Old 10-06-2012, 06:39 AM   #69841
planemanx15
planemanx15's Avatar
Oddometer: 1,007
In other news, I finally got to ride after a wet week. I was able to put my rear through its paces again with the new oil and spring. There is no off roading near me (that's legal, and as a soon to be federal employee I refuse to chance it). The bike is so much more controlled, and it actually feels like it has a more aggressive stance. The power delivery now is Great since the rear doesn't dive when twisting the throttle. The front wheel is in the air now, a lot lol.
I've learned that more power is nice, but how you control that power makes all the difference.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-06-2012, 08:18 AM   #69842
Escaped
Escaped's Avatar
Oddometer: 478
Well my Intiminators work great, brake dive eliminated, better on and off road performance
I believe isaac004 said he bought his used, so maybe there is an issue with his set?
Originally Posted by ER70S-2 View Post
Crap. I was tempted to try the Intiminators, just 'cause. Now, not so much. I do like my emulators.
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 10-06-2012, 09:34 AM   #69843
disconnected
anti click
disconnected's Avatar
Oddometer: 7,145
Im looking for engine case savers. Im a complete boob when it comes to this bike, but I learn fast. are there any other options than the TT case savers? Just wondering.
greg
IBA # 47004
disconnected is offline   Reply With Quote
Old 10-06-2012, 09:45 AM   #69844
TrophyHunter
Oddometer: 2,192
Here's an option - don't know if it's what is offered on TT
http://www.procycle.us/bikepages/dr650.html#engine
Armor Plating for Engine CasesDR650SE '96-Current
$79.95 - $169.95
Heavy gauge stainless steel case armor to protect your engine cases. These case guards bond to your clutch cover and stator cover with high-temp silicone (not included). Extremely tough protection from rocks! In a fall your brake pedal or shift lever can crack the engine case - leaving you stranded. Don't let it happen to you! Get the case armor or choose our Armor & Skid Plate combo.
NEW COLORS! Skid plates now available in the standard Aluminum finish or NEW Black or Gunmetal powdercoating!
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 10-06-2012, 09:46 AM   #69845
disconnected
anti click
Oddometer: 7,145
Thanks TrophyHunter!
greg
IBA # 47004
Old 10-06-2012, 09:47 AM   #69846
disconnected
anti click
Oddometer: 7,145
Other than a skid plate, are there anyothers you may need or want?
$79.95 - $169.95
IBA # 47004
Old 10-06-2012, 11:18 AM   #69847
thetable
thetable's Avatar
Oddometer: 1,425
Proper hand guards are a must. Nothing like trying to get home with a broken clutch lever.
Are you planning on crashing a lot? Not sure how much this stuff is needed for most crashes, but just like gear, you only need to use it once before it pays for itself multiple times.
Might want to look into some protection for the rear rotor. ProCycle has a weld on shark fin.
Rear master cylinder guard. The MC isn't overly exposed, but I wouldn't want to be without it.
Spend some time at Procycle and see what you want/need, as they seem to carry most everything DR related.
thetable is offline   Reply With Quote
Old 10-06-2012, 11:22 AM   #69848
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I know the Intiminators seem to work for some riders, a good option for those who are bothered by fork dive. But I prefer the wide range of adjust-ability with Race-Tech emulators. The Emulators come with 3 rebound springs (soft, medium and hard) to fine tune rebound feel.
In addition, you can tune further by drilling more or fewer holes in damper rod and vary diameter of holes. Then you've got oil weight and oil height to play with, plus spring rates and preload.
You could end up chasing your tail ... but might be worth trying different settings until you get something close to perfection. Mine is perfect and a great compromise between street and dirt.
Fork feel is subjective. If a pro sets up your emulators ... they may not always work for you. Depends what you're used to, how you ride and balance of street vs. off road.
Old 10-06-2012, 12:19 PM   #69849
ER70S-2
ER70S-2's Avatar
Oddometer: 6,296
Originally Posted by planemanx15 View Post
Progressive springs from procycle. 200 ready to ride. How can you tell if you have the right amount of preload? I don't have the noise that isaac004 has, but the springing back to the top issue.
Easy: stock = too much dive, +1/2" = too harsh, +1/4" = too much dive, +3/8" at our weight = bingo. These numbers are in addition to the stock springs and spacers. Since you have progressive springs which are stiffer than stock, I'd go with 1/4".
Good info. I'm happy with the emulators, first bike I've owned with a plush suspension (Cogent shock w/rebound on the back). I'm just curious about the differences between the two.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-06-2012, 01:39 PM   #69850
deathu
deathu's Avatar
Oddometer: 77
Originally Posted by procycle View Post
I don't know if this was mentioned but sometimes it helps to tighten up the motor mounts with the motor at full operating temperature.
Originally Posted by Rusty Rocket View Post
part # 29 is the bolt through the head
http://www.ronayers.com/Fiche/TypeID.../CYLINDER_HEAD
and the plates shown here as #5:
http://www.ronayers.com/Fiche/TypeID..._MODEL_T_V_W_X
Thanks for your suggestions, I did check all of the above mentioned items today, and torqued the mounts while the engine was warm.
Unfortunately I don't have any positive results, the vibration levels are unchanged.
Since I have no other "easy" things to check, I guess I'll take a deeper look into this vibration issue this winter when I'll take the top end apart for replacing the leaky base gasket. Hope I'll be able to see if the counterbalancer is installed/aligned correctly when the cylinder is removed from the engine, through it's opening. I don't want to split the crankcase unless strictly necessary.
deathu is offline   Reply With Quote
Old 10-06-2012, 03:24 PM   #69851
alonzo
Misadventurer
alonzo's Avatar
Oddometer: 419
greg
Here are some case savers (maybe the TT ones?): http://motorcycleproducts.org/Engine...n-frameset.htm
-- alonzo
2006 Suzuki DR650SE
1978 BMW R80/7
2009 BMW F650GS (do you think a new BMW every 30 years is too much?)
2006 Yamaha XT225
1970 Triumph Bonneville T120R
"The difference between genius and stupidity is that genius has limits."
Ąsǝʞıq ʇɹıp ɟo ɟɟo ʎɐʇs pןnoɥs noʎ ǝqʎɐɯ uǝɥʇ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
alonzo is offline   Reply With Quote
Old 10-06-2012, 05:21 PM   #69852
cemory
cemory's Avatar
Oddometer: 55
ColoradoSept 26,27,28,and 29th 2012
Went riding with my buddies just north of woodland park,colorado. Had a great time but did see a small amount of bad weather on 1 of the days there.
Pikes Peak in the background.
Links below are to a couple of short videos I took while there.
1st is of a scenic overlook spot we stopped at to take a breather and enjoy the view.
2nd video is of a hail storm we got caught in about 5 miles from our camp, my buddy and I had just pulled in to our camp and jumped under our tarp.
http://s842.photobucket.com/albums/zz346/cemory/?action=view&current=colorado2012011.mp4
http://s842.photobucket.com/albums/z...ado2012001.mp4
cemory is offline   Reply With Quote
Old 10-06-2012, 07:01 PM   #69853
badweatherbiker
badweatherbiker's Avatar
Oddometer: 705
Looking at trading my 2004 Yamaha FZ6 for a 1996 DR650 with low miles and looks to be in great condition, am I crazy?
The guy is asking 2700 for the bike and mine is worth a little more maybe 3000 - 3200.
The DR has a FMF pipe and has supposedly been jetted for it and everything else is stock. What should I look for, I commute 100 miles a day is this thing reliable and able enough to make it? about 20 of that is interstate travel the rest is back roads. What about tank range, the FZ will take me about 250 miles on a tank of gas what about the DR? I also get 50 mpgs is this about the same?
Ken
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker screwed with this post 10-06-2012 at 07:04 PM Reason: more questions
badweatherbiker is offline   Reply With Quote
Old 10-06-2012, 07:18 PM   #69854
disconnected
anti click
Oddometer: 7,145
I would try and be patient and sell youre bike first. I just bought an 02 from a Harley Guy who kept it immaculate and in show room condition for 2500.00 locally. The 96 sounds to be a unfair trade for you. the 02 came with 5xxx miles and extra chain and sproket a tail bag and a new battery tender still in the box.
greg
Ken
IBA # 47004
Old 10-06-2012, 07:39 PM   #69855
thetable
thetable's Avatar
Oddometer: 1,425
NADA puts an EXCELLENT condition 96 at $1600. At 2600, dude doesn't want to sell his bike.
Times are GMT -7.   It's 05:49 AM.
