Old 09-30-2012, 12:26 AM   #69676
Thumper Dan
Oddometer: 325
Originally Posted by ER70S-2 View Post
That's funny, but at the same time probably practical.
Originally Posted by procycle View Post
When I remove my Safari I also remove the front brace and bolt it to the tank while it is off the bike.
Why is that Jeff, so the tank doesn't distort too much. I did notice this time I've taken the tank off compared to others times is I had quite a bit of fuel in it - around 3/4 full. May this is why it was a struggle??
thanks though
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 09-30-2012, 05:16 AM   #69677
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Originally Posted by V8 View Post
So, does anyone here have a 790 or 780 kit installed?
I did, and it was awesome, and then I woke up.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 09-30-2012, 07:07 AM   #69678
sandwash
sandwash's Avatar
Oddometer: 1,357
Originally Posted by 805gregg View Post
Take the other one out and match it.
Ding Aling,thats the hard way.The reply from the poster is the easy way.But ya thats the way to do when all else failsNothing wrong with asking first.Thats what this fourm is for
97dr650
sandwash is online now   Reply With Quote
Old 09-30-2012, 07:31 AM   #69679
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,822
great visuals!
how is it people say the ktm needle works better than an oem needle shimmed? i have 2 washers under an oem needle and was thinking about a ktm needle. i see a wider ktm needle and that means less gas at the oem needle assuming the same resting position.
even the fp needle is wider. the only advantage those 2 have is clip adjust-ability but washers under the factory needle work just fine to raise the needle and thus more gas...plus the factory needle is thinner as lets more gas through. i see it being the best oem shape option. plus the fp & ktm needle are longer and sit deeper in the carb, less gas, than oem.
am i missing something here???
Originally Posted by motolab View Post
You can see by the measurements above that the OEM needle (non-USA is essentially the same except adjustable), FP, and KTM needles are quite similar.
Regards,
Derek
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 09-30-2012 at 07:38 AM
Old 09-30-2012, 07:44 AM   #69680
805gregg
Just Stroming along
Oddometer: 1,559
Check over at DRRidders
805gregg is offline   Reply With Quote
Old 09-30-2012, 07:53 AM   #69681
TrophyHunter
Oddometer: 2,212
I'm pretty sure Jeff has tested it out.... http://www.procycle.us/info/articles/dr650/780-kit.html
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 09-30-2012, 08:23 AM   #69682
Rumlover
Ed
Oddometer: 707
Originally Posted by eakins View Post
great visuals!
I am pretty sure the numbers in the chart represent the area left open around the needle -- not the needle diamenter. So it is a little confusing. The KTM one is actually slightly thinner throughout then the (DR) OEM.
Also the KTM needle is slightly longer because it was designed to be used with the white spacer and an additional (KTM) washer under that, so I am assuming it would sit basically at the same height as the DR needle.
Edit: Just speculating here, but the additional metal washer/shim on the KTM may have been to protect the white spacer from wear because of the vibrations from the KTM motor. The extra weight of that washer (added to the overall slide weight) may have also contributed to the reason why the KTM slide had two lift holes, to optimize slide lift.
Rumlover screwed with this post 09-30-2012 at 09:18 AM
Rumlover is offline   Reply With Quote
Old 09-30-2012, 08:24 AM   #69683
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,262
The stock seat bolts are turned to a bit of point (at least mine are) to make it easier to start them when the seat is fightin' yah.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 09-30-2012, 08:42 AM   #69684
sandwash
sandwash's Avatar
Oddometer: 1,357
I hear ya,it's just back to the bolt store to get another bolt that went missing.The last one was a heat shield bolt.The last one lasted 3 years
Bike Runs very well and strong.Move up to 7000',had to change out the pilot down one size(turning it did nothing till fully closed) and the needle clip lower one slot.Plugs alittle dark.The thing starts up at 40 degree weather on one or two rev with no choke.All in all very happy with it
Other than the horn bracket breaking in half again,it's all good.
97dr650
Old 09-30-2012, 08:48 AM   #69685
procycle
procycle's Avatar
Oddometer: 2,306
Yes. One time I had the half full Safari off the bike for a week. The tank spread so much that the front brace holes were 1-1/2" off! I had to wrap a ratchet tiedown around the tank to squeeze it enough the get the brace bolts in. It was a major PITA.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle screwed with this post 09-30-2012 at 10:10 AM
procycle is offline   Reply With Quote
Old 09-30-2012, 09:33 AM   #69686
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,822
oh man you're right. i was reading that inversely. thnx.
Alaska
Old 09-30-2012, 10:04 AM   #69687
motolab
motolab's Avatar
Oddometer: 2,621
great visuals!
Aside from the clarification by Rumlover about exposed area (thanks Rumlover!), also note that except for the DJ needle, the chart seems to be arranged with the tips even, which isn't all that useful. It would be better to look at mxrob's chart with the diameters, simply because the measurements are all taken in relationship to distance from the third clip (when adjustable).
As shimming the needle clip preloads the slide spring beyond standard, it results in lowering the slide rather than raising the needle. I would not shim the needle clip unless the goal is actually to lower the slide for a given intersection of throttle angle and rpm. Note that the additional preload from shimming the needle will also make the slide come off the stop at a later point in terms of rpm and throttle position (i.e. more velocity will be required to get it to come up off of the stop).
Regards,
Derek
motolab is offline   Reply With Quote
Old 09-30-2012, 10:14 AM   #69688
ER70S-2
ER70S-2's Avatar
Oddometer: 6,453
The thing starts up at 40 degree weather on one or two rev with no choke........
This normally means the idle circuit is too rich and could be wasting fuel once the engine warms up. But you're happy with it, so theoretical guessing on my part is irrelevant. I'm just jealous that you have a TM-40 and I don't.
Yes. One time I had the half full Safari off the bike for a week. The tank spread so much that the front brace holes were 1-1/2" off! I had to wrap a ratchet tiedown around the tank to squeeze it enough the get the brace bolts in. It was a major PIA.
Dang, 1-1/2" is a bunch. I'm glad you measured it to give others an idea of what to look for.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 09-30-2012, 10:15 AM   #69689
Rumlover
Ed
Oddometer: 707
Regards,
Derek
The only issue I have with mxrob's chart is that it doesn't show the white spacer (or the metal KTM shim) under the clip. That is the stock configuration, and would put the bottoms of the needles (KTM vs DR) at pretty much the same height.
Just the addition of the white spacer alone would put them a lot closer.
Also I believe the general consensus is that the DJ needle in that chart is meant to sit at the bottom of the slide (along side the shelf, not on the shelf). This would also make its installed height a little closer to (DR) OEM then pictured in the chart.
Not sure how the Procycle needle falls in there height wise compared to OEM. A lot of variables to be sure.
Rumlover screwed with this post 09-30-2012 at 11:06 AM
Old 09-30-2012, 10:52 AM   #69690
sandwash
sandwash's Avatar
Oddometer: 1,357
"This normally means the idle circuit is too rich and could be wasting fuel once the engine warms up. But you're happy with it, so theoretical guessing on my part is irrelevant. I'm just jealous that you have a TM-40 and I don't. "
Well it's a FCR-MX,almost the same thing
97dr650
Times are GMT -7.   It's 07:12 PM.
