Old 10-12-2012, 04:01 PM   #69991
wayno
wayno's Avatar
Oddometer: 6,870
Originally Posted by FatChance View Post
The 7 year old yellow IMS tank on my DR650 is still yellow...
Mines still blue after 5/6 years...wish it would turn clear so I could mark gallons
RIDE SAFE
wayno is offline   Reply With Quote
Old 10-12-2012, 04:04 PM   #69992
neo1piv014
ADV in training
Oddometer: 627
Originally Posted by motolab View Post
To remove the float needle, you have to separate the float from the cage. When you put it back together, using a float height too, set the float height to 14.7mm.
Regards,
Derek
Okay. I think that might be where it is then. When I removed the float, I pulled that tall column thing that was on one side, and then I pull the other side out where it was all flat down one edge. It all came up at the same time, and nothing fell off it, so I just assumed it was all one piece. If I get some time this weekend, I'm going to take it back off the bike and see about doing a more thorough examination.
Oh, and I went ahead and looked up that missing part from the spring on Bike Bandit. It's only $7.00, so I might as well go ahead and grab that.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 screwed with this post 10-12-2012 at 04:05 PM Reason: Added info
neo1piv014 is offline   Reply With Quote
Old 10-12-2012, 05:03 PM   #69993
JTB488
Oddometer: 153
Look in the BST-40 bible thread, shows the needle and float together in one pic,looks to be aluminum in ours, but still the little rubber tip.
JTB488 is offline   Reply With Quote
Old 10-12-2012, 05:34 PM   #69994
neo1piv014
ADV in training
Oddometer: 627
The BST Bible was what I went off of. That was where I noticed that my spring was missing a part. I just didn't see where to get at that float needle thing. After many frustrating experiences, I've learned better than to try forcing small, plastic parts around. Now that I know they come apart, however, I can check them out. I'm also looking at getting a TM40 for this bike before too long anyways, so this might all be a moot point, but it's always good to learn.
Ride videos
'01 DR650
Old 10-12-2012, 05:35 PM   #69995
Sierra Thumper
Oddometer: 641
Lucky you
I have a plan to turn my yellow-that-used-to-be-white IMS tank white again. I found that using a scotchbrite pad with soft scrub with bleach helped quite a bit.....I just didn't want to spend 24 hours scrubbiing on it to get the best results. So I'm going to get some scotchbrite type pads for my electric drill, along with the softcrub, and use a slower speed to scrub the tank beyond belief.
Believe me that sob is going to be white again
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-12-2012, 05:58 PM   #69996
ER70S-2
ER70S-2's Avatar
Oddometer: 7,225
You'll have to learn how a carb works, one way or another.
Something like this from the BST-Bible:
Hides in here on our DRs.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-12-2012, 06:22 PM   #69997
neo1piv014
ADV in training
Oddometer: 627
Ohhh! Yeah, I saw that part. I guess I just need to pull it out and check it for wear. So I guess I must have put something back together a little incorrectly. I thought it was running well, but now it has a very rough idle if you're not on the choke and pops like crazy on decel. I'm going to order that clip for my spring, and I guess I need to fiddle with my fuel mixture screw. I thought I had measured two full turns, though I could just be a quarter turn or so off when I reset it. Do you back the screw out to richen the mixture a bit?
Ride videos
'01 DR650
Old 10-12-2012, 06:33 PM   #69998
ER70S-2
ER70S-2's Avatar
Oddometer: 7,225
2013 WR250R
Old 10-12-2012, 06:48 PM   #69999
neo1piv014
ADV in training
Oddometer: 627
Tell you what, I'm going to devise quick release systems for the side panels, seat, and fuel tank. Even if I don't become a millionaire, I'm sure I'll save about 10,000 man hours per year.
Ride videos
'01 DR650
Old 10-12-2012, 07:12 PM   #70000
doug s.
Oddometer: 1,354
definitely stop wasting your time - get a tm40 or fcr39. the bst40 is simply not worth learning about, imo...
ymmv,
doug s.
doug s. is offline   Reply With Quote
Old 10-12-2012, 08:04 PM   #70001
ER70S-2
ER70S-2's Avatar
Oddometer: 7,225
Ain't that the truth!!
2013 WR250R
Old 10-12-2012, 08:11 PM   #70002
neo1piv014
ADV in training
Oddometer: 627
I've also learned a valuable lesson about why I need to get that god damned extended fuel screw. So I backed the fuel screw out about 1/2-1/4 of a turn. The bike fired up, with choke, but when I gave it throttle, the engine would sputter and die. Assuming that I had the mixture too rich, I screwed it in about 1/4 turn, put everything back in place, and fired it up again. It's about the same. The idle is still very "chuggy" and dies after about 10 seconds, and now, when I open the throttle any more than 1/3 or 1/2, the engine sputters and dies. I'm assuming that I'm running too rich, but I also know next to nothing about carburetors, so I might be a bad judge here. Does it sound like I'm running too rich?
Ride videos
'01 DR650
Old 10-12-2012, 08:40 PM   #70003
motolab
motolab's Avatar
Oddometer: 2,851
The pilot screw should only be used to tune the idle mixture. Anything that is not idle is the responsibility of other components. Correspondences on CV carbs:
Low rpm all throttle positions: float height, needle base diameter, emulsion tube outlet size
WOT operation overall: main jet
WOT operation between HP peak and red line: main air corrector
WOT operation below red line: jet needle shape
1/4 throttle opening: jet needle clip position
1/8 throttle opening: pilot jet size
1/16 throttle opening: pilot jet size
idle: mixture screw adjustment
Realistically, the float needle condition should be verified and the float height set before the idle mixture is adjusted.
Procedure:
Hold the carb in one hand and hold the base of the float cage tightly against the carb body with the index finger of the same hand. Rotate the carb so that the float tang just contacts the float needle's spring loaded plunger, but does not depress it. With the float height setting tool set to the desired height, use the other hand to drop it down over the float so the tool's posts contact the bowl gasket surface and the posts are square to the body (front to back - the tool takes care of side to side). Flip the tool to check both sides (as the float may have some twist in it). Bend the float tang until the tang on the float height setting tool just contacts the highest point on the float, but does not depress it.
Procedure for setting idle mixture:
Start the engine and warm it up. Lower the idle speed below the factory spec. Starting from a setting that is known to be lean (1-1/2 turns is likely but not guaranteed to be), adjust the fuel screw to obtain the highest idle speed. Adjust to 1/8 - 1/4 turn richer than that. Then, adjust the idle speed back to 1500 rpm.
Once you have the correct fuel screw setting, there should not be too many reasons to have to revisit very often. I'm therefore not a big proponent of extended fuel screws. If you intend to own carbureted motorcycles in the future, I recommend procuring an angle-drive screwdriver, which will be universally applicable.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-12-2012, 08:44 PM   #70004
ER70S-2
ER70S-2's Avatar
Oddometer: 7,225
Screw it in snug, back it out 1-1/2 turns, ride. Some time ago (39,000 miles or so), I was browsing the internet and I kept seeing 1-1/2 turns. Sounded good to me. I've since bought the extended fuel screw and messed with it. I'm still at 1-1/2 turns, give or take. At my altitude (6000 +), I'm satisfied; although I've heard that riding a TM-40 or FCR will ruin me forever (or until I convert).
Yesterday, my baby turned 40.
205'd by motolab
2013 WR250R
Old 10-12-2012, 08:49 PM   #70005
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Thumb screws...made all the difference
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Times are GMT -7.   It's 01:32 PM.
