Old 09-19-2012, 07:42 PM   #69271
Rumlover
Ed
Oddometer: 707
Originally Posted by procycle View Post
I think you could figure on about 2 hours of labor (+ fork oil) just to lower the forks and almost another hour to do the shock. You'll also need the shorter side stand ($55). I'm guessing closer to $225-$250 for everything.
Good catch on the side stand. You must do this for a living or something .
Thanks in general for checking in here!
Rumlover is offline   Reply With Quote
Old 09-19-2012, 09:33 PM   #69272
Chill
Chill's Avatar
Oddometer: 323
Is there some special knack to getting the bike up on a stand? I've got a stand like the one below but in the low position it is still too tall to slide under the sump. It's a good inch or two too high, bike is standard, not lowered or anything. The stand has a rubber top to it which makes sliding the bike on from the side very difficult. Is there a knack to this or do I just need to man up and wrestle beast onto it or am I missing something?
Chill is offline   Reply With Quote
Old 09-19-2012, 10:38 PM   #69273
procycle
procycle's Avatar
Oddometer: 2,390
The only thing you are missing is more ground clearance. Those stands are made for motocross bikes which have several inches more clearance between the frame and the ground. About the only way to make that stand work for the DR would be to shorten it enough to easily slide under the bike.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 09-19-2012, 10:58 PM   #69274
Chill
Chill's Avatar
Oddometer: 323
OK, thanks. Yes, I think I'm going to have to make some sort of ramp to back up and then remove after it's on the stand. Thinking about this now I'm wondering if I angle the stand at 45 degrees towards the engine I can push the bike forward onto it. Thanks.
Old 09-19-2012, 11:34 PM   #69275
Feelers
Oddometer: 189
[/IMG]
Push the bike up onto two pieces of wood - one under the front tire and one under the rear tire. Use whatever size you need to get the bike high enough to slide that stand under!
Feelers is offline   Reply With Quote
Old 09-20-2012, 01:54 AM   #69276
dljocky
Oddometer: 866
Shock Oil?
I'm about to attempt to change the oil in my shock. It feels like I'm riding a pogo stick it bounces so bad. Anyone who has some advise on this please chime in.
I'm 240lbs without gear, and I do have a heavier spring on it. Should I consider putting a heavier weight oil in, or would stay with the stock oil? I'm not really sure of the oil weight. I'm not going to do a re-valve job or anything, but is there anything that I should replace while I'm in there, ie, a seal or something? I am going to replace the bumper.
Bike is a little over 2.5 yrs old, 35K miles.
dljocky screwed with this post 09-20-2012 at 02:09 AM
dljocky is offline   Reply With Quote
Old 09-20-2012, 03:02 AM   #69277
eRRmmm
Oddometer: 576
I put Silkolene RSF 7.5wt shock fluid in mine when I put an 8kg/mm spring on, very happy with the results.
eRRmmm is offline   Reply With Quote
Old 09-20-2012, 03:17 AM   #69278
koh kood
koh kood's Avatar
Oddometer: 121
There's lots of good information here that might help you on the shock rebuild.
http://drriders.com/topic2041.html
"I wasted time, and now time doth waste me."
koh kood is offline   Reply With Quote
Old 09-20-2012, 04:06 AM   #69279
dljocky
Oddometer: 866
Thanks all,
I'm not the most mechanical person, so any information that I can get to pull from is appreciated.
Old 09-20-2012, 04:59 AM   #69280
TrophyHunter
Oddometer: 2,254
http://www.advrider.com/forums/showp...ostcount=35652
Full revalve write up but it may help. I didn't replace my seal head (7000 miles on bike) and haven't had any leaks at all.
http://www.procycle.us/info/guides/d...ock-build.html
PC has a nice write up with a little more sanitary pics. They were a great deal of help on the phone when I was deciding the direction I wanted to go.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 09-20-2012, 05:44 AM   #69281
greystoke
2 wheel whore
greystoke's Avatar
Oddometer: 123
Pig won't idle
Hi guys.
I've put my carb back together after giving a thorough clean, changed all the o-rings and replaced the idle jet with a stocker (42.5). Stock needle not worn and on 3rd clip (stock setting I believe). Fuel screw turned 2 1/4 turns. No airbox mods. As far as I can tell it's as Suzuki wanted it. Managed to get her fired up with some coaxing but it won't idle. Revs just drop and putt-putt-ptuh . If I hold the throttle the tiniest bit it'll keep going. It won't start with the choke on at all and if I put it on after starting it makes no difference to revs.
But!!! If I cover 3/4 of the snorkel with my hand it will idle.
I'm not a mechanic but to me this sounds like it's running too lean? (too much air?). I can raise the needle and keep turning the mixture screw but to me from what i've read this setup 'should' run and i'm wondering whether there's something else wrong.
There's no fuel coming out the overflow (as it has in the past) and if I turn the drain screw fuel comes out so the float bowl appears to be filling and shutting off correctly. The rubber tipped float needle looked fine and was thoroughly cleaned. If the float wasn't set correctly not allowing enough fuel in i'd guess that the problem would be more stop-start than affecting idle.
Am I looking at the problem wrong?
2 Brothers,
2 Scooters,
25,000 kilometres.
www.rightaroundaustralia.com
PX200
'86 K100RS
K7 DR650SE
greystoke is offline   Reply With Quote
Old 09-20-2012, 05:53 AM   #69282
Fire Escape
Fire Escape's Avatar
Oddometer: 1,601
Lightweight, Quick Stand
Would rolling the front wheel onto a piece of 2xXX lumber get you high enough? Might need a piece for each end and the side stand. Being intended for a MX bike, is that thing rated to lift a DR? Wouldn't be much fun to get it up there and end up wearing it for a hat.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 09-20-2012, 06:46 AM   #69283
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,773
I have one like that and it's not going to last very long if used to pick up the DR650. It's just barely adequate for the G450X we have.
Old 09-20-2012, 07:48 AM   #69284
procycle
procycle's Avatar
Oddometer: 2,390
+1
Also, those type of stands have the leverage ratios designed for lifting a 230 pound bike. You will probably find that even if you can get the stand under the bike it will take 2 people standing on the pedal to get it in the air.
Old 09-20-2012, 07:55 AM   #69285
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
Originally Posted by imprezagm4 View Post
Thanks for those numbers! That definitely helps.
Rather than spend that at a dealer, if you're really right down in Corvalis (I'm in Salem), come up one weekend soon and we can just do it at my place. I have all the tools, including a welder to shorten the side stand.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Times are GMT -7.   It's 04:39 PM.
