Old 09-25-2012, 08:49 AM   #69451
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,172
Originally Posted by greystoke View Post
No Pine Sol down here in Oz
Do you guys have carb cleaner? I buy it in the 5 gallon cans so I can dip Holleys, alumn heads and other parts. Carb cleaner works WAY better then Pine Sol. I don't buy into the whole pine sol thing. If it takes all night to work..well then it doesn't work that well. I can dip a carb in 30 minutes and it is CLEAN and even any paint that was on it is gone.
Obviously you don't need 5 gallons of the stuff. But the DR carb is small. Buy 2-3 cans of Spray carb cleaner. Spray them into a coffee can or something similar that wont get ate away. Then dip your carb parts (nothing plastic or rubber!!!) into the carb dip for about an hour. Pull it out and wash it off with the water hose then air dry it with compressed air. Done.
you might even try to find it in gallon size. The stuff is great to have around for cleaning any kind of metal small parts. It will eat carbon and paint off in no time!
Edit: Don't buy the stuff that says "non-chloronated". If you spray it and it evaporates in 2 sec it is junk, get something diffrent. I buy the Zepresto Carb dip in the bulk. Wear gloves. Carb cleaner will eat your hands up! it also soaks into your finger nails and they will stink for days...ask me how I know...
Mongle screwed with this post 09-25-2012 at 08:55 AM
Mongle is online now   Reply With Quote
Old 09-25-2012, 08:52 AM   #69452
thetable
thetable's Avatar
Oddometer: 1,468
Did you read through the linked thread? Looks like 90% are saying that it works better, and no need to worry about getting rubber in it.
thetable is online now   Reply With Quote
Old 09-25-2012, 08:57 AM   #69453
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,052
Edit: Wear gloves. Carb cleaner will eat your hands up! it also soaks into your finger nails and they will stink for days...ask me how I know...
I've used the gallon can for years. +1 for using heavier rubber gloves (the medical gloves will disolve) when handling this stuff.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is online now   Reply With Quote
Old 09-25-2012, 08:57 AM   #69454
procycle
procycle's Avatar
Oddometer: 2,413
Originally Posted by Jammin View Post
Thanks for the good info, Jeff. Sounds like it's the stator then.
Question on riding with generator disconnected: how can I ride for long when the battery would not be getting charged from the generator? I figure I can go about two hours before battery totally discharges, right?
It does sound like a stator problem albeit an unusual one. The proof will be in the actual fixing of it.
If you ride with your lights unplugged your battery will not be depleted. The source coil produces power for the spark energy. The battery is not required to keep it running except for a very small amount of DC current that is routed through the key switch to the CDI as a theft deterrent. You would want to do a minimum amount of stops and starts as running the starter motor will deplete the battery.
Well, now, I'm not getting the spark to fail. Bike is running for about 10 minutes with no problems, this is with replacement CDI and spare rectifier and 1 new spark plug. But I did check power source coil resistance after running and it comes to 0.6 ohms, pick-up coil comes to 245 ohms. Is the 'pick-up' coil the charging coil, the one that's wound on the engine case?
Jeff, to replace the stator, I need to get these 6 allen bolts out, right? Anything else? Those bolts are going to be really tough, right? How do you suggest I remove them without air tools?
Those 6 allen bolts hold the starter clutch to the back of the flywheel. Don't remove them! The stator is the round thing in the case cover with all the copper wire windings.
You can't easily tell by looking at it but there are 3 charging coils wound onto the iron core and the source coil is wound on top of them. The pickup coil is a small separate coil off the the side of the stator.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 09-25-2012, 09:01 AM   #69455
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,172
90% of people that don't have the right carb dip. Most home people are cheap and wont spend the money for the good stuff. Zepresto 5 gallons is $375. Go to any carb shop/engine shop...you wont find Pine Sol there.
Old 09-25-2012, 09:21 AM   #69456
neo1piv014
ADV in training
Oddometer: 621
That's because a shop would need something that works quickly. If something 1/30 the price works as long as you leave it overnight, I have the time to let it sit out overnight.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 09-25-2012, 09:27 AM   #69457
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,172
And I understand that. But, don't tell me it works better. That is why I said buy a gallon or 2-3 cans and make your own little dip. People say it works better because they try spraying a can on...it evaporates and quits cleaning in 2-3 minutes and when they look at it it is still dirty. You have to DIP the parts then wash them off.
I'm trying to help the guy out who says he can't get Pine Sol and everyone wants to argue about how great Pine Sol is? WTF? Then you all try to convice me how great it is...really? I do this for a living. I don't spend the money on the good stuff for shits and grins...I do it because it works.
Old 09-25-2012, 09:27 AM   #69458
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Suzuki released the 2013 DR650!... Take a look
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 09-25-2012, 09:40 AM   #69459
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,172
I would like to be an engineer on the DR650 team.
Engineer log:
Jan. 1st. - Going to design the 2013 DR650
Jan. 2nd – not changing anything- send last years engineering plans to the manufacturing plant
Jan. 3rd through Dec 31- Hang out, ride bike, collect pay check…..
Old 09-25-2012, 09:43 AM   #69460
planemanx15
Oddometer: 1,009
Sounds about right. The specs sheet does say Drum brake in the rear. Thats got to be a typo.
Engineer log:
Old 09-25-2012, 09:56 AM   #69461
motolab
motolab's Avatar
Oddometer: 2,777
Then went back to the float assembly. Before setting the float height again just did a little inspection and notices the piping in the float assembly has a tiny jet in it.
Which comes out here...
Eyeballing it against the light I couldn't see through it so drowned it in carb cleaner and used a tiny dental brush to gently pry the jet. Nothing came out. Blowing through it didn't do much but eventually I thought I could see a tiny dot of light when holding it up to the light. I don't know what this circuit is for or whether it's relevent but figured it has to do something.
The jet in question meters fuel to the cold start enrichment circuit.
Then fit the float assembly back and checked the float height. Float height looked OK from what I understand but when holding the carb the right way up so the float is on the bottom I lifted the float with my finger to see if it moved freely. It went up fine but when lowering the float the jet stayed in the hole until the tab touches the wire loop.
Do you mean the float needle?.
Choke still prevents it from starting.
Technically, BST40 carbs use cold start enrichment circuits instead of chokes (regardless of what the lettering on the lever might say). A choke is closed when an engine is cold and opened when it is warm, whereas a fuel enrichment circuit is opened when the engine is cold and closed when it is warm. A choke works by restricting the air flow, whereas an enrichment circuit works by adding extra fuel. A choke requires a fast idle cam or something akin to it (or you have to hold the throttle open manually), whereas an enrichment circuit adds a little extra air simultaneously with the extra fuel, so the fast idle is already built in. In any case, if the engine wont start from cold with the cold start enrichment lever activated, then it is likely that the fuel portion of the circuit is clogged somewhere, meaning that air will be let in (for the fast idle), but not enough fuel (making the mixture leaner instead of richer). This brings us to the jet you were cleaning. It's likely to still be dirty. On the other side of it, the fact that the engine will start from cold without the cold start enrichment circuit active means that the idle mixture is too rich, and should be readjusted when the engine is warm via the method I outlined in a previous post (or set to ~2.5-3.5% exhaust CO).
Regards,
Derek
motolab is offline   Reply With Quote
Old 09-25-2012, 10:12 AM   #69462
ER70S-2
ER70S-2's Avatar
Oddometer: 6,967
Originally Posted by deathu View Post
OOps! for some reason, it seems that my image was not visible... here it is again:
My pics are taken from both sides of the bike, the hose goes straight back along the right frame rail. This is stock, there is no filter.
This:
Goes here:
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 09-25-2012, 11:01 AM   #69463
neo1piv014
ADV in training
Oddometer: 621
I didn't think anyone was saying it worked better than the expensive stuff that's actually designed specifically for cleaning carbs. I thought the general consensus was that it's good enough if you let it work long enough, and it's significantly cheaper.
Ride videos
'01 DR650
Old 09-25-2012, 11:40 AM   #69464
shu
Oddometer: 1,055
Originally Posted by FlowBee View Post
Bob808: I have a completely unmolested BST40 I took off my 09 when it had 42 miles on it. It's been sitting on a box on my bench for 2 years. If interested PM me - I'll make you a sweet deal on it. (USA only)
FB
FB- If Bob808 is not intererested, I am. PM me.
Thanks............shu
ps: Your PM box does not seem to be accepting messages.
shu is offline   Reply With Quote
Old 09-25-2012, 11:46 AM   #69465
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,850
For the record, that's the rotor (it rotates) not the the stator (it's static).
Times are GMT -7.   It's 04:13 PM.
