08-27-2012, 07:01 AM
#68746 |
Mostly Harmless
Oddometer: 1,703
I found the park position the same way as many, but fortunately it was before my battery died. 'Course I also had an LED taillight too. Now I'm very careful not to hit that position.
FWIW, my 2010 KLX250S and 2001 Yamaha FZ1 both do NOT have those positions on the ignition, which is nice. On another interesting note... now that my regulator and stator are working properly, my Battery Bug is reporting my battery health at 75%, which is a huge step up from the 26% it had been at prior. Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
08-27-2012, 07:42 AM
#68747 |
Take it apart
Oddometer: 1,116
I could clarify; this was a 7way round trailer connection with the accessory lead that's always hot regardless of ignition position.
1999 Suzuki DR650 1998 Honda VFR800 Interceptor http://share.findmespot.com/shared/f...KJutW9osVpn3hd |
08-27-2012, 07:56 AM
#68748 | |
Mostly Harmless
Oddometer: 1,703
Only downside is the 7-pin connector is kinda big. Rob
08-27-2012, 08:08 AM
#68749 |
Take it apart
Oddometer: 1,116
I doubt you can crank the bike with it connected to the trailer connector without blowing the fuse in the truck. The 14 ga wire on the battery tender and PowerPoint setup worked for trickle charging. After 30 minutes, the stone dead battery had enough juice to turn over 2 revolutions before clicking the solenoid. That was after I had unplugged the tail and headlight.
After 20 more minutes on the trailer hitch it was able to turn over fast enough to fire and stay running. The bike is a pretty easy starter.
08-27-2012, 08:10 AM
#68750 | |
Mostly Harmless
Oddometer: 1,703
I've also considered carrying a battery tender with me as a backup too. Even though it's AC-only, odds are you could find somebody with a generator, or a business or something to plug into. If you're in BFE, then, well, it's not gonna work. :) Sure would be nice if the damn thing had a kickstart backup. Rob
08-27-2012, 08:23 AM
#68751 |
Oddometer: 837
Well said,I understand "stuff happens",just don't dummy up.
97dr650 bad ass FCR-MX pumper ,plus other goodies
08-27-2012, 08:47 AM
#68752 | |
Procrastinators
Oddometer: 5,772
But the intelligent chargers we bought came with pigtailed modular plugs which we carry on the bikes as booster cables. Caution - if you do this, don't assume the colour coded cable ends will be right when you connect to a battery or donor vehicle! If you are connecting this booster cable through a modular plug on your own bike to start it, the normal connections are that the female will be the hot side so connect the pigtails to the other bike accordingly.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
08-27-2012, 12:17 PM
#68753 | |
Life behind "Bars"
Oddometer: 6,242
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
08-27-2012, 12:19 PM
#68754 | |
Life behind "Bars"
Oddometer: 6,242
08-27-2012, 12:20 PM
#68755 | |
Life behind "Bars"
Oddometer: 6,242
08-27-2012, 04:50 PM
#68756 |
Oddometer: 20
1st Dual Sport ride on the DR
Finally got out with a couple KLR buddies for my (and theirs) 1st dual sport ride. We did about 150 miles with about half of it consisting of pretty rough jeep trails. All of us are long time street riders and I ride a Berg 390 off road. I also got to ride the 05 KLR for a bit on the trails. The 1st thing I noticed is that the suspension on my 2012 DR is hopelessly soft. Also, the front brake sucks. But despite riding with hard Pelican cases mounted, my DR was way more dirt worthy than the KLR's. It's hard to describe a 350 Lb dirt bike "nimble" but it actually is, comparatively speaking. All three bikes have aftermarket seats and I found the bikes pretty equal as far as comfort. MPG on the three seems to be pretty even also. I place some value on the air cooled simplicity of the DR. With the full FMF and TM40 the bike felt like it had more/better throttle response and power than the KLR. The KLR comes with a good size tank which is nice....I'm still waiting for my 5.3 Gal tank. The brakes on the KLR sucked as well. The KLR also has better, more modern instrumentation......but I think my yet to mounted Trailtech voyager will negate that advantage. Both great bikes with extensive aftermarket support. All in all I was pretty pleased with my decision to buy a DR as opposed to the venerable KLR.
08-27-2012, 05:42 PM
#68757 |
Motor Sickle Addict
Oddometer: 1,076
Heads up
I just listed a Sargent seat for sale in the FM.
http://www.advrider.com/forums/showthread.php?t=821286 |
08-27-2012, 09:14 PM
#68758 |
explorer
Oddometer: 73
I have to move my DR650 dream
Due to health reasons I am sending my DR650 on to more compatible home. After pelvic cancer and a new hip the bike is to big and powerful for me to handle. On the positive I still have the DR350. I also have the privilege of knowing that I built this bike.
Bike is listed on FM http://www.advrider.com/forums/showt...4#post19463084 it was and is my dream bike and will do someone very well. Thanks Steve B
Steve Barrus North Bend, WA 1976 BMW R90/6 1999 DR650SE 1991 DR350S 1980 XL250 Steve B screwed with this post 08-28-2012 at 07:24 AM |
08-28-2012, 01:25 AM
#68759 |
Oddometer: 165
DR750 DR800 Front Sprockets
If anyone is looking for DR750/DR800 front sprockets, this Ebay seller in Michigan has quite a few listed.
http://stores.ebay.com/Motorcycle-Pa...sid=1067012968 Most are for 520 chain, but there are some for 525 chain. 15t only as well. For those that don't know what the difference is, the 750/800 sprockets are 10mm wide at the spline, vs 7mm wide for a 650 sprocket. The wider boss makes it less prone to wobbling around and wearing the shaft spline. Just test fit it on my bike and there is about 20 thou clearance from the inside of the retainer plate groove and the face of the sprocket. Cheers, David.
Rowie's DR650RS Rebuild |
08-28-2012, 05:34 AM
#68760 | |
Road Less Traveled
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 457
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300 Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E 1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale) |
