Old 09-18-2012, 02:55 AM   #69226
greer
Oddometer: 3,858
Isaac,
How'd this work out? I'm with ER70S-2, the black plastic shield definitely needs to go.
Sarah
'08 DR650, '13 TU250X
greer is offline   Reply With Quote
Old 09-18-2012, 02:56 AM   #69227
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,943
Originally Posted by greer View Post
Isaac,
Ditto on both our IMS tanks. Plastic shield is no longer on our bikes.
Old 09-18-2012, 03:31 AM   #69228
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,385
Besides removing that black shield as already mentioned lining the holes up is the same as the Safari tank.
See that steel bracket with the lip under the rear of the tank.
If you use something like a ring spanner with the ring end in front of the the lip of the bracket,levering the tank forward will be easy to start the bolts.
Just remember those are only M6 threads in the frame,you want to make sure the bolts start easy to avoid cross threading etc.
Originally Posted by neo1piv014 View Post
And here's the holes not lined up:
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 09-18-2012, 04:14 AM   #69229
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,710
plastic shields
Alright ladies and gentlemen... on tonight's episode of "Isaac the Wonder Mechanic," I got the gasket in place, got the side cover on, got the bolts tightened, and put a light coating of RTV sealant around the edge. With that all looking good, I decided to go ahead and put the fuel tank, seat, and side panels on so it would at least look like a motorcycle again while I waited for the sealant to cure for 24 hours. I ran into yet another difficulty, however. Is there some kind of trick to getting the damn fuel tank back on I've got the pucks all the way back in the little U shaped depressions, got the tank pressed up against that plastic shield thing, but the holes for the screws simply refuse to line up. I've tried pulling up on the tank to verify that the pucks are correctly in the spaces allotted for them, and I can't seem to find anything that it's hitting that would stop it.
Here it is, fully up against the plastic shield bit.
I've taken the black grommets out just so you could actually see where the screws are supposed to go here. I'm assuming there's just a knack that I'm lacking, but I've killed about 30 minutes out in the garage trying to put the dang tank back on. Thanks again, and I'm sure I owe someone about 30 beers by now
Yep, get rid of those plastic shields. They are only there for looks with the steel tank. I have never run the plastic shields with my IMS tank and have never had any issue with holes lining up. just a wiggle and a jiggle and bolt 'em up.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 09-18-2012, 04:30 AM   #69230
Mike_drz
Mike_drz's Avatar
Oddometer: 401
this thread is funkyier than I thought it is
________
your wolrd point of view is suddenly wildened by a mindfully (of joke)
Mike_drz is offline   Reply With Quote
Old 09-18-2012, 04:35 AM   #69231
Mike_drz
Mike_drz's Avatar
Oddometer: 401
Talking
but I am still far from satisfy
________
holy shit @#$%^^ god typo of craps
Old 09-18-2012, 04:53 AM   #69232
Mike_drz
Mike_drz's Avatar
Oddometer: 401
I am a hiden french,
____
damn, I am poor (two more post before this others can't see) be careful everyone
Mike_drz screwed with this post 09-18-2012 at 12:38 PM
Old 09-18-2012, 05:53 AM   #69233
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,231
Originally Posted by MeterPig View Post
My 04f0 arrived today. I have to say, it's pretty sexy.
Just wait until you hear her speak!!
By God, Woodrow; it's been one hell of a party.
dogjaw is online now   Reply With Quote
Old 09-18-2012, 06:57 AM   #69234
neo1piv014
ADV in training
Oddometer: 627
That must be it then. I'll unbolt those once I get home.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 09-18-2012, 09:55 AM   #69235
maynard911
Oddometer: 142
Originally Posted by dogjaw View Post
What tire where you running on your 19"? I was running the 700 on my 21, they stuck so well I figured I couldn't go wrong with the 705's... I'm going to go carve it up tomorrow; I do have concern about how far off my speedo will be, going to check it with my GPS.
The speedo will be too far off to be of much use. You can get a drive from Procycle for a 17" but not a 19". I removed the stock speedo and installed a cheap bicycle speedo that I had sitting around. It works good but there is no light for after dark. Next farklefest I will get a Vapor or something similar.
Maynard " Youth is fleeting, immaturity is forever"
maynard911 is offline   Reply With Quote
Old 09-18-2012, 10:08 AM   #69236
neo1piv014
ADV in training
Oddometer: 627
It looked like he was running on 705's actually. Gotta say, I've been nothing but impressed with those tires since I spooned them on my 21/17 stock wheels. I can imagine they'd be that much better on 19/17 tires.
Ride videos
'01 DR650
Old 09-18-2012, 10:17 AM   #69237
neo1piv014
ADV in training
Oddometer: 627
Originally Posted by ER70S-2 View Post
Beer?? There's beer?!?!
Is that an IMS tank? I think you're supposed to remove that plastic shield? You are really close to the bolts lining up. Soap up the pucks like you're mounting a tire, everything should slip into place. As close as you are, I'd use a little persuasion. (Don't get stoopid and ruin your tank)
Beer has been the standardized form of payment any time I've ever done mechanical work with friends.
Ride videos
'01 DR650
Old 09-18-2012, 10:46 AM   #69238
deathu
deathu's Avatar
Oddometer: 77
I just had the gsxr1000 "40F0" muffler installed on my '98 DR650 today, using a custom fabricated mid-pipe. I'm not a fan of loud exhausts, the purpose was to save some weight, but this thing sounds amazing, not too loud and not too quiet either.
With the new pipe I noticed a significant drop in the level of vibrations at normal operation RPMs. From my point of view this is more than welcome, the bike is much smoother now, but I'm trying to understand why did the vibration levels drop? Is there a logical explanation to this? Did anyone experience the same after changing the muffler?
deathu is offline   Reply With Quote
Old 09-18-2012, 10:57 AM   #69239
acap650
acap650
acap650's Avatar
Oddometer: 734
Butting in here . . . I have been using a 19 X 2.5 for a few weeks and am delighted. Since I got the wheel for mainly street/commuting I'm running a Pirelli Scorpion Trail 100/90-19 with a Pirelli MT90A/T stock size on back (I believe this configuration is called a reverse mullet). The 2.5 in. front will take a larger 110/80 but works well with the 100/90 and allows use of all the side tread for really planted feel at full lean (and almost no chicken strips visible).
The speedo, checked with GPS, is out almost exactly 10% at most speeds and I can live with that as it is an easy calculation, i.e. 50MPH indicated = 50-5 = 45MPH true. I've also been toying with the idea of making a corrected stick-on scale for the speedo and see no need to go to a Vapor.
I intend to keep my 21 in. front and mount a more aggressive tire for dirt rides - takes about 10 min. to change out since both wheels have disks mounted.
acap650 is offline   Reply With Quote
Old 09-18-2012, 12:16 PM   #69240
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,579
Yeah, it is super light and far better made than the FMF I pulled off. The FMF is like a toy by comparison. Then again, a new 40f0 from Suzuki is something like $650 so it's a we bit better made than the FMF just on price.
Hopefully I can keep from denting it as I did the stocker over the weekend.
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Times are GMT -7.   It's 06:03 AM.
