Old 10-12-2012, 06:58 AM   #69976
buckrut1972
H.R. Nightmare
buckrut1972's Avatar
Oddometer: 112
New DR650 myself
Remove the top chain roller if not already gone and plug bolt hole with silicone.
May I ask why?
"Never argue with stupid people, they will drag you down to their level and then beat you with experience" Mark Twain
buckrut1972 is offline   Reply With Quote
Old 10-12-2012, 07:04 AM   #69977
thetable
thetable's Avatar
Oddometer: 1,449
May I ask why?
Because if it breaks off, and they have, it takes the frame with it.
thetable is online now   Reply With Quote
Old 10-12-2012, 07:09 AM   #69978
Rumlover
Ed
Oddometer: 707
May I ask why?
The chain has been known to break the roller out of the frame, leaving a big hole in the frame. Although some argue it is ok to leave it on, I personally don't see the advantage.
There has been no problems ever reported (that I am aware of) from removing it. The general consensus is to just remove it and forget it.
Some with good fabricating skills have moved it to a different location.
Rumlover is offline   Reply With Quote
Old 10-12-2012, 07:14 AM   #69979
sandwash
sandwash's Avatar
Oddometer: 1,358
They placed the roller too low on the frame,under the right conditions the chain will want to straighten out and will take the roller out along with part of the frame.Remove it and replace it with a locktite set screw.Then replace lower one with a bearing type,won't be as noisy as the stock one.This is where the upper roller used to be:
97dr650
sandwash screwed with this post 10-12-2012 at 07:31 AM
sandwash is offline   Reply With Quote
Old 10-12-2012, 08:43 AM   #69980
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,355
Originally Posted by sandwash View Post
No yellowing on the clear IMS after 3 years.
The 7 year old yellow IMS tank on my DR650 is still yellow...
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance screwed with this post 10-12-2012 at 08:52 AM
FatChance is offline   Reply With Quote
Old 10-12-2012, 09:56 AM   #69981
victor441
victor441's Avatar
Oddometer: 950
Originally Posted by TinMan207 View Post
Any pics of that "tire change" stand? or how it's made? Seems a world better than flopping around on the ground.
sure, I posted some when I made it at http://advrider.com/forums/showthread.php?t=822721
and it was definitely worth the effort, it is much easier for me to change tires with the wheel clamped down and at waist level
victor441 is offline   Reply With Quote
Old 10-12-2012, 10:15 AM   #69982
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,277
It was white when you bought it. Right?
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-12-2012, 10:26 AM   #69983
motolab
motolab's Avatar
Oddometer: 2,628
Originally Posted by neo1piv014 View Post
For instance, the pictures there showed some kind of white chicklet ring in the main needle spring, whereas mine was just a spring. I'm not 100% sure what it does, but I guess that I've been running without it for all this time so it couldn't hurt.
The DR650 also uses a lower spring seat. Suzuki calls it a "ring" and its part number is 13331-12D00. Without it, the needle will rattle and the slide spring preload will be reduced.
Did you inspect the float needle, slide guide, emulsion tube, jet needle, and slide for wear?
With the needle having been allowed to rattle around like that, I would be most concerned about emulsion tube, jet needle, and slide needle hole wear.
How many miles are there on the carburetor?
Regards,
Derek
motolab screwed with this post 10-12-2012 at 10:55 AM
motolab is offline   Reply With Quote
Old 10-12-2012, 10:35 AM   #69984
ER70S-2
ER70S-2's Avatar
Oddometer: 6,471
Stock '04 DR650.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-12-2012, 11:13 AM   #69985
Rusty Rocket
Life behind "Bars"
Oddometer: 9,277
Was out playing Tag-O-Rama last Friday. Last pic of this bike in "street attire" Turned 20,000 miles that afternoon.
Now she goes back to knobbies a smaller mirror and a 14 tooth sprocket. The tankbag will stay for the first dirt ride for evaluation purposes. Any problems and it comes off
2009 DR650
Old 10-12-2012, 11:20 AM   #69986
neo1piv014
ADV in training
Oddometer: 619
Regards,
Derek
The bike has 10600 miles on it, but I don't know how many of those were without that ring. The PO said he pit a DJ kit in there so it might have happened then. I didn't see any kind of noticeable wear on my Carb parts that made me concerned. What exactly should I be looking for? I'll try to find that ring online somewhere.
Sent from my LG-P999 using Tapatalk 2
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-12-2012, 12:31 PM   #69987
motolab
motolab's Avatar
Oddometer: 2,628
If the jet needle does not have more than one clip groove, it's not a DJ needle. Is the white needle spacer installed under the clip? If so, is it round, without a notch or being d-shaped?
The rubber tip of the float needle should be inspected under magnification. It should perfectly conical, with no witness line evident where it was contacting the seat. If any evidence is visible, or if there is a gap between the bottom edge of the rubber tip and the aluminum portion of the needle, if the plunger is stuck, or if the plunger return spring is sacked out, the needle should be replaced. Not doing so means that the float valve is leaking, or will begin leaking soon.
Emulsion tube wear generally sets in rapidly when the slide guide has worn .010" or more. The way to tell is to measure the depth of the depressions that are located in the bottom corners, concentric to the bore. If they are .010" deep or less, the slide guide should be replaced. '96 and up DR650 emulsion tubes are nickel plated, and so a bit more wear resistant than those found on previous models or KTMs. I don't know how thick the plating is, but if the nickel has worn away to expose the brass, it's definitely time to replace. Replace the slide if the lift hole area has been increased over stock, if there is vertical grooving on the downstream side, or if the needle hole is enlarged and/or ovaled.
See (scroll down for description and links. Click image for high-res view):
Slide guide, used
Slide guide, new
Emulsion tubes, new and used
Slide, used
Slide, new
Regards,
Derek
Old 10-12-2012, 02:13 PM   #69988
neo1piv014
ADV in training
Oddometer: 619
Well, it looks like I'm going to be pulling the carb apart again this evening to check this all out. The needle does have a white spacer on it, and I think it was pretty much perfectly round. At least, nothing stuck out in my memory of it. Is the "float needle" that large needle in the slide?
Actually,. I might be better off waiting until I get home to ask questions since I can't check out the pictures at work. Thanks for the info dump, though. It's much appreciated.
If the jet needle does not have more than one clip groove, it's not a DJ needle. Is the white needle spacer installed under the clip? If so, is it round, without a notch or being d-shaped?The rubber tip of the float needle should be inspected under magnification. It should perfectly conical, with no witness line evident where it was contacting the seat. If any evidence is visible, or if there is a gap between the bottom edge of the rubber tip and the aluminum portion of the needle, if the plunger is stuck, or if the plunger return spring is sacked out, the needle should be replaced. Not doing so means that the float valve is leaking, or will begin leaking soon.
Slide guide, used
Slide guide, new
Slide, used
Slide, new
Regards,
Derek
Ride videos
'01 DR650
Old 10-12-2012, 02:32 PM   #69989
JTB488
Oddometer: 152
The float needle is a small brass needle with a rubber cone shaped tip on the pivoting end of the float.
JTB488 is offline   Reply With Quote
Old 10-12-2012, 02:50 PM   #69990
neo1piv014
ADV in training
Oddometer: 619
Umm...I didn't see anything like that when I pulled my carb. Does it go into something? Like would it have maybe stayed inside of one of the many holes in the carb? I know the bike ran great after I put everything together, so I'm kind of curious what else I may have missed.
Ride videos
'01 DR650
Times are GMT -7.   It's 11:57 AM.
