Old 08-22-2012, 06:34 PM   #68476
sagebrushocean
Harris's hawker
sagebrushocean's Avatar
Oddometer: 180
Originally Posted by Motodeficient View Post
Interesting G-tech results there! I haven't heard much talk about 1/4 miles times or 0-60 times for the DR650.
Here's a good compendium:
http://dalefranks.com/cycles/wp-cont...anPerfIndx.pdf
Shows the DR650 0-60 in the mid 5s, 1/4 mile in the (very) low 14s.
2008 DR650SE supermoto
2009 CRF230M
sagebrushocean is offline   Reply With Quote
Old 08-22-2012, 07:12 PM   #68477
ram1000
ram1000's Avatar
Oddometer: 1,837
Originally Posted by ntm1973 View Post
I ordered a hayabusa/kientech exhaust with a spark arrestor already installed and am looking forward to shedding a little weight but I would like to keep my jetting stock if possible. In fact, my only reason for wanting an aftermarket exhaust is to shed some weight. I went down the cut the airbox top/jet kit route and prefer the stock setup with one shim raising the needle. Has anyone done the hayabusa exhaust and kept the airbox stock? I know jetting is a case by case science but I was hoping for a starting point for people who have done the hayabusa exhaust with a stock airbox.
Also; Has anyone tried tuning the front fork on the cheap by changing the compression or rebound holes slightly? I am not a big guy (170lbs without gear) or an aggressive rider and I don't feel that I need emulators but would like a little more plushness up front. Has anyone done any experimentation?
Thanks for any words of wisdom!
Keep the stock jetting with those changes and you'll likely burn a valve.
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 08-22-2012, 08:24 PM   #68478
Meter Man
Living on a prayer
Meter Man's Avatar
Oddometer: 7,825
My most favorite place in the world!
Originally Posted by ShadyRascal View Post
I'll see that and raise you a Glacier park/Rocky mountain front loop
Meter Man is offline   Reply With Quote
Old 08-22-2012, 10:17 PM   #68479
TRAVELGUY
Old Traveler
Oddometer: 716
I'm running a GSXR pipe with stock carb and jetting and having no problems. All it did was save weight which is what I was hoping for.
TravelGuy.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 08-22-2012, 10:40 PM   #68480
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Originally Posted by Rumlover View Post
Cheat if you have to, but I want a time reported in the 13s.
I actually expected the DR to break 14 as my 558cc Nordwest did 14.1 and I feel the DR has a much better bottom end.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 08-23-2012, 05:15 AM   #68481
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,858
Interesting data there, but why in the world does the 2007 DR650SE do the 60-to-Zero stop in 131 feet while the older DR650, from 1996, stops in 118 feet?
Mambo Dave is offline   Reply With Quote
Old 08-23-2012, 05:54 AM   #68482
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,723
glad I have a '96
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 08-23-2012, 07:06 AM   #68483
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,269
Could just be a difference in break-in on the pads and rotors. I think the brakes on my DR650 suck, so my '96 probably falls into the 130-foot range. My G-Tech does do 60-0 braking too... suppose I could practice and see what it does.
Soon as I get a tap to chase the threads on my 15T sprocket, I can swap it on and go do some more testing.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 08-23-2012, 08:27 AM   #68484
Fire Escape
Fire Escape's Avatar
Oddometer: 1,670
Eh? Statistics
I believe Sannuel Clemmons is credited with saying that there are three kinds of 'untruths', Lies, Damned Lies and Statistics!
At first glance that looks like a big difference, and it would seem like one if there was a stopped truck you could not go around at 125'. The difference is 13', which is 0.15 seconds (at 60 mph). Despite having been told more than once how exactly skid marks can be used to calculate speed, I think that you could easily make that big a difference by altering tire pressures, temperatures, the tires themselves or the texture of the pavement. As I have heard said "That is why they play the game". Statistics, no matter how carefully recorded, from different times and places don't really tell you the whole story. There could have been lots of reasons for a 13' difference in 60 to 0 stopping over an 11 year period, I doubt we will ever know them.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 08-23-2012, 10:19 AM   #68485
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,295
Bruce
simple answer
Steroids
New testing procedures probably hold the '07 to a new standard and the old statistics from the '96 era should probably be marked with an *
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 08-23-2012, 11:01 AM   #68486
Rusty Rocket
Life behind "Bars"
Oddometer: 9,723
tire deal
http://newjersey.craigslist.org/mcy/3223077921.html
2009 DR650
Old 08-23-2012, 11:08 AM   #68487
TinkerinWstuff
Take it apart
Oddometer: 1,295
Originally Posted by Rusty Rocket View Post
probably needs the money to pay the maid
1999 Suzuki DR650
Old 08-23-2012, 07:40 PM   #68488
isgila
isgila's Avatar
Oddometer: 110
WTB: DR650SE 96 rear shock
Good day guys,
Anybody got a spare rear shock to let go for cheaps.
Want to sent it to rick at CD for the group buy.
Way too expensive to sent mine from Singapore.
Or can someone pls check which year is compatible with 96 model.
Pls PM me
isgila screwed with this post 08-23-2012 at 07:53 PM
isgila is offline   Reply With Quote
Old 08-23-2012, 07:50 PM   #68489
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,899
Is a Hayabusa muffler the muff of choice now for the DR? Is it lighter then the stocker by much?
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 08-23-2012, 07:58 PM   #68490
Foot dragger
singletracker
Oddometer: 12,899
Originally Posted by godwinmt View Post
I just checked outside...the cord is a set of earplugs someone in the plant must've dropped :)
The forks are off an '04 DRZ400S. The DRZ steering stem/bearings are pretty much identical to the ol' tractor's setup, so it was a matter of pull the bars off and lay them over the tank, pull the rest of the DR stuff, and then bolt up the DRZ front.
The DRZ uses the same headlight/cowl as the DR, so you get to reuse those parts. You will need new headlight mounts sicne the forks on the DRZ are bigger. I found a box of DRZ parts on ebay that had the brackets as well as a ton of bolts and misc brackets (brake line) etc. for $25.
You will need to modify the turn signal brackets (just take the top with the little alignment tab off) to fit, and the ignition switch needs remounted with homemade brackets as well. With some tweaking you should be able to get it mounted and still use the steering lock, but I was in a hurry with mine and it doesn't quite make it.
Unfortunately the stock DR wheel has a 17mm axle wheras the DRZ has a 20mm axle. The other problem is that DRZ wheels are pretty damn expensive to find in decent shape. Lucky for us though the front wheel off of an RM250 also works (I snagged one from an '07 for $85). The only problem with this is that the RM wheel doesn't have a provision to drive your speedo (I'm using a vapor, so this didn't affect me). The DRZ/RM has a smaller rotor than the DR, but some late model RM's (I know 07 for sure, not sure about others) have a floating front rotor like the DR. You'll need the axle spacers from whatever model bike you decide to use the front wheels from (RM in my case).
The brake is pretty much plug and play. Try and find the brackets to guide the line from a DRZ to make your life easier. Once the new brackets are on the line it's as simple as bolt the DR caliper up on the forks and go. The fender from the DR also works just fine, but I snagged a polisport YZ fender off of motorcyclesuperstore for $5
here's a quick cost breakdown for what I is needed to get it to work
'04 DRZ forks/tree - $200
'07 RM250 wheel - $85
RM250 axle - $15
Box of bolts with headlight brackets etc. - $25
trailtech vapor - $110
misc. aluminum flatstock - $5
So for me it cost $440 with the vapor. I'll make some back when I sell the forks/triple from the DR, but it's definitely a worthwhile upgrade. It completely transforms the bike...I mean it's still a tractor, but definitely less so than before.
Let me know if there are any questions.
-Malhon
Just a sidenote. The RMX has the 17mm axle,its the same as the RM except it has the speedo drive. I have a DRZ as well,Ive tried a few things to try to get the forks to work better,valving/springs/oil. They kinda work but are harsh yet mushy when pushed hard.
My new 530 solved the problem.
Times are GMT -7.   It's 01:42 AM.
