Old 10-03-2012, 03:49 AM   #69931
deathu
deathu's Avatar
Oddometer: 73
Originally Posted by Thumper Dan View Post
I remember on this very forum (the only one I really read ) and someone was having similar issues with vibration and thought it was the chain etc etc. It turned out to be dodgy cush drive rubbers. He replaced them and everything was fine again.
Its going to be a process of elimination unfortunately. Do the simple things like the chain sprocket replacement.......check. Engine mounts are torqued to correct spec.........check. Cush drive rubber replacement........check (you get the idea). If it isn't the parts that I just mentioned, at least you'll have spares and peace of mind that you've eliminated them. Not sure about the counter balance and how to remedy but maybe Jeff from procycle can chime in :)..
But please make sure you let us all know what happens so this library of info keeps building.
good luck
Thanks, but I did replace the cush drive rubbers, along with the chain and sprockets... now I have under 1000miles on the new components. I wish it was that, because it would have been one of the most simple things to fix.
I really hope it's not the counterbalancer being a few teeth off, fixing that would require splitting the crankcase. I don't know if I could even verify this without splitting the case... hope the punch marks are visible when the side covers and top end are off the engine... maybe somebody can confirm this. This will definitely be the last thing to check, if all else fails.
deathu is offline   Reply With Quote
Old 10-03-2012, 04:16 AM   #69932
dryder
Oddometer: 1
Are those plastics still available?
Are the side plastics in good shape? Black right?
dryder is offline   Reply With Quote
Old 10-03-2012, 05:18 AM   #69933
wee-twin
Oddometer: 137
Originally Posted by ram1000 View Post
Does it have a high compression piston? Mine does and it is smooth until I use the power. Cruising its just fine.
No, stock piston. But I do not think a high compression piston is the cause of your vibration. I am far from an expert on this, but you might have the same problem as me.
wee-twin screwed with this post 10-03-2012 at 05:48 AM Reason: More info
wee-twin is offline   Reply With Quote
Old 10-03-2012, 05:30 AM   #69934
wee-twin
Oddometer: 137
Originally Posted by NordieBoy View Post
Look down and see if the front of the chain is jumping around.
If the vibes smooth out under heavy acceleration, then it's probably the chain.
I am running smooth untill I go up a hill or accelerate,then i get the vibes. It is easier to notice going up a hill as i do not have to downshift, but as soon as more load is put on the drivetrain i get the vibes.I am running without the countershaft sprocket cover so I could see if anything does not look right. CC sprocket is a bit worn but rear socket looks fine and with 14t front my chain adjuster is at 4. Chain was filthy and a bit stiff when I got bike, but I have been taking care of it now.
wee-twin screwed with this post 10-03-2012 at 05:49 AM
Old 10-03-2012, 05:44 AM   #69935
wee-twin
Oddometer: 137
good luck
For checking my cushdrive, I did a visual of them and they were not beat up or a sloppy fit. Then with the wheel off the ground and the bike in gear I grabbed the wheel forward and backward to check for slop. Is that an accurate check? I guess as you pointed out, buy a chain set and install each piece till problem solved same with cushdrive. I will have to make order and I will report back. Now I have to decide on which chain and sprocket ration.......
Old 10-03-2012, 06:08 AM   #69936
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,266
Originally Posted by deathu View Post
Indeed knobby tires do add some vibration, but the vibration I have is much worse than that caused by knobby tires alone. I currently have Pirelli MT21s on the bike. If I grab the clutch lever at speed and let the engine idle, the vibration level drops significantly, even though the bike is still rolling at 110km/h on those MT21s. This makes me think that the actual source of the worst vibrations is the engine itself, unless I am overlooking something...
Did you compare the feel of things while in neutral and sitting still. By revving the engines on both bikes? What about pulling in the clutch while at speed to see if it is a chassis/driveline or engine thing?
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 10-03-2012, 08:59 AM   #69937
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,397
This looks like a difficult problem. As mentioned before, sometimes loosening up all the engine mount bolts ... then re-tightening them in the correct order and in steps ... this may help some.
But unfortunately ... it sort of sounds like something in the engine.
Most DR650's, if the drive line is in good shape, run pretty smooth (for a Thumper) at 70 mph to 80 mph. i've had three ... and all were quite smooth at speed.
Can we assume your bike still has standard Suzuki handlebar rubber mounts in place? And, are the rubber mounted foot pegs still in place?
If not ... (and your buddies bike DOES have those things) then that could be the reason for the difference in the two bikes.
I still hold out hope for a cheap and simple solution for you!
All the best!
Old 10-03-2012, 11:21 AM   #69938
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,437
Question CDI from new model in old model?
Hey guys,
I need the help of two DRs for swapping CDIs to confirm something for me. I'm looking for riders in the same location with a 2006 DR and a 1996-1999 one. I'd like to see if plugging in the CDI from the 2006 will work in the 1996-1999 models.
I've had some mechanics in Nairobi take a look at my CDI and just by looking at it they say the CDI is faulty because the blue capacitor has melted part way thru the silicone cover on the bottom of the CDI and there's these small rocks that are stuck to the silicone cover that they say are melted parts of the circuit board. My 98 CDI and the 2001 CDI that I got from South Africa both look like this.
Could someone with a functioning bike please unbolt their CDI and take a look at the bottom and confirm that you can't see a blue capacitor or white stones coming thru?
I have a spare CDI from a 2006 DR sitting in India and it's going to take a few weeks to get to me. I'd like to know if I can rely on that CDI to work in my DR or whether I have to look for another unit.
J A Y on a 98 Suzuki DR650SE (sanDRina)
Trip Website: JamminGlobal.com
Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos
Jammin is offline   Reply With Quote
Old 10-03-2012, 11:59 AM   #69939
deathu
deathu's Avatar
Oddometer: 73
Thanks, I tried that, and the result of all tests seems to indicate the engine itself as the source of the worst vibrations. I mentioned these tests a few posts ago...
All the best!
Can you please tell me the correct order in which the engine mounts are to be tightened? I can't locate this information in the service manual, only the correct torque values are mentioned.
Yes, the bike still has the rubber parts for the handlebar support and footpegs. Actually at sppeeds over 120km/h the vibrations are so bad that you feel them very harsh even through the seat, not only handlebars and footpegs.
On the buddy's bike I felt I could easily cruise all day long at 130 to 140km/h (from a vibration point of view), the only issue would be the lack of wind protection at these speeds.
deathu screwed with this post 10-03-2012 at 12:06 PM
Old 10-03-2012, 12:26 PM   #69940
Escaped
Escaped's Avatar
Oddometer: 265
It is the same process as tightening any multi fastener item. Loosen all bolts, tighten one slightly then tighten the one across from the first one, then slightly tighten the next loose one slightly and the one across from that. Then start over the process by tightening with greater force untill all are tighten up to specification.
PS: Don't break off the bolts! :)
DR650 - Living the Dream!
Escaped is offline   Reply With Quote
Old 10-03-2012, 01:34 PM   #69941
procycle
procycle's Avatar
Oddometer: 1,607
Weird! But apparently normal.
This is the CDI on my 1999:
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 10-03-2012, 02:11 PM   #69942
thetable
thetable's Avatar
Oddometer: 797
Is that a silicone cover or potting compound? Definitely looks like the latter, which would just be poured in and allowed to cure. It is odd that they wouldn't use enough to cover everything though.
thetable is offline   Reply With Quote
Old 10-03-2012, 02:36 PM   #69943
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 1,306
I don't know if I would call that normal... I refuse to pull mine off and look at it now...I do not want to know if mine looks like that...because if it did it would bother me....
Mongle is offline   Reply With Quote
Old 10-03-2012, 02:43 PM   #69944
procycle
procycle's Avatar
Oddometer: 1,607
Evidently there is some crystalline filler used with the rubbery (silicone?) potting material. Looks to me like some of the filler was not very level when they poured the potting material in.
Old 10-03-2012, 03:53 PM   #69945
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,458
please explain that more in detail, step by step with the proper torque specs, if you have all that info. that would also be good for krusty's DR index.
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
eakins is online now   Reply With Quote
Times are GMT -7.   It's 10:09 PM.
