Old 09-01-2012, 07:44 PM   #68716
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,536
Originally Posted by Meter Man View Post
Yeah, first time with the magnetic plug. We'll see how it looks when I change it in a few months to put the motorcycle up for the winter.
No winter riding in your neck of the woods?
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 09-01-2012, 07:46 PM   #68717
Meter Man
Living on a prayer
Meter Man's Avatar
Oddometer: 7,734
[QUOTE=Escaped;19499763]Wow - is that a solid mass, big pieces or a fine paste?
I started using a magnetic drain plug at around 30,000 miles, now have 40K and never more than a smudge of magnetic stuff.
First oil change with a magnetic drain plug.
Does this like normal wear for a DR with 15,500 miles?
Mostly a paste with a few larger pieces.
Meter Man is offline   Reply With Quote
Old 09-01-2012, 07:47 PM   #68718
Meter Man
Living on a prayer
Meter Man's Avatar
Oddometer: 7,734
Not much, I used to tough it out in the winter but not much anymore.
Old 09-02-2012, 01:59 AM   #68719
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
Originally Posted by sandwash View Post
Damm that's alot of stuff on there.My first change with a mag bearly had anything on it, and this is with a disk mag
(33 lbs of pull force).
Mine found a nsu screw the first time I used it.
About 50,000km ago. Only paste since then.
NordieBoy is offline   Reply With Quote
Old 09-02-2012, 02:01 AM   #68720
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
Originally Posted by Snowy View Post
When my son was doing his Provisional license, he took his ZZR250 in for a service, and the shop gave him a Vulcan 1700 cruiser loan bike, which was perfectly LAMS legal.
Over here LAMS is (going to be) 660cc or less.
An IT465 is approved
Old 09-02-2012, 12:56 PM   #68721
scottbed
scottbed's Avatar
Oddometer: 453
Question DR650 tires needed by Thursday - urgent!!!
I need a set of dual sport tires for a DR650 for a 3 day ride starting the 7th. So I need to spoon the tires on by Thursday night.
I just found out that tires cannot be shipped 2nd day or overnight...so, does anyone have a source for dual sport tires in the eastern Mass region?
I live in Arlington, MA and was looking for Bridgestone TW301/302s or maybe the Pirelli MT21s. In a pinch, most 50/50 I would do but don't want to break the bank. Local dealers or someone that can overnight a set to me would be good.
Thanks!!!
Happy to be here...
'02 DR650
'00 DR650
scottbed is offline   Reply With Quote
Old 09-02-2012, 06:31 PM   #68722
805gregg
Just Stroming along
Oddometer: 1,571
DRRiders
Anyone here on that DR forum? I'm trying to join but something is screwed up, I don't get an email back, someone contact an administrator or moderator for me please, 805gregg
805gregg is offline   Reply With Quote
Old 09-02-2012, 06:35 PM   #68723
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,536
Just got back on a shakedown ride with the dr. My opinion is the 16 42 combo works well for commuting and highway droning. Not to debate ratios, but, it worked really well actually having a 5th gear for, well overdrive.
I have a pumper carb so that might make a difference in rally lugging the motor.
Oh, I had the gocruise cruise control. Look mom! No hands!
Old 09-02-2012, 06:52 PM   #68724
thinairflyer
Oddometer: 161
I too run a 16 42 for going places on highway or graded gravel. It sure calms the revs down at highway cruising speeds. Stock motor except for a stage one 223 grind cam.
thinairflyer is offline   Reply With Quote
Old 09-02-2012, 07:00 PM   #68725
ER70S-2
ER70S-2's Avatar
Oddometer: 6,731
.......the 16 42 combo works well for commuting and highway droning.
I like the 16-42 combo for the highway too, very mellow.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 09-02-2012, 08:55 PM   #68726
GISdood
GISdood's Avatar
Oddometer: 856
Been running a 16/42 combo for commuting and highway use here, too. Next combo (already purchased) will be 16/43. I found that for most of the 100km/h roads up here that I was almost lugging at or just under 100 and as a result, was always jumping between 4th and 5th.
I'm hoping one more tooth on the rear will alleviate that a bit.
Sent from my SGH-I747M using Tapatalk 2
GISdood is offline   Reply With Quote
Old 09-02-2012, 10:00 PM   #68727
ER70S-2
ER70S-2's Avatar
Oddometer: 6,731
I don't use 5th until over 60 mph (92kph) unless I'm on a flat road or a downhill. I guess they get pretty 'touchy' if'n they catch you speeding up there.
2013 WR250R
Old 09-03-2012, 01:22 AM   #68728
eRRmmm
Oddometer: 576
Use tyre levers - much easier than spoons...
eRRmmm is offline   Reply With Quote
Old 09-03-2012, 01:56 AM   #68729
greer
Oddometer: 3,821
Seems like I get tires in two days from Cedar Rapids, Motorcycle Maniac and Dennis Kirk.
http://www.cedarrapidstire.com/home.php
http://www.motorcyclemaniacstore.com/
https://www.denniskirk.com/
Good luck!
Sarah
Thanks!!!
'08 DR650
greer is offline   Reply With Quote
Old 09-03-2012, 06:21 AM   #68730
Rugby4life
Rugby4life's Avatar
Oddometer: 731
Fly and Ride
OK folks, my battle damaged knees have informed me that dirt riding is no longer in my skill set. So the Kung Fu Panda has to go.
http://advrider.com/forums/showthread.php?t=822901
Thanks for looking.
"Before attempting to beat the odds, first determine if you can survive the odds beating you."
Rugby4life is offline   Reply With Quote
Times are GMT -7.   It's 05:44 PM.
