Old 10-11-2012, 04:49 PM   #69961
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,793
Dude, slow down!
But, we just got passed by a KLR...
I don't care; we are going WAY to fast!
Mongle is online now   Reply With Quote
Old 10-11-2012, 05:15 PM   #69962
FlowBee
Just me.
FlowBee's Avatar
Oddometer: 5,754
Originally Posted by procycle View Post
The pilot jet is probably partially clogged from all that sitting around.
This.
I agree with Jeff. The first thing that went through my mind was.... "what happened to the gas left in the carb all those years?"
"And then this one time at banned camp ....."
FlowBee is offline   Reply With Quote
Old 10-11-2012, 06:25 PM   #69963
Chill
Chill's Avatar
Oddometer: 317
Originally Posted by Skidmarkart View Post
Question - since this bike is older, and has low miles, is there any particular maintenance I should do? I am assuming that I will need to do the oil, filters, etc. I do not know if the bike had the 600 mile valve adjustment tune up. It seems to run well, but it is difficult to start at times and seems to bog-down a little bit at lower rpms. I am sure I can find this info inside, but jeebus, there's a to sort through.
Any advice would be appreciated.
It sounds a lot like mine. 2008 model but only 3,000kms. I changed the oil and filter and the old oil was like black water. The new oil went black pretty quickly so I changed it again after another 300 miles and the new oil has stayed cleaner looking. Anyway, I have noticed that the thing seems to sort of be self cleaning itself and the gear changing is getting smoother, especially the neutral to first change. I also put in a magnetic drain plug and filter magnet so try and catch any wear debris.
As for the bogging down at low revs, they are a bit like that even when they're running tip top I think. It took me a while to adjust my riding style so that I was in the right gear coming out of corners and still misjudge it a bit sometimes and have to slip the clutch a tiny bit to get past that low rev "hammering" that they seem to do. I don;t think the "hammering" does any real damage but it still makes my mechanically sympathetic teeth itch.
*edit* meant to mention that when I did the oil changes I also did an engine flush, basically add about 250ml of engine flush like Nulon and then let it idle for 10 mins before draining the oil. It will thin the oil and dissolve some of the sludge that builds up inside the engine.
Chill is offline   Reply With Quote
Old 10-11-2012, 06:45 PM   #69964
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
Originally Posted by victor441 View Post
do it this way, with cable ties...5 minutes is possible with practice and it is nearly impossible to pinch the tube, very little force is required to get the tire on the rim (did not invent the method, learned it from another thread here) Also get some tire lube from Napa, makes the job easier and works better than soapy water. No need to cut the ties one the tire is on the rim, it is easy to release the locking tab with a small screwdriver so they can be reused
Is there a thread with more details you could link me to? I want to be sure I understand how this works. I'm assuming you spoon on the tire complete and not one side at a time. Seems like a game changer?
Edit: I found this thread that describes using straps, sp the same concept. Still looking and learning!
http://www.advrider.com/forums/showthread.php?t=299597
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper screwed with this post 10-11-2012 at 08:39 PM
GaThumper is offline   Reply With Quote
Old 10-11-2012, 07:14 PM   #69965
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,488
From what i have seen, the tire just slips right on, may take a little lube.
ChromeSux is offline   Reply With Quote
Old 10-11-2012, 07:28 PM   #69966
Chill
Chill's Avatar
Oddometer: 317
I like the look of that zip tie method a lot. Looks like it gets round the problem of getting the valve through the rim too. (that was a major PITA for me) I'm guessing that the valve goes in first which keeps the bead in the dish of the rim (Jeez, get me, I've done it once and I'm throwing all these technical terms round like a pro)
Old 10-11-2012, 07:44 PM   #69967
Sierra Thumper
Oddometer: 641
Pissed
Originally Posted by Kommando View Post
I don't know how much total gas my IMS will now hold, but I often hit Reserve at 220-230 miles, and have gone over 250 on Reserve several times. I've never run it dry, but I've filled it with almost 5.3gal a few times. I haven't yet had to tilt the bike to get more gas either.
BTW...I currently use a Suzuki OEM petcock, and my carb inlet is turned.
The IMS tank seems extremely durable, and the white one looks like yellowed hell after a bit of heavy use.
My bike came with a white IMS tank, its a lower mileage 04, not sure how long the tanks been on there and if the bike was parked outside in the sun alot, causing the fuel to stain through the tank worse, but the bike looks awesome except for that birdcrap-yellow tank. I scrubbed the hell outta the tank with soft-scrub, its better but still yellow. Not as bad as some I've seen, but bad enough to irritate the hell outta me
I'll never buy a white aftermarket gas tank.....ever.
I'm either going to get a decal kit for it or buy another color tank.....we'll see
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-11-2012, 08:07 PM   #69968
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,598
Forget decals. They won't stick for long. But I wonder if you couldn't dye the tank a different colour?
My white IMS tank has been on the bike for 10 years and it's still white.
Maybe that is bird poop on yours?
Old 10-11-2012, 08:12 PM   #69969
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
Originally Posted by neo1piv014 View Post
Here's a mod I think everyone should do to their DR's. It's a little hard to stabilize off road, but the benefits are obvious when you finally reach your destination.
Also, if you're working on your bike in the garage, it provides a much needed distraction.
thats awesome . I was actully checking out a pipe like that earlier this week
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim screwed with this post 10-11-2012 at 08:59 PM
PPCLI-Jim is offline   Reply With Quote
Old 10-11-2012, 10:29 PM   #69970
victor441
victor441's Avatar
Oddometer: 931
you are right,It is very easy to get the valve stem stem through the rim using zip ties (and put the locknut on it) , then remove the ties and inflate the tire...the tube needs to be inflated just enough to round it out before it is put in the tire and the zip ties are installed. I've only installed three tires this way but am completely sold on the method, no damage to the tube, the rim, or my fingers this way. The whole process goes very quickly with a little practice
victor441 is offline   Reply With Quote
Old 10-11-2012, 10:36 PM   #69971
victor441
victor441's Avatar
Oddometer: 931
that is indeed the one that enlightened me, I should have posted the link. FWIW 24" zip ties should be big enough for nearly any tire and they are easy to find, got mine at a big box hardware store
Old 10-12-2012, 04:05 AM   #69972
TinMan207
Most often a lurker...
TinMan207's Avatar
Oddometer: 1,603
Any pics of that "tire change" stand? or how it's made? Seems a world better than flopping around on the ground.
When I was young I hoped to be Rich and good looking. At this point, I think that having great stories of many adventures is a much better plan
06 Suzuki DL650 (2 at the moment!) - 00 DR650
TinMan207 is offline   Reply With Quote
Old 10-12-2012, 07:04 AM   #69973
neo1piv014
ADV in training
Oddometer: 619
That poor old bastard hookah is currently held together with a combination of RTV gasket sealant and packing tape.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-12-2012, 07:07 AM   #69974
Rumlover
Ed
Oddometer: 707
Wow. Just wow. This thread is awesome.
I am the proud new owner of a DR650. I can see my job performance is going to suffer due to this very thread. I just got a 2005 DR650 with only 800 miles on the clock. The guy I got it from only rode it 100 miles in the year he owned it!?! How that happened is beyond me because I just rode it 100 miles over the weekend. No adult should be able to have this much fun getting to work!
- Change oil as already suggested.
- Run a good dose of Techron fuel additive through it to clean out the pilot jet, etc.
- Remove the top chain roller if not already gone and plug bolt hole with silicone.
- Get some case guards ASAP (AMP or Procycle can supply them). One tip over can put the shifter through the case.
Edit: Also, as already touched on, the stock (cv) carb setup makes the bike a little touchy when RPMs are too low and can make the engine shutter, vibrate, and basically sound like a rod is letting go..
Don't panic just keep the RPMs a little higher.
Rumlover screwed with this post 10-12-2012 at 07:23 AM
Rumlover is offline   Reply With Quote
Old 10-12-2012, 07:45 AM   #69975
neo1piv014
ADV in training
Oddometer: 619
Last night, I decided to have a go at cleaning out my carburetor. The bike had been down on fuel economy, and definitely down on power. I couldn't really shift into fifth gear until around 60 mph without it feeling bogged down and shaky. Just pulling the cap off showed years of dirt and grime that had accumulated. The BST bible thread was a damn near perfect guide to follow, though there were some minor differences. For instance, the pictures there showed some kind of white chicklet ring in the main needle spring, whereas mine was just a spring. I'm not 100% sure what it does, but I guess that I've been running without it for all this time so it couldn't hurt. I also noticed that my needle didn't have any notches for a clip to go into. I took the jets out and cleaned everything out with Simple Green and a hot water rinse. All the parts were dried out with a towel, some q-tips, and a box fan, and they looked shiny again. After getting everything put back together and on the bike, I took it out for a test drive around the neighborhood, there was an immediately noticeable difference. I dropped it into fifth gear at 45 and didn't get any of the bogging down feeling I'd previously had. So if you feel like your bike is down on power, it might just need a good cleaning.
Ride videos
'01 DR650
Times are GMT -7.   It's 03:53 PM.
