Old 09-21-2012, 05:10 AM   #69301
Samford
Samford's Avatar
Oddometer: 64
Travel Tools
I briefly searched the forum and google for this with no success, so here it goes:
I just recently purchased a DR650 down in Orlando, FL. I will be doing a fly and ride to bring it home to Southern Wisconsin next weekend. I hope I won't need any tools for my trip home, but I tend to not leave the house with some kind of tool set to help me get through a bind. Unfortunately, I haven't had a lot of 1-on-1 time with a DR650 before buying this one so I'm not very familiar with the "tools you don't leave home without." Obviously I'm aware of the basic 10mm wrench and socket, but to help me out... what tools do all of you never leave home without?
"'Any bike's subframe is liable to crack with the extra weight of the luggage when travelling on corrugated dirt roads,' it said somewhere. Hmm, I thought... mental note: Strengthen subframe. Second mental note: Find out what subframe is." - Lois Pryce
Samford is offline   Reply With Quote
Old 09-21-2012, 05:27 AM   #69302
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,740
Among the standard pliers and screwdrivers, I carry tire repair stuff. I have a small bicycle pump, tire Irons and a patch kit. Also on my front fender in a tool bag made for that spot I carry a 21" tube and a small set of jumper cables that came from Aerostitch. The DR is the first and only bike I ever owned that doesn't have a kickstarter. Scares me to death. I've never needed them for myself, but have helped several others. (how old is the battery on this bike you are buying?)
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 09-21-2012, 05:44 AM   #69303
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,957
Did you know the DR has a fairly complete tool kit already? You need tire irons, spare tubes and a pump as well, though. And an adjustable wench.
Old 09-21-2012, 05:46 AM   #69304
Bear Chow
Oddometer: 13
Meat clubs for hands
I don't think, I have overtly gargantuan sized hands but I'm struggling with comfort on my 2012 DR650. I always wear gloves, in summer I wear mechanics gloves and for winter I have a nice thick pair of snowmobile gloves. The bars on the DR are just a bit narrow so I'm looking to replace them. As I collect parts I also want to find the right size and fit had grips.
In the my summer gloves the palms of my hands hangover the outer bead of the grip a 1/4 to 1/2 inch, even when I keep my hands right up against the inner bead. This is very pronounced in my winter garb. The grips also tend to be skinny. This is to say my fingers wrap around the grip and nearly touch my wrists. I'm only 5'10 230lbs so I'm not unusually big, although; I do have long gorilla arms. I can't be the only person with similar problem.
Can someone recommend a wider thicker grip that will allow me to tackle obstacles while knowing I have firm grasp of the handlebars?
Bear Chow is offline   Reply With Quote
Old 09-21-2012, 06:06 AM   #69305
Kommando
Kommando's Avatar
Oddometer: 7,390
The big DR push-starts easily enough.
Kommando is offline   Reply With Quote
Old 09-21-2012, 06:07 AM   #69306
Rusty Rocket
Life behind "Bars"
Oddometer: 9,740
Not in the woods. I realize though that he is not doing any trails on his way home, but those are the things I don't leave home without.
2009 DR650
Old 09-21-2012, 06:38 AM   #69307
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,782
Question
i SHOULD know this but I am not confident: I'm thinking of buying a late model, sell the older one [sshhhhhh... don't tell 'er]. I recall that at some point, like maybe 2009, the third gear part was changed, and then we've had several discussions about the subtle change to the NSU fasteners, but in the States what year wuz that ??? Bottom line, what model year incorporated the last useful change?
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 09-21-2012, 07:04 AM   #69308
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,278
Originally Posted by 805gregg View Post
Weight is your enemy off road, why not put a 790 kit on a DR and have a light weight powerfull bike $680, that's what I plan.
I'm going to either way. The 790 will likely happen before the 800XC, as it will likely be sometime in mid 2013 before I might have any chance of having the money for one.
I also need to do the 351 kit in my KLX250S... in fact, it needs it far worse than my DR needs the 790. The DR, in stock form, at least has torque. The KLX has none. :)
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 09-21-2012, 07:05 AM   #69309
Samford
Samford's Avatar
Oddometer: 64
It's a newer battery. The bike was driven daily by the previous owner. While I haven't tried it with the DR650, it's not very difficult to bumpstart (rollstart) a 450 so I wouldn't think doing the same to a 650 would be impossible. I had him mount up a brand new distanzia with a HD tube for the front and the rear is under a year old. Random mishaps do occur though I suppose. I plan on doing a lot longer/semi-permanent trip on it next spring and will definitely have a full tire repair kit with me then. A small bicycle pump sounds like a good idea for this return trip though.
I guess I was more asking for that special, handy tool that only an experienced DR650 rider doesn't leave home without. From what I've gathered the DR seems very straightforward, but without actually spending time on breaking down one it's hard for me to feel 100% prepared.
Old 09-21-2012, 08:04 AM   #69310
kamlander
Oddometer: 58
you may want to seriously consider bringing a better seat along (12mm wrench). for some of us, the factory seat is a real torture rack.
kamlander is offline   Reply With Quote
Old 09-21-2012, 08:24 AM   #69311
Samford
Samford's Avatar
Oddometer: 64
I've read that about the stock seat in countless places. Luckily the one I bought has a custom seat already installed. According to the previous owner it's remarkably comfortable. Lets just hope his ass isn't made of steal because the stock seat on my GSF400 makes my ass numb after a good 3 hours of riding. It wouldn't be a pretty site to be doing the "trade-off" ass cheek maneuver for 20+ hours.
Old 09-21-2012, 08:43 AM   #69312
thumpism
Oddometer: 623
If need be, you can always pick up one of those Stearns ATV seat pads at the first Walmart you come to.
thumpism is offline   Reply With Quote
Old 09-21-2012, 08:55 AM   #69313
thetable
thetable's Avatar
Oddometer: 1,481
I wish my stocker made my ass numb. Nah, it's more along the lines of a pain that continues on for a few days after putting the bike away.
thetable is offline   Reply With Quote
Old 09-21-2012, 10:41 AM   #69314
TrophyHunter
Oddometer: 2,310
From memory - 2006 on the 3rd gear part number change. NSU's went to a hex head (Allen Head) screw but still have been found loose.
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 09-21-2012, 10:47 AM   #69315
procycle
procycle's Avatar
Oddometer: 2,463
Yes, a new part number but there's no evidence of any update or improvement in the gear.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Times are GMT -7.   It's 11:08 AM.
