Old 08-29-2012, 07:11 PM   #68641
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Originally Posted by thinairflyer View Post
I posted:
Pro Cycle Top End Performance Kit ?
Is anyone running the Pro Cycle high compression piston and stage 2 cam? If so, how do you like it? I'm considering it for more power at highway speeds, staying with stock carb and muffler. Thanks for info. L D
Originally Posted by dirtydeeds View Post
I would think that those mods won't do a lot with the stock carb and pipe. Fuel has to get in and burnt gasses need to leave. Especially at highway speeds - there is a lot going through the engine under that load and the stock set up restricts the engine as it is.
Procycle replied:
The stock carb can handle it just fine if the airbox is opened up and carb is jetted to suit. By retaining the stock exhaust it will still get a boost but it will not let the engine mods work to their full potential.
I have been riding and working on bikes for a full 60 years... :-)
As Procycle replied: The stock carb is fine.
I say, take a look at dyno charts and about the most to be gained over the stock exhaust is a good deal more noise and 2 hp. I don't want the noise.... Carb mods only increase response mostly, I don't need that, the CV carb is okay for my use on the highway or gravel roads.
The high compression piston and stage 2 cam will put the power increase where I want it.
My original query was if anyone was running the Top End Performance kit, thanks, but don't need opinions on needing to do something else first. The higher compresion and stage 2 cam should add more horsepower than a carb and pipe upgrade.... I would just like to hear from someone using it...
So, is anyone actually running the Top End Performance kit that can comment on how they like it?
Thanks, L D
I had the hi-comp piston only in my first DR and it made a very nice improvement with the stock re-jetted carb and stock exhaust. It pulled everything with more authority was a bit smoother due to the lighter piston.
jessepitt is offline   Reply With Quote
Old 08-29-2012, 07:58 PM   #68642
Kommando
Kommando's Avatar
Oddometer: 7,390
I would think so too, especially if he's riding at any kind of altitude. He's going to want to be able to flow more air. Even here at sea-level, I noticed a difference with opening the airbox and exhaust to flow better, especially at higher RPMs.
Open the airbox (cut open or door removal), find an exhaust that flows well without sounding obnoxious, and tune the carb (stock or other). The choked-off stock engine will thank you. THEN go tearing into the engine to replace a piston and/or cam.
You may get better performance than stock with just the piston and cam, but it's not going to be optimal without being able to flow more fuel and air in and out.
Kommando is offline   Reply With Quote
Old 08-29-2012, 08:03 PM   #68643
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,295
I would recommend suspension changes before messing with the piston. Probably LED lights too.
Hope to see you out on the trail. I've done the rest of the mods and the piston is next on my list. Let us know how it goes should you proceed.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is online now   Reply With Quote
Old 08-29-2012, 08:06 PM   #68644
Kommando
Kommando's Avatar
Oddometer: 7,390
Originally Posted by TinkerinWstuff View Post
So who knew you could turn your key past the "lock" location to an "accessory" position and remove the key? Then leave the bike at a secluded mountain location and hike for 11 rugged miles and return to a stone dead battery?
Ever try to push start a DR650 with ammo can panniers on gravel?
I managed to macgyver a jump from some guy's pickup truck by removing my battery and connecting it to his trailer light connector. There were vehicles at the trail head all from hunters who'd packed in for the week. Fortunately the guy didn't show up to find me stealing a jump off his truck.
I'd almost killed my battery this way a year or two ago but noticed the tail light on.
You sound like a candidate for a dual-battery setup. Carry a charged spare. You could also carry one of those solar panels that folds like a map.
Old 08-29-2012, 08:07 PM   #68645
thinairflyer
Oddometer: 161
Thanks much, jessepit I appreciate your response. I am glad you mentioned the smoother motor with the lighter piston. Sounds like I need to plan on a winter project. :-) Besides the power increase, smoother would be nice, vibration is the biggest complaint I have with the DR650. Actually it is my only dislike. My KLR250 at 330 cc and my SV650 are much smoother than the DR650. That said, if I was limited to one bike it would definitely be the DR650. It is just such a good all around bike.
I have the stage 1 cam in mine right now and it makes the motor much 'crisper' feeling to me, but does not add much power above low and mid range.
By the way did you run regular or premium gas in yours?
L D
thinairflyer is offline   Reply With Quote
Old 08-29-2012, 08:19 PM   #68646
thinairflyer
Oddometer: 161
Suspension mods, Seat Concepts seat kit, different handlebars that suit me, different gearing, (several sets of gearing) stage one cam, Turbo City WS with Laminar lip, custom rear rack, Cortech TriBags, DRZ-S rear shock, Hi Intensity headlamp bulb, true 50 - 50 DOT tires, Waterproof GPS and a few other touches done. :-) Thousands of miles ridden. :-) Just want a little more oopmh on the highway with a quiet stock exhaust, had a GSXR1000 muf on and didn't like the noise.
Old 08-29-2012, 09:11 PM   #68647
TinkerinWstuff
Take it apart
Oddometer: 1,295
Was mostly just poking fun although I was serious about suspension.
The high compression piston seems like a hell of a value and will be on my Christmas list.
1999 Suzuki DR650
Old 08-29-2012, 09:53 PM   #68648
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,579
Mocked up, not bolted down yet. Getting there.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 08-30-2012, 02:12 AM   #68649
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
yes you do have a DR problem...looks great.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 08-30-2012, 05:23 AM   #68650
TrophyHunter
Oddometer: 2,310
After the few years of keeping up with this thread and modifying my own DR, I still enjoy seeing how each rider makes the bike their own. One of the strengths of the DR IMO, personalizing. A good common base with an endless list of outcomes supported heavily by the aftermarket and penny tech tinkering brains around the globe.
Lookin' good MeterPig..!
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 08-30-2012, 06:07 AM   #68651
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,742
Originally Posted by thetable View Post
Sounds like you have your easy fix then. I spent all of about 20 minutes removing mine for a track day, and never bothered putting them back on. The mounts make such good tie down points... Since then, the DR hasn't spent much time outside of TN and NC, but I have plenty of friends in VA without signals too.
Is it possible that you have an electronic flasher module, like those designed to operate LEDs at a normal flash rate?
The flasher is whatever is stock. I put mini turn sigs on a couple years ago. The bulbs are 12v 23W. Everything worked for years, but all of a sudden none work but the dash indicator still flashes.
I'm headed to the garage to dig around in the harness.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 08-30-2012, 07:11 AM   #68652
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,579
Love the ammo cans but they are heavy
That's your setup? Very nice.
Old 08-30-2012, 07:20 AM   #68653
TinkerinWstuff
Take it apart
Oddometer: 1,295
That's just one setup. My DR will be in the next movie installment of Transformers
1999 Suzuki DR650
Old 08-30-2012, 07:34 AM   #68654
TinkerinWstuff
Take it apart
Oddometer: 1,295
anyone still accumulating parts for a quick change rear gear and rubber setup:
http://www.ebay.com/itm/2003-Suzuki-...d12389&vxp=mtr
no affiliation with the seller.
I've finally got a complete spare rear wheel and second drive hub for my ADV and singletrack setups.
1999 Suzuki DR650
Old 08-30-2012, 08:34 AM   #68655
mrbing73
bOOb
Oddometer: 9
Question Aqualine + Brittania Comp + HDB?
I'm currently running an Aqualine Safari tank with a Britannia Composites fairing and Fat bars. I'd like to add a HDB set of hand guards with clamps, but I'm concerned about clearance between the tank and the ABS portion of the fairing. I'm already hitting the tank before I run out of steering lock.
Anyone running a similar setup? Successfully?
mrbing73 is offline   Reply With Quote
Times are GMT -7.   It's 08:07 PM.
