Old 07-28-2012, 10:00 PM   #67741
P-P
P-P's Avatar
Oddometer: 97
Nice catch! So what is the little bottle that is mounted on your frame for?
Originally Posted by acap650 View Post
My choke cable finally snapped from corrosion, seems a bit premature on a 2008 but others have had it happen. It kept getting sitffer so I knew something was up. Ordered a new oem cable but it was backordered so I got the Procycle kit, not the knob version since the IMS tank blocks easy access, but the one with the short cable. After installing it I thought what a nicely executed replacement - it looks like a factory part.
Just say NO! to CaliFornication!
P-P is offline   Reply With Quote
Old 07-28-2012, 10:08 PM   #67742
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Looks like a home made chain oiler.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 07-29-2012, 12:26 AM   #67743
Eddieb
Eddieb's Avatar
Oddometer: 1,019
As you can see the oem plunger and guide pin is longer, by about 3mm or 1/8 inch. This told me that when the choke was in the off position it was still partially on and may be responsible for my stalling problem. So I removed the new plunger and installed the original plunger and spring. I backed out the idle stop and set the mixture screw to 1.5 turns out and it ran nearly perfectly. After a good warmup ride I tweaked the settings and all is well again.
I'm just wondering if anyone has had issues with the choke conversion or did I just get the wrong part, maybe for a different carb? I still commend Procycle for a nicely finished part and their excellent shipping practices but maybe they should check the current batch to see if they all have the wrong plunger.
Very interesting
I've just installed the same Procycle choke cable setup on my FCR when I installed the FCR 2 weeks ago. While the bike runs sweet throughout the rev range I can't get it to idle at all. I've tried all sorts of combinations of Idle mixture and speed settings to no avail.
I'd been thinking maybe I set something in the carb up wrong as I installed the needle/jets etc myself but maybe it's my cable.
Eddieb is offline   Reply With Quote
Old 07-29-2012, 12:48 AM   #67744
Rainier_runner
Epic Adventurer
Rainier_runner's Avatar
Oddometer: 313
Originally Posted by Eddieb View Post
Very interesting
I hate to ask an ignorant question, but as I look on the Procycle site, Isn't that particular mod only available for the stock or TM 40 carb?
Remote Choke Cable Kit
DR650SE '96-'12
Choose Type:
$32.95
Hate the handlebar mounted choke lever? Can't reach the choke knob? Does your Safari or IMS tank make using the choke difficult?
We now have a cable operated choke knob that mounts to the left side engine case. You can choose a remote choke for either the stock BST carburetor or for the Mikuni TM40.
2014 KTM 1190 Adventure R
2006 Suzuki DR 650 ADV
Rainier_runner is offline   Reply With Quote
Old 07-29-2012, 01:11 AM   #67745
Eddieb
Eddieb's Avatar
Oddometer: 1,019
To be honest I don't recall which carb I bought it for and what was available at the time as I've had it for quite a while. When I fitted it however it looked like the stock cable had a different sized thread than what the FCR would accept
Old 07-29-2012, 01:21 AM   #67746
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
The FCR plunger also has no spike.
Old 07-29-2012, 04:34 AM   #67747
Callahan71
Callahan71's Avatar
Oddometer: 4,142
Originally Posted by eakins View Post
others go the full dynojet/airbox cut route but have some surge and poor running problems. i've stuck closer to stock and mine is functional and versatile. thought about pumper carb from Procycle but i'm waiting for a finalized PNP FI kit (if that ever happens http://www.advrider.com/forums/showthread.php?t=725795 http://drriders.com/topic2824.html?s...45a472105fb775 )
Strange, I've heard nothing but good things about the DJ kit + airbox mod. I ended up doing it with the GSXR 1000 can and it works great.
Callahan71 is offline   Reply With Quote
Old 07-29-2012, 05:29 AM   #67748
Thumper Dan
Oddometer: 329
Originally Posted by HerrMnnn View Post
Sides carbon, top gripper.
Not to harp on about this but how slippery is the all carbon seat cover from SC! I'm getting conflicting reports: some say its good some say they move around too much and can nearly fall off - WTF.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 07-29-2012, 06:13 AM   #67749
jhomc1300
Oddometer: 13
Need to adjust carb?
Last fall I bought a 2000 with the loud FMF pipe, open airbox, and pumper carb. I have since scrounged up a stock muffler. I am wondering what bad thing will happpen if I close up the air box, install the stock muffler, but do not change the carb?
jhomc1300 is offline   Reply With Quote
Old 07-29-2012, 06:19 AM   #67750
acap650
acap650
acap650's Avatar
Oddometer: 734
Not ho-made, it's a Loooooooooooobman.
acap650 is offline   Reply With Quote
Old 07-29-2012, 06:24 AM   #67751
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,295
Fcr carb will not run right with closed airbox or even an airbox with just snorkel removed. It doesn't get enough air at higher rpm and the fuel mixture richens out. Can't get the jetting right without an open airbox.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 07-29-2012, 06:55 AM   #67752
Olas
the darkness
Olas's Avatar
Oddometer: 4,081
Anyone have any rear stock shock parts sitting around? Specifically looking for the rubber bumper, mine disintegrated and I need to replace it...I know alot of people replace their stock units, so maybe someone has this part sitting around and maybe wants a few bucks in exchange?
Sent from my DROIDX
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 07-29-2012, 07:09 AM   #67753
TrophyHunter
Oddometer: 2,300
I don't have experience with the SC carbon but my son's Corbin is slippery. I bought just the all carbon cover from SC to possibly change out the gripper but decided not to. I laid it on the existing seat and didn't like the amount of movement.
Personal preference of course.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 07-29-2012, 07:26 AM   #67754
Weldman
Weldman's Avatar
Oddometer: 1,518
Call me an ex-KLR rider with bad habits but I got
one of these http://www.amazon.com/Coleman-Comfor.../dp/B006JMK7N8
and I also put one of these http://www.amazon.com/Northeast-Prod...s=therm-a-seat underneath it in back to extend my pillion room and comfort and we couldn't be happier .
All for about thirty bucks .
I'm going to get me one of these for the DR maybe next week. Is the defualt option Carbon / Gripper the best cover to use??
I believe Seat Concepts probably needs some more pics a just a little bit more info on the website so people know what they're getting. But i've only heard good things about the comofort of their seats.
Nawfick, Virginny
Weldman screwed with this post 07-29-2012 at 07:33 AM
Weldman is offline   Reply With Quote
Old 07-29-2012, 07:46 AM   #67755
jhomc1300
Oddometer: 13
So if I leave the airbox open and install the stock muffler, will I be OK if I don't adjust the carb?
Times are GMT -7.   It's 06:13 AM.
