Old 09-17-2012, 04:20 PM   #69196
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,779
Originally Posted by Rob.G View Post
I hope people don't hate me too much for posting this... but how OFTEN do you change the oil in your DR? I don't care to start a, "what oil is best" debate; I already have a brand that I use and I will stick with it (all I will say is that it's synthetic)... but how often, as in miles, do you tend to go?
I've been going 2000 miles per change, given that the motor is air-cooled and only holds two quarts. I wonder if this is about right, or if it can go longer, especially on synthetic? I just happened to look at the odometer today (I'm at 24,035 miles) and I checked my oil change log, and last time was 22,235. So I either will go to 24,500, or maybe round it up to 25k because I like even numbers.
Thoughts?
Rob
For me it really depends on where I have been riding. Lots of dirt and water...closer to 2000-2500. Road riding: 3000-4000. I also keep an eye on the oil color. If I see it getting dark I just go ahead and change it. I think I have around 18K miles on the DR now and the oil looks the same as it did the first oil change.
My street bikes are all full syn. (Motul 10-40) and changed 3500 miles on the dot. I gotta admit I am a little more slack with the DR. Most of the time I run standard oil unless I know the temps are going to be 95 and up or I will be doing a lot of sand riding then synth. I know some guys are cringing me switching back and forth..but in all honesty..I don't care...it's a DR: put oil in it and ride it.
Mongle is offline   Reply With Quote
Old 09-17-2012, 04:28 PM   #69197
procycle
procycle's Avatar
Oddometer: 2,274
Nothing wrong with switching back and forth. Modern synth is 100% compatible with dino.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 09-17-2012, 04:48 PM   #69198
neo1piv014
ADV in training
Oddometer: 619
So I have a question about the Procycle gasket for the DR650 side cover - how in the hell do I put it on? As you can see in the picture....
... there's two places where the gasket would have to be cut away or something just to get the wiring through. I tried slipping the stator and wiring assembly before putting the gasket on, but they wouldn't fit. I'm assuming this thing is supposed to go on before anything else, but since the original gasket disintegrated, I couldn't see how it was put in place. Any advice?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 09-17-2012, 04:51 PM   #69199
procycle
procycle's Avatar
Oddometer: 2,274
The gasket goes on last. It's a lot easier to put it on the crankcase (engine side). Put the dowel pins in the crankcase and they will hold the gasket in place.
Old 09-17-2012, 04:55 PM   #69200
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,172
The abuse I put it through over the weekend more than likely shortened the, ahem, interval.
You looked down here...didn't you.
MeterPig is online now   Reply With Quote
Old 09-17-2012, 05:13 PM   #69201
neo1piv014
ADV in training
Oddometer: 619
Dowel pins? Do you mean the bolts? Here's what I don't get though, how do you get the stator through that small first hole? My wiring is all one solid piece,so it isn't as though I can disconnect everything to run the wires.
Sent from my LG-P999 using Tapatalk 2
Ride videos
'01 DR650
Old 09-17-2012, 05:54 PM   #69202
Kommando
Kommando's Avatar
Oddometer: 7,360
Originally Posted by RidingDonkeys View Post
I'm sure this has been asked before, but searching through 4625 pages has yielded me no specifics so here goes.
I want a DR650. MrsDonkeys wants a dual-sport that we can both ride. Not 2 up, but both pilot. The problem is that she is 5'1" tall.
I'm seeing lowering links online for up to 4". For her to ride, we would need a target seat height of no more than 31". So for your experienced DR guys, how do the lowering links equate to seat height? Does a 4" drop get the seat height down below 31"?
I'd try the factory lowering for front and rear, then call Seat Concepts about a lower piece of comfier seat foam.
If that's not low enough, try 1" lowering links in the rear and then slide the forks up in the clamps. I wouldn't put the suspension any lower than this without having (expensive) custom work done on the forks and shock.
You'll also want a shorter/adjustable sidestand, and make sure you have a skidplate.
You don't mention your inseams, or YOUR height. You may want to lower the rider pegs, for more legroom, with the lower seatfoam. I also like having lower passenger pegs to put my feet back, and touring pegs to put my feet forward. Having multiple positions to move my feet around to lets me eat serious mileage in relative comfort.
Kommando is offline   Reply With Quote
Old 09-17-2012, 05:56 PM   #69203
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,139
The price and availability of parts had nothing to do with my choosing this bike, but they are great perks... And I take this opportunity to show off my new 19" front wheel, can't wait for it to dry out tomorrow so I can scrub her in
By God, Woodrow; it's been one hell of a party.
dogjaw is offline   Reply With Quote
Old 09-17-2012, 05:56 PM   #69204
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Dowel pins?...........
#14. They're usually used as pairs, on opposite 'corners' of a cover.
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 09-17-2012, 05:59 PM   #69205
neo1piv014
ADV in training
Oddometer: 619
Weird. I don't remember seeing those at all, but I also wasn't looking for them. I have a feeling I'll be ordering up a new gasket from procycle, however, since I seem to have messed up the installation pretty bad on this one.
Ride videos
'01 DR650
Old 09-17-2012, 06:17 PM   #69206
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
Don't panic, you'll get thru this. Is the new gasket broken?
The wiring goes in the cover, outside of the gasket.
Mount the stator in the cover, push the rubber plug(s) into the cover, put the gasket on the engine (being located by the dowel pins), fit the stator/cover, install the bolts.
DON'T OVERTIGHTEN THEM, a small seeping leak is way better than a stripped hole in the crankcase half.
Not my pic.
Another photo from 'not my pic'.
2013 WR250R
ER70S-2 screwed with this post 09-17-2012 at 06:28 PM
Old 09-17-2012, 06:19 PM   #69207
procycle
procycle's Avatar
Oddometer: 2,274
Stator through the small hole? I have no idea what you mean.
The wire harness has a rubber grommet that slides into the pocket in the side case. The wires are routed under the pickup coil.
Bolt the stator into the cover.
Insert the harness grommet into the pocket.
Run the wires through the channel between the pickup coil bolts.
Install the pickup coil.
Install the starter drive gears in to the engine case.
Put the gasket on the engine case.
Install the side case onto the engine.
Next time take photos while you are taking it apart.
You might need a dab of something sticky to hold the gasket in place because there is only one dowel pin for the cover.
Old 09-17-2012, 06:31 PM   #69208
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,112
Originally Posted by Adv Grifter View Post
I've also ridden (a long distance) a XT225 Serow. I am not a fan of this bike. Power is truly pathetic. The DR650 trumps it in every way I can think of ... except picking it up from the ground.
Good luck!
It really depends a lot on the size/weight of the rider. My wife at 5'4"/125lbs fits like a glove on the XT and just loves the light weight of it and surprisingly is very quick on it too. When it comes to off road, she does not want anything larger/heavier to have to struggle with.
Yeah, me at 6'4" & 240lbs, the XT is fun around town for about 10mins, but that's about it. There's no way I could ride an XT any distance and have fun. I just know when it comes to ladies, us guys sometimes take for granted that we usually are built larger and stronger and weight and size is a whole lot bigger factor for them. I've learned that the hard way with my wife and she is now finding her element in small/lightweight bikes.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 08 WR250R,
Hers: 07 Ninja 650R, 13 CRF250L,
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 09-17-2012, 06:55 PM   #69209
neo1piv014
ADV in training
Oddometer: 619
The 19" adventure wheel setup looks phenomenal. Very nicely done. Have you noticed much of a hit in offroad performance?
Ride videos
'01 DR650
Old 09-17-2012, 06:57 PM   #69210
neo1piv014
ADV in training
Oddometer: 619
Not my pic.
Hmm. I think I see where I was losing the plot. I'm away from my part at the moment, but when I was working under the assumption that the gasket went on first, I had put a thin coating of RTV sealant on the side cover and set the gasket on top of it. Since that wasn't terribly long ago, I can probably still peel it off and see if I've actually done any damage. Hopefully not, but even if I do need to get another one, that's essentially the cheapest thing I could have messed up during this whole process, so I'm not overly hurt about it. Thanks again to everyone here for knowing a good thing or two more than me.
Ride videos
'01 DR650
Times are GMT -7.   It's 12:56 AM.
