Old 10-02-2012, 05:08 PM   #69916
deathu
deathu's Avatar
Oddometer: 73
Hi,
I recently had a chance to swap bikes for a few miles with a buddy, he has a '96 model, mine is a '98. One thing struck us both, which is the huge difference in the level of vibrations between the two bikes, which are after all the same model. The first thing he said after riding my DR was "dude, your bike vibrates a lot". Also I felt his bike vibrated MUCH less.
To give an quantitative example, on his bike I was doing 110km/h (68mph) in the 4th gear and felt it was not asking much, the bike could easily do more. On my bike, if I go over 110km/h in 5th gear I feel that i'm asking too much from the engine. Notice the difference, at this speed his bike was in 4th gear and felt butter smooth, mine was in 5th and felt stressed.
Ok, there is a small difference in gearing, I am running 15/43 while he is using the stock 15/41 gearing. The gearing difference is minimal however.
Apart from that, both bikes are almost stock. Stock carbs, snorkles in place, performance pipes installed to save weight.
The difference between the two bikes was absolutely huge, this seriously got me thinking maybe something is wrong (maybe valve timing, maybe the balancer is not installed coorectly, who knows what else....). I would say that, for example in 4th gear, his DR ar 110km/h (68mph) is as smooth as, or smoother than mine at 80km/h (50mph).
So I am asking you, how fast should a stock DR go and still feel smooth?
deathu is offline   Reply With Quote
Old 10-02-2012, 05:13 PM   #69917
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,772
Did you check the chains to see if one was bad and the other good? Back when we used Chain Wax, I could hear the chain on my wife's Monster when I was riding behind her. Switched to proper chain lube and a new set of chains and sprockets and never had that problem again.
A tight or kinked chain can make such a big difference to a bike's feel.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 10-02-2012, 05:14 PM   #69918
barko1
barko1
barko1's Avatar
Oddometer: 2,511
Smooth is awfully relative so pretty hard to give anything but a subjective answer. Mine seems fine at 70 mph, until I get on my Concours 14 then I remember what real smooth is. Perhaps you have bad or improperly torqued engine mount bolts??
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi
barko1 is offline   Reply With Quote
Old 10-02-2012, 05:32 PM   #69919
deathu
deathu's Avatar
Oddometer: 73
The chain on my bike has under 1000 miles, installed with new cush drive rubbers and sprockets, and also with sufficient sag. I know how much problems an incorrect chain setup can create... had serious chain issues on one of my other bikes. By comparison the chain I installed on the DR is very quiet... actually I couldn't hear it at all, even when I had the stock muffler.
70mph, in 4th or in 5th gear? My buddy's bike felt really smooth in 5th gear up to around 85mph (130-140km/h). I know this is a subjective matter, but common sense applies I think... there's no way my bike would go over 120km/h without feeling it's going to disintegrate really soon.
Thanks for the engine mounting bolts tip, I'm going to check that.
Old 10-02-2012, 05:48 PM   #69920
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,040
I typically haven't been over 80mph and very seldom. I've actually never been on the interstate on my bike, all rural highway, rural road and dirt. When I have cranked it up a little to pass a car on the highway I've gotten to 80mph in 5th and it was smooth. It felt very smooth in fact; HOWEVER, I recently put knobbies on and whoa! what a difference. It's night and day. The knobs are squirrely, vibey, etc. I ride 5 - 7 days a week. Rode one day at 80mph, the next with knobs and wow.
I don't know if your bikes are set up the same other than gearing, but realize you're turning about 5% higher RPM at any given speed. If your tires aren't the same, it could account for a LOT of vibes compared to more road oriented tires.
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is online now   Reply With Quote
Old 10-02-2012, 06:11 PM   #69921
deathu
deathu's Avatar
Oddometer: 73
Indeed knobby tires do add some vibration, but the vibration I have is much worse than that caused by knobby tires alone. I currently have Pirelli MT21s on the bike. If I grab the clutch lever at speed and let the engine idle, the vibration level drops significantly, even though the bike is still rolling at 110km/h on those MT21s. This makes me think that the actual source of the worst vibrations is the engine itself, unless I am overlooking something...
Old 10-02-2012, 06:12 PM   #69922
doug s.
Oddometer: 1,166
Indeed knobby tires do add some vibration, but the vibration I have is much worse than that caused by knobby tires alone. I currently have Pirelli MT21s on the bike. If I grab the clutch lever at speed and let the engine idle, the vibration level drops significantly, even though the bike is still rolling at 110km/h on those MT21s. This makes me think that the actual source of the worst vibrations is the engine itself. Am I overlooking something?
maybe the counterbalencer is off?
doug s.
doug s. is online now   Reply With Quote
Old 10-02-2012, 06:18 PM   #69923
wee-twin
Oddometer: 141
On my recently acquired DR I get vibes under load such as acceleration or climbing a hill. I already checked motor mounts, but I am suspecting chain. Bike had 14 countershaft sprocket when I bought it. Only 7000 on bike. Any ideas how to tell if chain/sprockets are causing this? Oh, I checked the cushdrive and rear bearings.
wee-twin screwed with this post 10-02-2012 at 07:10 PM Reason: More info
wee-twin is online now   Reply With Quote
Old 10-02-2012, 06:30 PM   #69924
deathu
deathu's Avatar
Oddometer: 73
doug s.
This deffinitely is one of the possibilities I am thinking about. Until now I understand that the possible causes may be:
- enine mounts not torqued correctly
- counterbalancer off by a few teeth (I don't know the history of the engine, I don't know if it was opened or not)
- valve timing may be incorrect (camshaft may be off by one tooth? would the engine even work in this situation?)
Any other possible causes?
LE. Just rode from work to home, and I did a new test. Got to a speed where the vibrations were problematic, grabbed the clutch, let the engine idle for a second then revved it to about the same RPM it was running before, while still holding the clutch. The bad vibes came back, the same as under load. I think this eliminates the drive train as a possible cause...it must be the engine
deathu screwed with this post 10-02-2012 at 07:50 PM
Old 10-02-2012, 06:46 PM   #69925
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 738
Hey everyone, I'm hoping to get back into dualsporting after some time commuting on a street bike.
I have a 1990 Honda Pacific Coast 800 in pristine condition that I am looking to trade for a DR 650. I'm in the Vegas area, so if you know anyone nearby that is looking for a street bike, send them my way, thanks!
nigelcorn is online now   Reply With Quote
Old 10-02-2012, 07:13 PM   #69926
ram1000
ram1000's Avatar
Oddometer: 1,710
Does it have a high compression piston? Mine does and it is smooth until I use the power. Cruising its just fine.
Chrome and noise are no reason to ride a motorcycle!
:2002 KTM 640 DS :2003 Suzuki GSXR1000
:2005.5 KTM 950 :2007 VStrom 1000
:2008 DR650 :2009 Aprilia DorsoDuro
:2009 KLR 650 :more to come
ram1000 is offline   Reply With Quote
Old 10-02-2012, 07:38 PM   #69927
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,763
Look down and see if the front of the chain is jumping around.
If the vibes smooth out under heavy acceleration, then it's probably the chain.
NordieBoy is offline   Reply With Quote
Old 10-02-2012, 10:49 PM   #69928
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 3,744
I run over 90MPH (indicated) for miles at a time out west. With 16/46 sprockets, 90/90-21 front Shinko 244, and a 130/80-17 rear Kenda K761, the DR feels fine.
Kommando is offline   Reply With Quote
Old 10-03-2012, 12:57 AM   #69929
Thumper Dan
Oddometer: 214
I remember on this very forum (the only one I really read ) and someone was having similar issues with vibration and thought it was the chain etc etc. It turned out to be dodgy cush drive rubbers. He replaced them and everything was fine again.
Its going to be a process of elimination unfortunately. Do the simple things like the chain sprocket replacement.......check. Engine mounts are torqued to correct spec.........check. Cush drive rubber replacement........check (you get the idea). If it isn't the parts that I just mentioned, at least you'll have spares and peace of mind that you've eliminated them. Not sure about the counter balance and how to remedy but maybe Jeff from procycle can chime in :)..
But please make sure you let us all know what happens so this library of info keeps building.
good luck
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
Thumper Dan screwed with this post 10-03-2012 at 01:02 AM
Thumper Dan is offline   Reply With Quote
Old 10-03-2012, 02:28 AM   #69930
BergDonk
BergDonk's Avatar
Oddometer: 1,637
Originally Posted by Adv Grifter View Post
My DR clunks pretty good going into 1st also. The 1st to 2nd shift I do kinda slow, and that seems to help. Not much I know to make that clunk go away.
I know sometimes different oil seems to help. But (for me) as oil wears down seems the clunk becomes more severe.
I use Mobil One synthetic Car oil (for High Mileage cars) It has no friction modifiers. Been using it for 35,000 miles now.
I usually mix in about a half quart of Chevron Delo 400 (Dino oil) with the Mobil One. Seems to work well and shifting is better for about 1000 miles ... then clunk returns.
But I believe the Delo may help some .... Strictly seat of the pants call here. Good luck.
IMHO if you notice an improvement in shifting and/or clutch operation after an oil change then you are not changing your oil often enough as its breaking down and your engine is suffering as a result. Forget the Mobil 1 and just use the Delo 400. Not 400 LE, just 400. I also add a splash of Lucas stabilizer, about 5%, and change at up to 4,000 km intervals with no noticable change in behaviour.
shed time IS quality time
Check my DR650 story:
BergDonks DR650 Build
BergDonk is offline   Reply With Quote
Times are GMT -7.   It's 11:02 AM.
