Old 10-09-2012, 10:28 AM   #69901
TrophyHunter
Oddometer: 2,192
http://www.atomic-moto.com/boots.html
I usually give Brian at Atomic Moto a look for boots. Some stuff you don't see everywhere. I went with the Gaerne SG-10's for my more adventurous rides and the Gaerne G-Adventure for most of my stuff. I also picked up a brand new pair of A-star "no stop" trials boots from CL at a "I don't really need 'em but I can't pass 'em up" price.
Brian is a vendor on ADV and has outstanding customer service.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 10-09-2012, 11:00 AM   #69902
isaac004
isaac004's Avatar
Oddometer: 821
Originally Posted by Ren20 View Post
Thanks, new to dual sport. a lot to learn. first to get proper boots. I don't think my racing boots work for this application.
I do all my DS and ADV riding in Side Flex Force boots, which are quite hefty.
Yes they are big and clunky, but I have gone on 3 week rides (the Continental Divide Ride) in them without any issues. I just bring a pair of flip flops with me, so at lunch breaks I can air my feet out. Makes a huge difference.
isaac004 is offline   Reply With Quote
Old 10-09-2012, 11:03 AM   #69903
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by canoli View Post
For now I'm just going to leave it alone and before I head out to the middle of nowhere try to run my tank dry.
Thanks guys for the info. You just saved me from screwing up my carb.
Cheers,
Canoli
I've rotated the fuel tube on three BST carbs, no issues at all. Two were my Carbs, one on a friends bike.
It's technique, not technical.
I did this Carb on bike. Tank off and out of way. I used big Channel Lock pliers, a BIG Crescent wrench can work also. I placed a piece of inner tube on the fuel tube to protect. Grab the entire length of tube with pliers, applying even pressure.
I rotated to 9 O'clock position (some go to 3 O'clock position). Steady, firm pressure (NO HEAT) and she moved smooth and easy on all three carbs.
Access is important to apply even pressure along the length of the tube. So use the right tool or remove Carb.
The result added "about" 20 miles more range on my IMS fuel tank.
Does the Safari have dual petcocks? (right and left). I recall some mention of that. If not, maybe add another petcock?
Good luck.
Old 10-09-2012, 11:27 AM   #69904
Adv Grifter
Oddometer: 6,128
Hi guys,
Is a 2001 dr650SE with 7000 miles for $2000 Fair? Seller wouldn't go down in price. It's a clean bone stock example. I think nada value is about $1600 for that year. Been looking for one for a while. But no luck. Not many people selling. And ppl want $4500 + for newer years in North east.
updated info, it does have extra gas tank and skid plate. I think that's about it.
Thanks in advance
Could be a good deal if that mileage is true. So easy to disconnect ODO.
Sadly, many fudge ODO readings.
Try to find a good mechanic to come with you to check bike out. Have a close listen and nice test ride. Sound can tell you a lot on a DR650. Listen for changes from Cold to Hot. Look at oil, shift through gear box.
Check underside for off road damage (linkage, case, bash plate, underside of swing arm, fork ends ... all can show damage from off road use/abuse)
chances are good its a great deal. Best!
Old 10-09-2012, 11:43 AM   #69905
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,137
I have the AXO Boxer boots that Atomic sells and I couldn't believe what a nice boot it was for the money.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-09-2012, 11:45 AM   #69906
Feelers
Oddometer: 187
Wicked Intiminator Clunk Cause
Originally Posted by isaac004 View Post
OK, another update here.
I was trying to avoid just straight up removing them, but I figured it was worth a shot. So today I had a free hour and decided to pull out the Intiminators to see how the fork action is. I did not bother to add more oil (as the oil height dropped), add preload (to keep the same preload I should add around 3/4" extra in PVC pipe, or bump the oil viscosity up (with the Intiminators removed I should go back up to around 10 wt, as Ricor recommended a lower 5 wt). I will do these things later.
The fork action has pretty much returned to normal, in regards to no more excessive binding, easier to compress, and it rebounds back to normal ride height without me having to "pull" it up. There is still a slight amount of stiction, more then my F800GS or WR250R, but hey, it's a low tech DS bike without nice USD forks, so it feels pretty damn good now for what it is.
For now I will just return to a higher viscosity oil and leave the Intiminators out, more or less a stock fork setup.
Hey Isaac!
I love how my intiminators work, so I'm hoping to help you fix yours and experience the goodness!
Because I am a nerd, I did a bunch of research on your intiminator fork clunking. I am pretty positive I know what's causing that clunk, and probably the lack of rebound. Essentially, the intiminator is floating off its seat on top of the damper rod due to pressure overwhelming the spring during the compression stroke and when the downward movement of the fork tube stops, the intiminator gets pushed down by the spring against the damping force until it contacts its seat. Hopefully, that makes sense.
So, how can you correct it?
There are 3 possibilities:
First, and most lame is defective valving inside the intiminator. We'll skip that for now because a replacement is the only solution. I think this is also unlikely.
Second is spring rate. I'm not sure which springs you are using - whether stock or aftermarket, but since the spring rate is sort of being overpowered by the damping rate, it's possible that using stiffer springs might help. Adding more preload to your springs also might help. However, the intiminators are designed to be used with the stock springs I'm pretty sure, so the spring rate should not be the issue. I wouldn't swap springs just as an experiment...
Now for the most likely culprit. I've heard that these intiminators are pretty sensitive to oil viscosity, and they are designed and tuned at the factory using Amsoil 5WT fork fluid. When I installed my intiminators, I was very careful to find the best alternative to the amsoil. WT has almost nothing to do with viscosity.
Oil........................Viscosity @ 40degC................Viscosity @ 100degC............Viscosity Index
Amsoil #5..................5.7........................... ................4.4............................... ..............210
Maxima 5wt..............15.9............................. ............3.5................................... ..........150
Your fork oil will typically be nearer to the 40degC mark, so that is the main number to look at. Your viscosity (resistance to flow) is triple the design viscosity and likely the reason the intiminators are having problems flowing the oil fast enough. Amsoil has an unusually low viscosity somehow.
You can select a better oil from the chart at the bottom of this page:
http://www.peterverdone.com/archive/lowspeed.htm
FWIW, I used Torco RFF 5 with a 40degC viscosity of 10.75 which works well. I bought it because of price/availability, but the damping at high speed is a bit harsh. It's still much better than stock, but the Amsoil #5 would almost certainly be the best.
Feelers screwed with this post 10-09-2012 at 11:47 AM Reason: formatting
Feelers is offline   Reply With Quote
Old 10-09-2012, 11:50 AM   #69907
Ren20
Finding Touge
Oddometer: 111
thanks for the tip. I already bought it. My uncle picked it up. uncle said the bike looks excellent. The seller was very nice as well. I won't be able to see it until the weekend.
Here's the picture.
Ren20 is offline   Reply With Quote
Old 10-09-2012, 11:58 AM   #69908
mud390
mud390's Avatar
Oddometer: 162
Wanting to get everyone's thoughts on a DR650 I'm looking at buying. The bike is a 2006, single owner, with just over 8000 miles. Has a full FMF setup, TM40 carb, brand new set of 17 supermoto wheels with brand new tires, new Trail Tech vapor, new 520 chain and sprockets (stock gearing), extra fork, dirt wheels (rear hub is trashed), 320mm front rotor, stainless brake lines, and all the stock parts. Bike is real clean and well taken care of. The guys is asking $3000 for it. Thoughts?
mud390 is offline   Reply With Quote
Old 10-09-2012, 12:01 PM   #69909
neo1piv014
ADV in training
Oddometer: 619
Jump all over it. Assuming you want the supermoto setup (which is awesome), that's every awesome mod you'd want to do besides the big bore kit.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-09-2012, 12:18 PM   #69910
isaac004
isaac004's Avatar
Oddometer: 821
Originally Posted by Feelers View Post
Hey Isaac!
Thanks for all of the tips!
I am using stock springs with some preload...I have not measured it, but I do have to compress the spring about 1 inch to get the fork caps to start engaging the threads.
You make a very good point about the oil, although Amsoil's webpage says the following (http://www.amsoil.com/storefront/stl.aspx):
Kinematic Viscosity @ 100C, cSt (ASTM D-445)
4.4
Kinematic Viscosity @ 40C, cSt (ASTM D-445)
15.7
So to correct your chart, it would read as follows:
Amsoil #5..................15.7.......................... .................4.4.............................. ...............210
When I called the Ricor guys up in Nevada, they said that if Amsoil is not available, Maxima would be a very good alternative. The kinematic viscosities are very similar. Your #3 theory does make sense, although I still think there is some physical binding since the fork does not want to return to normal ride height at all. If the oil was too thick, it should rebound back to normal ride height, just very slowly.
I think the Ricor unit still might be defective. Though I still may also buy some Amsoil #5 fork oil if I can track some down.
Thank you for the insight though, I enjoy the discussion going on here.
Old 10-09-2012, 01:01 PM   #69911
Escaped
Escaped's Avatar
Oddometer: 473
He already bought the bike and it looks great in the photos.
Hey for a story I read somewhere -
This guy bought a used motorcycle with very low miles and after buying he said to himself "I really took advantage of that seller, what an astute buyer I am!"
Well he had the bike a few years and really racked up the miles. It was time to sell the bike and he told himself "There are too many miles on this bike to get a good price, I will just turn back the OD so I can get a better deal, what an astute seller I am going to be!"
Well he took apart the speedometer to get at the OD and found a note. The note said "Oh No Not Again".
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 10-09-2012, 01:25 PM   #69912
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,550
Acerbis tank and available fuel to the engine
Wow, I have the Acerbis 5.3 gal tank. Well I just had it trucked home from California using Allied after my 2,600 mile offroad trip out there. Last Friday the truck arrive with all the bikes. I start mine using the ON position of the petcock. She stumbles on idle, I swithc to reserve, she lights up.
I think to myself, I know I had a few gallons in there when I dropped the bike off in Reno wtf ?
I baby it to the Shell 4 miles from my house. She drinks 5.2..something gals !
So Im making 2 points.
1. For the 1st time Allied has drained the gas tanks or the driver was simply stealing it, as they have never done that before and I have used them many times.
2. You can get just about all the usable fuel out of that tank before you'll push.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 10-09-2012, 01:37 PM   #69913
Feelers
Oddometer: 187
Hahahaha.....The amsoil publication that I got 5.7 from must have erroneously left off a 1. Nuts! So much for that theory! 15.7 does make a heck of a lot more sense.... Your video does sound exactly like the intiminator is floating above it's seat though.... I guess you should try to poke around at the intiminator and see if any of the passages are blocked or the valves are sticky. Maybe clean it up? Maybe take it apart? Maybe the rebound circuit is blocked or something....
Old 10-09-2012, 01:38 PM   #69914
procycle
procycle's Avatar
Oddometer: 2,276
Check to see that all that gas isn't in the crankcase with the oil.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-09-2012, 01:46 PM   #69915
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
I'm using 5mm of preload and no problems with stiction or returning to full height.
What spacers were you running?
Ricor recommend running the stock spacers, uncut.
Easier to compress without the Intiminators? It should be, the anti-dive is one of the selling points.
DR650 Wiki
NordieBoy is online now   Reply With Quote
Times are GMT -7.   It's 01:19 AM.
