Old 09-30-2012, 11:52 AM   #69691
sandwash
sandwash's Avatar
Oddometer: 1,334
Originally Posted by sandwash
The thing starts up at 40 degree weather on one or two rev with no choke........
"This normally means the idle circuit is too rich and could be wasting fuel once the engine warms up. But you're happy with it, so theoretical guessing on my part is irrelevant. I'm just jealous that you have a TM-40 and I don't. "
Well it's a FCR-MX,almost the same thing
97dr650
sandwash is offline   Reply With Quote
Old 09-30-2012, 12:03 PM   #69692
MADurstewitz
MADMark
Oddometer: 159
Originally Posted by V8 View Post
So, does anyone here have a 790 or 780 kit installed?
790. Yes! I love it! While I was in there (bearing failure made me rebuild the motor) I put in skf bearings and kibblewhite valves as well. Lots of smooth power. Bike goes like hell and still gets great mileage.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 09-30-2012, 01:14 PM   #69693
ER70S-2
ER70S-2's Avatar
Oddometer: 6,130
Oops.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 09-30-2012, 05:11 PM   #69694
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Thumper Dan View Post
Getting the Safari tank back on was the marathon of the day. The alignment with the brackets seems to change every time I take it off and back on again. I seem to be coming up with new techniques to get the bloody thing back on.
I may start a "how to put the safari tank back on hints and tips thread page"..............is there one out there already.
anyway, thanks for all the feedback (again)
I didn't realize the Safari was difficult to remove/replace. If that's the case with ALL of them ... then definitely not for me. I've taken my IMS off and on at least 30 times in just the last few years. I routinely take the tank off for any maintenance or Carb tuning. Very handy with the IMS, which comes in just minutes. I've done it on the road in Mexico, never a problem.
Access is important to me ... and is a BIG PLUS on the DR650 in general.
I see guys on BMW's sweating in the hot sun, going through 30 minutes of struggle just to get down to something.
The IMS and new Acerbis give over 230 to 250 miles of range (depending how bike is tuned) . Plenty of range for this continent ... Oz is a different world of course.
Old 09-30-2012, 05:23 PM   #69695
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,456
I got 60 miles to the gallon on one tankful recently. Almost 300 mile range on that tank. (IMS tank) I've gone to a 16-tooth front sprocket.
windigo
Old 09-30-2012, 05:30 PM   #69696
Thumper Dan
Oddometer: 325
It only seemed on this occasion that it was difficult to get back on. Previous times, it aligned more or less straight away. As I mentioned earlier, the tank had a lot of fuel in it so may have been "flexing" a bit.
Even though it can create some issues, I still love my safari tank and the range I get with it. Even the fact I don't have to go into and fuel up is such a convenience. Last time I fueled up I had 732km and still hadn't hit reserve.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 09-30-2012, 06:03 PM   #69697
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
Question
Friends
somebody rescue me from the "First Gear Clunk"... My 97 has a bad case of it. I've replaced the clutch cable, adjusted, adjusted, adjusted, adjusted, changed the oil [currently running Rotella HD 15/40], sacrificed two chickens and a snake, all to no avail. Strained my old oil for any telltale signs and found NO debris at all, though I tried hard. nothing on the magnetic plug either
mine, like others have reported, is sensitive to temperature and engine speed, and of course, movement. just move it forward at slow walking speed and its really happy. move it backward and its nasty. cold it behaves ok. warm it is more cooperative. hot its ugly.
upshifting to 2nd is almost as dicey, and downshifting from 3rd to 2nd is like dropping off a ledge
suggestions?
Zapp
"I will not let the White City fall... nor our people fail.” - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 09-30-2012, 06:50 PM   #69698
TRAVELGUY
Old Traveler
Oddometer: 637
Grifter the Safari isn't a big problem to remove/reinstall once you've done it twice. I had a IMS on my previous DR and now that I've have a Safari I wouldn't trade it for 3 IMS's. I'm big on accessibility also and can remove my Safari in less than and extra minute more than my IMS and reinstall with a extra two minutes over the IMS. Since both of us have done some serious Central America travel we both understand ease of maintenance "on the road".
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 09-30-2012, 07:45 PM   #69699
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,687
Originally Posted by Zapp22 View Post
Friends
suggestions?
Pull the clutch and check that the metal plates are clean and flat. If they are warped and/or contaminated that can cause drag. Also take a look at the fingers on the clutch basket and see if the sides that engage the fiber plates are smooth. If these are not smooth, they can cause the clutch to stick too. Make similar checks with the metal plates and the clutch hub.
Mine shifted better after I changed to Valvoline 20W-50 synthetic blend.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 09-30-2012, 08:03 PM   #69700
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,463
Originally Posted by Rumlover View Post
The only issue I have with mxrob's chart is that it doesn't show the white spacer (or the metal KTM shim) under the clip. That is the stock configuration, and would put the bottoms of the needles (KTM vs DR) at pretty much the same height.
Just the addition of the white spacer alone would put them a lot closer.
Also I believe the general consensus is that the DJ needle in that chart is meant to sit at the bottom of the slide (along side the shelf, not on the shelf). This would also make its installed height a little closer to (DR) OEM then pictured in the chart.
Not sure how the Procycle needle falls in there height wise compared to OEM. A lot of variables to be sure.
That is where i put mine, i had to turn the C clip to where the opening would sit sit along the wall ( flat side ) of the shelf, that way it would go all the way down and not be in a bind or cocked to the side.
ChromeSux is offline   Reply With Quote
Old 09-30-2012, 09:56 PM   #69701
V8
Oddometer: 9,321
V8 is offline   Reply With Quote
Old 10-01-2012, 12:05 AM   #69702
greystoke
2 wheel whore
greystoke's Avatar
Oddometer: 123
Originally Posted by TRAVELGUY View Post
I found mounting and remounting my Safari tank a challenge also. Increasing the hole size and elongating in the bottom mount brace made the job easy.
TravelGuy
Prolly common knowledge but when putting the thing back together I do the 2 bolts on the bike (under the seat) first. It's a shedload easier to wiggle the wings into position than to get the under seat holes to line up. Was a 'duh' moment for me after much swearing.
2 Brothers,
2 Scooters,
25,000 kilometres.
www.rightaroundaustralia.com
PX200
'86 K100RS
K7 DR650SE
greystoke is offline   Reply With Quote
Old 10-01-2012, 08:43 AM   #69703
procycle
procycle's Avatar
Oddometer: 2,252
If you're just pulling it off and going to put it back on right away it's not a problem. I believe the problems come it when the tank is off for a couple of days or more and has fuel in it. Mine is off right now and since I knew it would be off the bike for more than a week I drained it and attached the front brace.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-01-2012, 09:25 AM   #69704
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,951
Ethanol may be responsible for the expansion of these plastic tanks. Ducati's amoung many others have serious expansion problems. http://deformedfueltanks.com/
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 10-01-2012, 10:09 AM   #69705
wipe-out
wipe-out's Avatar
Oddometer: 201
wanting to rent a bike for a trip in costa rica, i'm asking myself whether a dr650 would be a good choice travelling 2-up (girlfriend and me, together about 280 pounds) for two weeks with the necessary luggage (maybe a giantloop + a bag)? the dr would most likely be stock, i don't think that there's any upgrades on the bikes in regards to suspension etc. other options include f8gs & lc4, lc8. no personal experience with the dr. thoughts?
wipe-out is offline   Reply With Quote
Times are GMT -7.   It's 01:54 AM.
