Old 06-27-2012, 12:22 PM   #66421
opium89
opium89's Avatar
Oddometer: 1,136
Originally Posted by cabinfever View Post
That was my thought on the washer, too... to keep the spring from catching on the spacer. The emulator instructions specifically says to put the spring directly on top of the emulator, so no washer there. And I didn't see a need for a washer on top of the spacer. I will more than like leave things as they are unless someone comes along and says I am headed for a horrible, fiery crash if I don't have a washer on top of the spacer.
You are headed for a horrible, fiery crash.
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Old 06-27-2012, 12:28 PM   #66422
cabinfever
cabinfever's Avatar
Oddometer: 65
And with that... off to the hardware store I go!
Chris
cabinfever is offline   Reply With Quote
Old 06-27-2012, 12:43 PM   #66423
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,842
Anyone have any opinions on the MSR or Quadboss kits for the steering stem or wheel bearings? The dealer here offered them for about half the price of the OEM stuff, just wondering if the quality is reputable.
Whatever you order, make sure it includes the seal/dust covers for the top and bottom. I bought from ProCycle and their kit has the seals.
Emmbeedee screwed with this post 06-27-2012 at 01:20 PM
Emmbeedee is online now   Reply With Quote
Old 06-27-2012, 02:05 PM   #66424
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
What is the story of that rider who looks like he's about to hit the fire-bike? Did he somehow make it, or did he hit it?
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 06-27-2012, 03:22 PM   #66425
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
I've had pretty great success with the All Balls bearings. The steering bearings in my dr are those and I put a set in the sprocket carrier that have held up longer than the oem jobs ( likely because they are double sealed ).
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 06-27-2012, 04:23 PM   #66426
40cu.in.of.furey
40cu.in.of.furey's Avatar
Oddometer: 224
If the rear wheel of the DR350 has a cush drive hub, than yes it will fit your 650, all you have to do is flip the brake disk of the 650 and use all the 650 spacers, I'm not sure about the front wheel.
Originally Posted by bouldertag View Post
Does anyone know if I can fit on my 2008 DR650se front and rear wheels from a 1994 Suzuki Dr350s?
Boulder
07 DR650SE w/ FCR MX carb
01 Honda VFR800FI
73 Honda SL125
40cu.in.of.furey is offline   Reply With Quote
Old 06-27-2012, 04:30 PM   #66427
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,799
Originally Posted by Tech23 View Post
...You might not be using the tread all the way to the sidewall on a more street oriented tire...if that kind of thing is important to you. It also looks like your running a 70 aspect ratio rear tire.....I don't do track days so the so called "chicken strips" are meaningless to me. ...Tech23
haha, same 'ol Tech23! nice to see you made it to the ADV forum. and yes, the street tires i'm ordering will definitely be used all the way to the edge of the sidewall. :P
that rear is a 140/80, that's the only Distanzia with the DS compound and was the reason for the mileage report. just in case some others are interested.
overall, pretty good tire. they get a little squirmy after i've been pushing them hard for several miles. it's probably just my fatass.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 06-27-2012, 05:29 PM   #66428
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,842
"This shot of World Superbike legend Noriyuki Haga riding through the flames on his BSB debut must rank as one of the most dramatic motorcycle racing pictures ever."
http://www.crash.net/british+superbi...all_print.html
Old 06-27-2012, 05:42 PM   #66429
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
Thank you!
their motorcycles
RyanR
Old 06-27-2012, 07:51 PM   #66430
Tech23
Tech23's Avatar
Oddometer: 470
Nice to see you over here too vintagespeed! Hope all is well.
That was real good mileage out of a dual sport compound tire. Have you decided on what street tires you are going to mount? There are a lot of good street tread options. I think you'll like the more flex free lower profile rear tire especially if you want to push the outer edges of the tread surface. I'd go with a 150/60-17. It might give more road feedback/feel, but it'll be a magnet in the corners.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 06-27-2012, 09:32 PM   #66431
bouldertag
WannabenarlyADV'rrrr
bouldertag's Avatar
Oddometer: 460
Thanks I will check for the cush drive hub.
Burn out dont fade away!!
bouldertag is offline   Reply With Quote
Old 06-27-2012, 09:49 PM   #66432
Phreaky Phil
Oddometer: 1,885
Originally Posted by notarat View Post
BB is competitive on certain parts. Not so much on others. Do some comparison shopping.
Try Part Shark out. Ive ordered from them a couple of times with no problems. They show you the normal price and there price so you can compare. http://www.partshark.com/default.asp
Phreaky Phil is offline   Reply With Quote
Old 06-28-2012, 04:54 AM   #66433
Motodeficient
Oddometer: 448
The cheapest I have found for OEM parts so far is
www.powesportsplus.com
Their shipping rates are good too. And free shipping over $250.
5% coupon code "meetsister" should still work.
Motodeficient is offline   Reply With Quote
Old 06-28-2012, 05:56 AM   #66434
notarat
notarat's Avatar
Oddometer: 349
Nice site. Thanks for the link!
When I was restoring my '98 YZ250, I was looking for a new crank and the complete front and rear caliper assemblies and found that BB and DGY were crazy expensive. I tried Service Honda for some reason and found they carried Yamaha parts too. I was able to get the complete crank assembly for $300 less than BB or DGY. The caliper assemblies were also $200 cheaper than DGY or BB.
Looks like they carry Suzuki parts as well for up to 2008. (so they'll fit the 98-12)
I would also give them a look-see if you're hunting for a hard to find OEM part.
notarat is offline   Reply With Quote
Old 06-28-2012, 08:57 AM   #66435
vintagespeed
fNg
Oddometer: 1,799
Question
...Have you decided on what street tires you are going to mount?...
yeah, i'm gonna run the Avon Storm 2 Ultras, i've read good things about them. not sure how well they'll work on a light(er) weight SM bike, but others are running them. supposedly they get amazing mileage on big bikes, so i'm expecting this will be the last set of tires i ever buy......
should have 'em mounted & scuffed in a couple weeks and i'll know more about how they work on the DR.
only thing i'm unsure of is the front tire aspect ratio to go with. they offer it in a 120/60 & 120/70, i'll be running the 150/70 in the rear but dunno if i need to run a 70 front to match or if the 60 will be better in the corners??
of course, the 70 would allow for more curb hopping so maybe i'll just go that route, this bike sees daily air time. :)
Times are GMT -7.   It's 05:45 PM.
