Old 09-15-2012, 11:46 AM   #69136
bross
Where we riding to?
bross's Avatar
Oddometer: 4,695
Sand riding
Thanks for the tips guys, I'll try to find some sand but I'm gonna practice on the DR.
Your comment about keeping your eyes up hit home. I have always struggled with that, when I used to take our kids out quadding and dirt biking, all we had was sand. I knew to look far ahead and when I'd do that, I'd get to the other side of the mud hole, deep sand pit or what ever and think. "Damn that was easy!". Then try the same trail the next week and end up looking at the fricking rut I was trying to stay out of and down I'd go. I think that's exactly what I did, looked down and of course that's where I went.
Old 09-15-2012, 12:59 PM   #69137
Bob808
Oddometer: 47
Can someone help me with some info please?
I have my DR all put together and I just need a single job to be done. To tighten the magneto screw. Since I don't have a 32mm wrench around I thought of just poping the engine into a higher gear and tighten the screw to 160NM while holding the rear brake. Could that damage something? Seeing that the DR engine puts out about 54NM ...
Bob808 is offline   Reply With Quote
Old 09-15-2012, 01:54 PM   #69138
MikkSteel
MikkSteel's Avatar
Oddometer: 32
White number plate?
I managed to cook the number plate on the right side of my DR after putting soft bags on and having the rubber piece that holds the plate off the exhaust fall out. Anyone got an old plate they took off collecting dust that they want to get rid of?
Thanks.
2006 XT225
MikkSteel is offline   Reply With Quote
Old 09-15-2012, 02:29 PM   #69139
Bob808
Oddometer: 47
Nevermind, I tried but the clutch is slipping...
Old 09-15-2012, 04:35 PM   #69140
Mobiker
Mobiker's Avatar
Oddometer: 1,824
Originally Posted by MADurstewitz View Post
Speed is the best way through deep sand. You have to stay on top of it. I live in NJ and used to ride in the pine barrens, which are mostly like beach sand. I found that going as fast as possible was the only way to stay on top. As soon as you slow down, you sink and that's when the squirrely stuff starts.
And as Bross said his wife did, keep your weight back and unload the front end as much as possible. I used to ride on the mine tailings on an XT500 back when I lived on the Keeweenaw Peninsula in Michigan. 50-60 mph across the stamp sands was a blast.
'88 R100GS
'76 xl350
"Don't Panic"
"If I was in a hurry, I'd left earlier."
Mobiker is offline   Reply With Quote
Old 09-15-2012, 06:51 PM   #69141
Nullarbor63
Test Pilot
Nullarbor63's Avatar
Oddometer: 23
Mate, those levers look great. Any chance you could post a plan drawing of them, with measurements, so I can check the size against my hands and bars? If they're a fit, I want to preorder (It's a long way to send them back from Aus).
Originally Posted by warp9man View Post
2nd item is Levers
I could find any decent levers out there for the DR, you get stock or Bikemaster levers, nothing that i was happy with so. you guessed it were making levers to and im supper happy with them and these puppies are already be machined in mass quantities. only diffrence from the picture is it will be titanium color pivot and black blade for a 2 tone look. we tried a lever with the sport bike little lever adjustments on them but after a few rides in the dirt the little adjusters siezed up so we went a more old scholl and simpler adjustment of bolt with backer nut. the levers fold and are adjustable for reach.
yes we are also doing a real chain guide that can take a beating.
here are the prototypes that are working out great, they use the stock perches and work with the OEM brake switches. im also going to include new pivot bolts for guys that are not running the OEM hand guards.
Nullarbor63 is offline   Reply With Quote
Old 09-15-2012, 10:50 PM   #69142
procycle
procycle's Avatar
Oddometer: 2,455
Originally Posted by bross View Post
So, how do you guys who are better at this do it?
I suck in sand too. It's always difficult on a heavy bike.
I don't have any additional advice but I did recently see a great explanation about why sand is such a bitch.
I think most of us are familiar with the 'trail' or 'caster' effect that keeps your from wheel pointed forward. Riding on flat ground the contact patch is behind the steering axis and the force on the contact patch adds a self centering effect to the steering.
When your front wheel is in deep sand the force where the tire contacts the sand is in front of the steering axis. You get a negative trail effect. With the contact force in front it makes the tire want to turn and the more it turns the stronger the turning force is applied to the tire. It wants to do anything but go straight. You can counteract this in a few ways.
1) Move as much weight as far back as possible. This will help stop the front tire from sinking into the sand as far which will lessen the negative trail effect.
2) Accelerate and stay on the gas. This will lighten the front end even more and help the front tire stay high enough to steer normally.
3) Go fast. If you go fast enough front wheel won't be able to sink into the sand and will steer normally.
Yeah, how fast do you want to crash? Like Grifter said, don't slow down suddenly. Chopping the throttle will bury the front wheel even deeper and the negative trail will steer the wheel right out from under you.
My sand riding hasn't gotten much better but I believe understanding what makes it difficult will help me develop my own techniques for getting through it.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 09-16-2012, 02:59 AM   #69143
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,710
Good advice. Another bit of good advice that transformed my sand riding is keeping head and eyes up and level, and not looking down at the wheel tracks you want to ride in. The old adage, you go where you're looking, and those wheel tracks in sand are rarely straight. If you have enough speed and keep the front light, the front tyre will plow the sand out of the way and track straight if you are looking ahead in the distance. EDIT: I've just looked back a few posts and someone has already said that. Tyre pressures make a difference too, more so than the type of tyre itself.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson screwed with this post 09-16-2012 at 03:05 AM
kezzajohnson is offline   Reply With Quote
Old 09-16-2012, 03:56 AM   #69144
Tyrepower
Tyrepower's Avatar
Oddometer: 165
Only one thing to say about this............... Canning Stock Route. After a week riding this you will be an expert sand rider. However exactly as Procycle has reported seems to best way. I also found to adopt the Motocross way of body English, either sitting or standing. Look ahead to where I was going, not where I was. Relax the grip and keep the elbows out. Keeping up enough speed to be safe but not so much that you over shoot the next corner. I found cresting one sand hill I backed off to look for 4x4's coming the other way, loaded up the front and buried the wheel up to the axel and did a perfect nose plant into the dune. As everyone has said above the best practice is, weight back, keep the power and speed up, look ahead and relax. The death grip on the bars just added to head shake and exhausts you all that much quicker. I will put up some helmet cam footage of an off the track excursion after I hit some ruts and a bush and ended up in the Spinafex and shrubs for a 50m jaunt. Also got a good shot of my brother going down that he caught on his cam. Will post as soon as I get it edited and work out how to. My advice to anyone thinking of doing the Stock Route would be to go down to your most popular fishing beach when the fish are running. Ride up and down amongst the fishermen dodge in and out amongst them. Do this a few times so they get real angry....... not just a little but real angry. Then let them bash you with their rods and buckets as you ride by. Do this for 1-2 weeks and you should be prepared for the shrub/tree/bush lined tracks of the CSR.
Cheers Richo
My biggest fear is when I die, my wife will sell all my bikes for what I "told her" they cost!!!
It's all good fun until someone gets hurt......... then it's hilarious!!!
Tyrepower is offline   Reply With Quote
Old 09-16-2012, 08:47 AM   #69145
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 9,134
I'm sure this has been asked before, but searching through 4625 pages has yielded me no specifics so here goes.
I want a DR650. MrsDonkeys wants a dual-sport that we can both ride. Not 2 up, but both pilot. The problem is that she is 5'1" tall.
I'm seeing lowering links online for up to 4". For her to ride, we would need a target seat height of no more than 31". So for your experienced DR guys, how do the lowering links equate to seat height? Does a 4" drop get the seat height down below 31"?
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 09-16-2012, 09:06 AM   #69146
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,090
Stock (low) seat height is 33.0" per the Suzuki website, if you aren't already aware. The factory low height doesn't include lowering links, but a change in the front spring set up and there is a low setting change to the rear shock assembly. There is also a factory low seat, which is approximately 1" lower than the stock seat. So, with the factory low suspension setting and the low seat you're at approximately 32". It's my understanding the factory low seat is also contoured a little different so it's easier to reach the ground. I don't know about lowering links, but 4" lowering links seems excessive considering you can get the bike to ~32" with factory parts.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 09-16-2012, 09:08 AM   #69147
doug s.
Oddometer: 1,354
i would think you could get there, or wery close. my dr650 doesn't have lowering links, but is is lowered due to being 'tarded. its seat height w/o passenger is ~32.5". (corbin seat.) so, lowering links, even w/o new wheels should get you in the ball park. especially since the "stock" seat height is listed at 34.8". or perhaps switch to 19" front wheel, along w/the lowering links, if you don't want that much height reduction to come strictly from the rear of the bike?
my only concern would be that, if you are also not on the shorter side, what mrsdonkeys likes might not be what mrdonkeys likes... of course, you could compromise, and set the bike up in-between, so neither of you likes it! i think you need to try before you buy...
doug s.
doug s. is offline   Reply With Quote
Old 09-16-2012, 11:09 AM   #69148
Bob808
Oddometer: 47
Almost done with the rebuild only need to paint the exhaust. As long as I am here I decided to grind the blob of weld that everyone talks about. So after I finished the job I noticed that the whole area is smaller than the rest of the pipe's diameter. Isn't that a bottleneck for the whole exhaust? Should I grind it all around or is it ok like this?
Old 09-16-2012, 12:49 PM   #69149
RidingDonkeys
Purveyor of Awesome
Oddometer: 9,134
doug s.
It is entirely possible that we set one up for her, and I will end up having to get my own. This is why we have two hacks, and two Triumphs, etc.
I may or may not be pushing that direction again.
Sent from the voices in my head, and transcribed by their drinking buddy.
Old 09-16-2012, 01:02 PM   #69150
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Below 31? You might want to look at customizing the seat to get most of that. Lowering the suspension means putting the frame closer to the ground, so you'll need to modify the sidestand, or use the Suzuki sidestand designed for the lowered setup. A bashplate and case armor is even more important with things closer to the ground. Radically lowering the frame could mean having the rear tire rubbing, too.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Times are GMT -7.   It's 02:23 AM.
