Old 08-30-2012, 07:34 AM   #68656
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
anyone still accumulating parts for a quick change rear gear and rubber setup:
http://www.ebay.com/itm/2003-Suzuki-...d12389&vxp=mtr
no affiliation with the seller.
I've finally got a complete spare rear wheel and second drive hub for my ADV and singletrack setups.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 08-30-2012, 08:34 AM   #68657
mrbing73
bOOb
Oddometer: 9
Question Aqualine + Brittania Comp + HDB?
I'm currently running an Aqualine Safari tank with a Britannia Composites fairing and Fat bars. I'd like to add a HDB set of hand guards with clamps, but I'm concerned about clearance between the tank and the ABS portion of the fairing. I'm already hitting the tank before I run out of steering lock.
Anyone running a similar setup? Successfully?
mrbing73 is offline   Reply With Quote
Old 08-30-2012, 12:00 PM   #68658
epix1718
epix1718's Avatar
Oddometer: 730
Stock Flasher Relay
In search of a DR650 stock flasher relay.. I gave away my stock unit to a member doing a RTW trip after I switched to LEDs, but I am in the process of returning my other DR650 back to stock so looking for this part. If you have one please let me know! PM me please :)
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Old 08-30-2012, 12:10 PM   #68659
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,216
Labor Day Ride
I'm heading out tomorrow for a four-day ride up around Mount St. Helens, Mt. Rainier, Mt. Adams and Mt. Hood (probably in that order). If anybody else is up in that area this weekend, wave if you see me. White DR650, purple frame, clear ScreensForBikes screen, Givi side luggage, a MotoFizz bag on top (with sleeping bag on top of that), etc. I have an ADV sticker on the back of my left-side case and an old-style ADV sticker on the headlight cowling under the windscreen. Oh and LED aux lights too.
I'll take lots of pix and try to do up a RR when I return.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 08-30-2012, 12:32 PM   #68660
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,586
Hey all, what is the name of the clip, or more importantly can it be procured separately that connects the turn signal wires to the main wiring harness? I don't want to cut mine to splice in some aftermarkets but would rather fab up an OEM connector.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 08-30-2012, 12:52 PM   #68661
epix1718
epix1718's Avatar
Oddometer: 730
These are what I used to wire up aftermarket LED signals w/o having to splice. Get 2 pairs (one for front/one for rear)
http://www.ebay.com/itm/Pair-Suzuki-...ht_1138wt_1397
edit: I've put a good 2,000+ miles including being out in the rain and no issues yet with mine.
97 Suzuki DR650
98 Honda XR250R
Old 08-30-2012, 12:55 PM   #68662
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,586
Thank you so much-just bought a pair (already have some for the rear). Right on!
Old 08-30-2012, 01:18 PM   #68663
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,586
I tried finding a 13T front sprocket for a 520 conversion but it appears that none exists...is this true
Old 08-30-2012, 01:24 PM   #68664
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,216
Not sure they do. Instead, go the other direction. A number of us are running 16/46 (520) for road use, then keep 14T and 15T's around for off-road. I love this gearing setup... had it on my bike for about 13k miles and it's ideal for the road. If I'm going to do extended dirt, the 15T goes on in a matter of minutes.
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 08-30-2012, 01:25 PM   #68665
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,586
Rob
Rob-I hear ya there just wanted to avoid changing out my rear sprocket.
Old 08-30-2012, 01:27 PM   #68666
frecks
frecks's Avatar
Oddometer: 246
http://procycle.us/bikepages/dr650.h...ts-chain-dr650
They have one at Procycle. It is in the "Individual 520 Sprockets & O-Ring Chains" section. It costs $19.95.
frecks screwed with this post 08-30-2012 at 01:28 PM Reason: Added the price.
frecks is offline   Reply With Quote
Old 08-30-2012, 01:29 PM   #68667
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,586
Doh! Should have looked there first-thanks.
Old 08-30-2012, 01:29 PM   #68668
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,216
Can you use a 525 rear sprocket with a 520 chain?? I would put a fresh sprocket on anyway if your rear sprocket is worn.
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 08-30-2012, 02:45 PM   #68669
Rumlover
Ed
Oddometer: 707
Rob
No, but I am pretty sure you can use a 525 chain with 520 sprockets.
I have a 520 13t sprocket for limited use with my 525 chain when the going gets tough. Just haven't had a need to use it yet, so I can't report on it.
Rumlover is offline   Reply With Quote
Old 08-30-2012, 02:51 PM   #68670
procycle
procycle's Avatar
Oddometer: 2,407
Originally Posted by meterpig View Post
doh! Should have looked there first...
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Times are GMT -7.   It's 03:22 PM.
