Old 09-24-2012, 07:47 PM   #69436
psmcd
Oddometer: 954
glad
I put my magnet in at 3,400 miles and only saw light dusting at 4,480. First oil change at 500 miles.
Originally Posted by Meter Man View Post
First oil change with a magnetic drain plug.
Does this like normal wear for a DR with 15,500 miles?
psmcd is offline   Reply With Quote
Old 09-24-2012, 08:29 PM   #69437
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Bob808 View Post
Oh thank you. That put my mind at ease. Then I will install back the 145 tomorrow and see how it goes with the rest of the settings.
For the fast idle problem ... I would ensure your throttle cables are not hanging up. Very common. Routing should be perfect. Check them. Even if twist grip is shut ... you could still have the throttle slide hanging up a bit.
If you can't solve this (carb probs) ... I'd buy a nice BST Carb off someone here ... preferably a nice virginal one that hasn't been "Tuned".
Good luck Bob and good work getting her running! You are almost there!
Adv Grifter screwed with this post 09-24-2012 at 08:46 PM
Old 09-24-2012, 08:50 PM   #69438
ram1000
ram1000's Avatar
Oddometer: 1,833
That picture reveals many times what my motor shows at an oil change interval. I always use Mobile 1 15/50 in my DR650
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 09-24-2012, 10:08 PM   #69439
troyfromtexas
troyfromtexas's Avatar
Oddometer: 279
Thumb
Originally Posted by refokus View Post
6K for a bike that has 24K miles? good luck.
Hi Refokus,
Perhaps I'm being optimistic. However, I'm pricing the bike taking into consideration the modifications and the market price of a similar bike in Paraguay, Argentina and Brazil, the three countries to which I'm closest at the moment. In Paraguay a new DR650 runs about US$9,000, in Argentina about $10,000 and in Brazil probably $13,000. So even a one year old bike with 24,000 miles is within reason. On MercardoLibre, the ebay of Latin America, there are a few 1999 DR650s with between 40-60,000km selling for US$4-5,000. In all of these countries it is hard to find or import quality modifications. The import duties often double the price of the item. While this bike does have 24,000 miles, it has been maintained tightly. And it is running perfectly.
Thanks for the feedback. If I am unable to sell her, I'll just bring her home with me.
Troy
Troy
www.theadventurebegins.tv
2011 Suzuki DR650
troyfromtexas screwed with this post 09-24-2012 at 10:17 PM
troyfromtexas is offline   Reply With Quote
Old 09-24-2012, 10:16 PM   #69440
troyfromtexas
Oddometer: 279
Originally Posted by PPCLI-Jim View Post
i see you are letting go of your DR are you selling any parts / separately ? If you are send a list of parts / cost. I am in the market for some DR 650 upgrades without blowing my budget.
Hey Jim,
Thanks for the question. At the moment, I'm trying to sell the complete bike. If I do sell the bike complete, I will have some of the original stock parts that I will sell once I return home. The original parts are in new condition and are in storage at the moment. If I am unable to sell my bike, I will bring her back home with me. Then I may rebuild her as a stock bike. I would then sell all the goodies. I'd be sure to post on this thread.
Thanks for the inquiry,
Troy
Troy
2011 Suzuki DR650
Old 09-24-2012, 10:21 PM   #69441
troyfromtexas
Oddometer: 279
Originally Posted by Adv Grifter View Post
Troy!! Congrats on a great tour!! A few of us here have followed your ride from the start. Best of luck with the sale ... probably a local will end up buying your bike. Maybe contact the local riding clubs there.
I hope everyone here takes time to check out your report!
Cheers!
Cheers Grifter. Thanks for following. It's been a ride.
Troy
2011 Suzuki DR650
Old 09-24-2012, 11:43 PM   #69442
greystoke
2 wheel whore
greystoke's Avatar
Oddometer: 123
Originally Posted by Feelers View Post
Hey Greystoke,
I just want to say that the total height of my idle adjustment/throttle stop screw is about 10mm above the bracket. This is the outer screw length (9mm) plus inner pin height (1mm). When your throttle is completely closed, does the throttle rest on the throttle stop screw, or touch it at all? It should - unlike in that picture a few pages back. I don't mean to beat a dead horse though, so onwards!
Really, the only things that should affect idle are the pilot/idle jet, idle adjustment screw, fuel/air screw, and float level.
Your pilot jet is known good.
Your fuel/air screw is probably fine.
You don't like your idle adjustment screw anymore!
So, I guess you need to pull the carb apart and check if you missed anything - any little spacers or o-rings? Check the float level?
You could take out the fuel/air screw without taking out the carb and see if the spring, washer, and o-ring are on it first...
Did you change anything else on the bike at the same time as cleaning the carb?
Do you have a tach by chance?
Thanks for the measurements mate. Here's a shot of mine. Looks pretty much the same with pin wound up as far as possible.
A bit of an update.....
Pulled the carb again and checked every jet and gave them another clean for good measure. Everything looked fine.
Gave the idle circuit a good soaking in carb cleaner spray as best I could with no compressor to blow through. Let it sit for a bit then did it again.
Then went back to the float assembly. Before setting the float height again just did a little inspection and notices the piping in the float assembly has a tiny jet in it.
Which comes out here...
Eyeballing it against the light I couldn't see through it so drowned it in carb cleaner and used a tiny dental brush to gently pry the jet. Nothing came out. Blowing through it didn't do much but eventually I thought I could see a tiny dot of light when holding it up to the light. I don't know what this circuit is for or whether it's relevent but figured it has to do something.
Then fit the float assembly back and checked the float height. Float height looked OK from what I understand but when holding the carb the right way up so the float is on the bottom I lifted the float with my finger to see if it moved freely. It went up fine but when lowering the float the jet stayed in the hole until the tab touches the wire loop. Then it drops with a tick. Tried it a few more times and realised it was sticking in the hole. Pulled the jet out and saw a tiny bit of varnish on one of the four posts around the jet. Cleaned that off and tried again. Now the jet morves freely. That must be some pretty fine tolerance there.
Put the carb back together and reinstalled in the bike.
Now it starts easier. Choke still prevents it from starting. Warmed it up a bit then let the throttle drop. Stalled.
Started it again and warmed it up for a few more mins. Let it drop. SUCCESS
It's idling by itself, sitting on the throttle stop. I'm guessing it was the jet not dropping freely that was the main issue.
Thanks tons for all your input fellas. Legends, all of ya
Here's a little vid. Can anyone guestimate whether that idle sounds about right?
http://youtu.be/M7QXJg4r3NY
2 Brothers,
2 Scooters,
25,000 kilometres.
www.rightaroundaustralia.com
PX200
'86 K100RS
K7 DR650SE
greystoke is offline   Reply With Quote
Old 09-25-2012, 12:52 AM   #69443
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,589
do a pinesol clean on the carb. way back when, i thought my carb was clean until i did and was amazed how much dirt came out. http://advrider.com/forums/showthread.php?t=560117
i now also run a small pour of Lucas fuel treatment through all my full tanks of gas. after another year and 1/2 i pulled my carb to look at it clean everywhere. did a precautionary pinsol clean and i had only tiny amount of dirt. it's oil based (not a distillate) so it's not harsh. my bike is happier when i use it. goes in everything i have with a motor. http://www.lucasoil.com/products/dis...catid=2&iid=26
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 09-25-2012, 01:50 AM   #69444
Feelers
Oddometer: 187
Thumb
Well done, Greystoke!!!
So, it could have been the sticky valve, weird float passage thingy, or dirty idle circuit?
The idle adjuster does look fine. Thanks for the photo.
My ear isn't really calibrated to rpm but it sounds good to me!
All that's left is minor adjustments for ease of starting and no stalling!!! Oh, and fixing the choke.
Feelers is offline   Reply With Quote
Old 09-25-2012, 02:49 AM   #69445
Bob808
Oddometer: 46
I replaced the bars with ones that are a bit longer, like 1 cm each side. That caused some problems when turning right but as I was working on a friends freewind a few nights ago I noticed that his were routed on the right side so that gave me the idea. I rerouted the cables and now I have plenty slack. It isn't a cable problem, I've adjusted them properly for sure. I'll make more tests in the evening after I get off work. Thank you all for your help.
Bob808 is offline   Reply With Quote
Old 09-25-2012, 02:54 AM   #69446
deathu
deathu's Avatar
Oddometer: 77
Originally Posted by deathu View Post
Hi,
Can anybody please tell me if there should be any hose attached to the highlighed port on the stock carb?
I just noticed today that this port is not connected with anything in my case. I guess it's a port for ventilation purposes, an I wonder if a hose is missing on my bike.
OOps! for some reason, it seems that my image was not visible... here it is again:
or:
deathu is offline   Reply With Quote
Old 09-25-2012, 05:31 AM   #69447
greystoke
2 wheel whore
greystoke's Avatar
Oddometer: 123
I'd put money on the float needle sticking being the main issue. Took it around the block a few times and seemed ok. It's always been a little rough and decided to raise the needle one clip, something i've been meaning to do for ages and now she starts first time every time (today). I'd go so far as to say it feels better than it ever has. Fingers crossed she loves me in the morning.
Thanks again to ER70S-2, Feelers, motolab, Adv Grifter, Mongle and anyone else I missed that suggested stuff. Really appreciated
2 Brothers,
2 Scooters,
25,000 kilometres.
PX200
'86 K100RS
K7 DR650SE
Old 09-25-2012, 05:58 AM   #69448
FlowBee
Just me.
FlowBee's Avatar
Oddometer: 5,754
...If you can't solve this (carb probs) ... I'd buy a nice BST Carb off someone here ... preferably a nice virginal one that hasn't been "Tuned". Good luck Bob and good work getting her running! You are almost there!
Bob808: I have a completely unmolested BST40 I took off my 09 when it had 42 miles on it. It's been sitting on a box on my bench for 2 years. If interested PM me - I'll make you a sweet deal on it. (USA only)
FB
"And then this one time at banned camp ....."
FlowBee is offline   Reply With Quote
Old 09-25-2012, 06:19 AM   #69449
TRAVELGUY
Old Traveler
Oddometer: 642
I understand what your saying. I bought and shipped a used DL650 to Costa Rica and rode it for two years. Then sold it for $3000 more than my purchase price and that was a very good deal for the buyer. Importation duties in many countries really add value. With shipping cost and taxes it only cost me $1000 to have it there for the two years.
TravelGuy
Originally Posted by troyfromtexas View Post
Hi Refokus,
Troy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 09-25-2012, 06:35 AM   #69450
greystoke
2 wheel whore
greystoke's Avatar
Oddometer: 123
No Pine Sol down here in Oz
2 Brothers,
2 Scooters,
25,000 kilometres.
PX200
'86 K100RS
K7 DR650SE
Times are GMT -7.   It's 06:13 AM.
