Old 08-30-2012, 02:54 PM   #68671
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,578
Originally Posted by Rob.G View Post
Can you use a 525 rear sprocket with a 520 chain?? I would put a fresh sprocket on anyway if your rear sprocket is worn.
Rob
It's not worn at all-relatively new
You looked down here...didn't you.
MeterPig is online now   Reply With Quote
Old 08-30-2012, 02:59 PM   #68672
Trbig67
Oddometer: 108
Originally Posted by Trbig67 View Post
Just looking... Are the plug wires even removable from the coils? Do they screw in like the plug caps?
The bike doesn't do this in the rain.. just when I hit a puddle pretty fast. It's forcing water into something it seems and takes a long time to dry out afterwards.
Bump.
Trbig67 is offline   Reply With Quote
Old 08-30-2012, 04:56 PM   #68673
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,220
If it's like my FZ1, no. It means you get to buy a new coil to get the wires. Check eBay first. I had to do that with my FZ1... a pair of new coils and plug wires was $35 shipped. Couldn't beat that. New ones woulda cost $200.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 08-30-2012, 05:07 PM   #68674
Chill
Chill's Avatar
Oddometer: 326
Hello, I'm new. Long time lurker and browser of all the awesome pictures, first time poster.
Could anyone please confirm if the Australian spec DR650 is the same as the US and Euro spec. In Australia there is what they call a LAMS scheme (Learner Approved Motorcycle Scheme) and so some bikes are LAMS approved and some aren't. Some bikes they do two versions of so these bikes must have some sort of restricter in place, usually in the throttle. The DR650 is a LAMS approved bike in Australia but my question is, is this because it's power figures are such that it falls into that bracket, or does it have some sort of restriction in place?
I have a full licence so would prefer to unrestrict it if there is some sort of restriction in place.
Thanks,
Chill
Chill is offline   Reply With Quote
Old 08-30-2012, 05:16 PM   #68675
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,385
Thanks,
Chill
The DR650 is LAMS approved simply because it is rated at 34 HP stock (worldwide)
You could then open the air box,fit a pipe and pumper carburetor along with a 780 kit for over 50 HP and no one would be the wiser.
The restrictions stock are worldwide and simply things like the air box having a small inlet not things like restricted intake manifolds etc or ECU's like some Japanese market import bikes.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 08-30-2012, 05:50 PM   #68676
Chill
Chill's Avatar
Oddometer: 326
OK, I understand. Thank you. That's cool then.
Old 08-30-2012, 07:04 PM   #68677
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
Originally Posted by MeterPig View Post
Doh! Should have looked there first-thanks.
Um, yea. Is there any where else? :
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 08-31-2012, 12:37 AM   #68678
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,666
Lams
Thanks,
Chill
The LAMS scheme allows bikes that don't exceed 150kw/tonne. At 32 KW on the DR650se, you do the maths.
The only restriction it has in reality is a weld in the header pipe,which many owners grind down, as I have, but which will hardly turn it into a mind blowing wheely machine. And from stock, the carby is on the lean side of life. There is no end of mods one can do to give the bike that involve buying new bits, not removing them from the stock bike, to give more power. Regardless (here in QLD), you get the letters LAM on your rego label to show the coppers you are riding a LAMS approved bike. Unless they carry a dyno with them, I doubt one would get sprung if on a learners.
If on an Open, go your hardest, they can't do anything about it.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 08-31-2012, 01:10 AM   #68679
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,283
let's not forget all the DR groundwork Jesse has done http://www.kientech.com/
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 08-31-2012, 03:33 AM   #68680
drsmiley
drsmiley's Avatar
Oddometer: 253
I with you on that , Jesse has done alot for the DR community!!!
drsmiley is offline   Reply With Quote
Old 08-31-2012, 05:56 AM   #68681
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,552
I tried finding a 13T front sprocket for a 520 conversion but it appears that none exists...is this true
I think ProCycle has one. I bought a Sunstar 31713. It fits fine, but you have to use the circlip that Jesse sells or one like it.
The sprocket, if I recall is one that fits a 1979-80 Kaw KLX 250 so maybe a long time Kaw dealer could have one still a OEM on the shelf that you could bargain the price down an save shipping.
you can even find 12 & 11 tooth sprockets for these bikes, Like the old KX500's on ebay
From an ebay seller:
SUNSTAR 31713 FRONT SPROCKET KDX400 79-80 / KX-KDX420 80-81 / KX500 83-86
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket screwed with this post 08-31-2012 at 06:33 AM
Rusty Rocket is online now   Reply With Quote
Old 08-31-2012, 07:20 AM   #68682
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,278
DR's are heavy
I was out playing last night and found some rocky, gnarly singletrack and decided to ride my DR down it. It was steep and knowing momentum is key I carried some speed. Well it got a bit out of shape and I couldn't bring it back and plop we went. Me over the bars and it slamming to earth. Broke the mount off of my hand guard and bent the shifter into the cover. Gouged the cover but it didnt leak. Picked the big pig up and had to decide if I wanted to ride up, or ride down not knowing where I was going. I chose the up route and decided that exploring unknown rocky trails riding solo on a DR is not for me. I will use my two-smoke for that.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 08-31-2012, 07:26 AM   #68683
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,850
Originally Posted by RichBeBe View Post
DR's are heavy
I went down a hydro line trail yesterday and managed not to fall though there were some steep up and down sections.
I didn't use momentum on my downhills, though. I used the rear brake and pussyfooted down since I was also on my own.
Emmbeedee is online now   Reply With Quote
Old 08-31-2012, 08:06 AM   #68684
TinkerinWstuff
Take it apart
Oddometer: 1,292
anyone still accumulating parts for a quick change rear gear and rubber setup:
http://www.ebay.com/itm/2003-Suzuki-...d12389&vxp=mtr
no affiliation with the seller.
I've finally got a complete spare rear wheel and second drive hub for my ADV and singletrack setups.
someone snatched it up - anyone here?
1999 Suzuki DR650
Old 08-31-2012, 08:08 AM   #68685
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,220
DR's are heavy
This sort of thing is how I ended up with a KLX250S for that kind of riding. My DR rarely ventures off anything more "extreme" than a gentle two-track trail now. :)
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Times are GMT -7.   It's 06:33 AM.
