride to (180 mile one way trip half highway, half two lane back roads). |
06-19-2012, 02:24 PM
#66260 |
Oddometer: 60
Don't know if anyone have an answer for this but here we go.
I've found a cheap nearly unused Öhlins front fork with crowns and all for a Honda CRF 150. Would that be functional on a DR or is it to weak for the DR's weight? |
06-19-2012, 02:31 PM
#66261 | |
Oddometer: 608
Pre 96 or newer choice
I have found parts are not easy to come by for my pre-96, it weighs a ton, kick starting is easy if it is willing to start but if there is a problem it gets old real fast. There are those who really like the early DR's but I am not one. Check the pre 96 DR650 thread here in ADV and post the same question there if you have not already. I bought an 02 and it is so much better in every aspect. So much in fact that I now have two of them. ![]() Everything on the '96 up to current is compatible, parts are available everywhere and are reasonably priced. The suspension, such as it is, is better too and easy to improve. The magic button is wonderful and the modifying options are unlimited.
Attitude ~ The difference between Ordeal and Adventure James |
06-19-2012, 04:48 PM
#66262 | |
Oddometer: 1,169
doug s. |
#66263 | |||
Oddometer: 116
Oddly enough, the forks were not that objectionable -- but maybe that was because the rear was mis-behaving so badly that the front's behaviour paled in comparison. Quote:
I suspect a bit of too much preload on the rear does not help (I set it to match the front, which means it's not as soft as it should be), but the primary culprit is too much compression damping and almost no rebound damping. Unfortunately, compression damping is set at just 4 turns from full soft, and setting it at zero or 2 turns made the bike wallow on longer wavelength bumps on the road. And of course rebound damping is not adjustable -- what an inspired choice Suzuki made! The conclusion is that there's not much I can do with the shock as it is right now; the only solution is to either get a new one or rebuilt the stock, but this is not cheap as you attest -- which means that one needs to commit to the bike first, and I'm not at that point yet. Quote:
Too far away?? Why, it's only 2700 miles! Isn't the DR an adventure bike after all?
06-19-2012, 04:57 PM
#66264 | |
Oddometer: 1,169
http://www.advrider.com/forums/showthread.php?t=796934 personally, i cannot understand why this is still f/s... doug s. |
06-19-2012, 05:00 PM
#66265 | ||
MacGyver
Oddometer: 1,972
Anakees and Scorpions are both great tires for doing mostly asphalt duty, but if you want to save some coin, then look at the Shinko 705. A very good tire that will last for many miles, and very good in the rain. They'll handle light gravel roads, too.
_______________ "You can't put the shit back in the donkey." - Tony Soprano FYYFF
06-19-2012, 05:06 PM
#66266 | |
Oddometer: 1,169
the corwettes were broken-in in a similar fashion, after we had rebuilt them and installed twin-turbos.... doug s. |
06-19-2012, 05:24 PM
#66267 |
Oddometer: 533
Anyone have the IMS tank? I bought a used one with no hardware.. does it use the 2 stock fuel tank mounting bolt to attach to the frame?
97 Suzuki DR650 97 Ural Sportsman 2WD 98 Honda XR250R 85 Yamaha BIG Wheel 200 www.drriders.com |
06-19-2012, 05:37 PM
#66268 |
Oddometer: 664
Yes and the rubber bumpers on them too.
Excellent, our country is now run by folks that would allow you to smoke pot in Washington State, but not buy a Big-Gulp in New York. 10 State Trip 2010 2011, $1000 in the pocket, how far can we go |
06-19-2012, 06:18 PM
#66269 |
Procrastinators
Oddometer: 5,817
But not the same rubbers and bolts as the stock tank, at least not in my case. They are rubber bumpers which fit only on top of the rear tank mounts.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
06-19-2012, 07:14 PM
#66270 |
almost gnarly
Oddometer: 1,473
Mine does not use the stock mounts. It came with different rubber mounts and bolts.
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
