Old 10-12-2012, 09:11 PM   #70006
neo1piv014
ADV in training
Oddometer: 619
I've also learned a valuable lesson about why I need to get that god damned extended fuel screw. So I backed the fuel screw out about 1/2-1/4 of a turn. The bike fired up, with choke, but when I gave it throttle, the engine would sputter and die. Assuming that I had the mixture too rich, I screwed it in about 1/4 turn, put everything back in place, and fired it up again. It's about the same. The idle is still very "chuggy" and dies after about 10 seconds, and now, when I open the throttle any more than 1/3 or 1/2, the engine sputters and dies. I'm assuming that I'm running too rich, but I also know next to nothing about carburetors, so I might be a bad judge here. Does it sound like I'm running too rich?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-12-2012, 09:40 PM   #70007
motolab
motolab's Avatar
Oddometer: 2,521
The pilot screw should only be used to tune the idle mixture. Anything that is not idle is the responsibility of other components. Correspondences on CV carbs:
Low rpm all throttle positions: float height, needle base diameter, emulsion tube outlet size
WOT operation overall: main jet
WOT operation between HP peak and red line: main air corrector
WOT operation below red line: jet needle shape
1/4 throttle opening: jet needle clip position
1/8 throttle opening: pilot jet size
1/16 throttle opening: pilot jet size
idle: mixture screw adjustment
Realistically, the float needle condition should be verified and the float height set before the idle mixture is adjusted.
Procedure:
Hold the carb in one hand and hold the base of the float cage tightly against the carb body with the index finger of the same hand. Rotate the carb so that the float tang just contacts the float needle's spring loaded plunger, but does not depress it. With the float height setting tool set to the desired height, use the other hand to drop it down over the float so the tool's posts contact the bowl gasket surface and the posts are square to the body (front to back - the tool takes care of side to side). Flip the tool to check both sides (as the float may have some twist in it). Bend the float tang until the tang on the float height setting tool just contacts the highest point on the float, but does not depress it.
Procedure for setting idle mixture:
Start the engine and warm it up. Lower the idle speed below the factory spec. Starting from a setting that is known to be lean (1-1/2 turns is likely but not guaranteed to be), adjust the fuel screw to obtain the highest idle speed. Adjust to 1/8 - 1/4 turn richer than that. Then, adjust the idle speed back to 1500 rpm.
Once you have the correct fuel screw setting, there should not be too many reasons to have to revisit very often. I'm therefore not a big proponent of extended fuel screws. If you intend to own carbureted motorcycles in the future, I recommend procuring an angle-drive screwdriver, which will be universally applicable.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-12-2012, 09:44 PM   #70008
ER70S-2
ER70S-2's Avatar
Oddometer: 6,124
Screw it in snug, back it out 1-1/2 turns, ride. Some time ago (39,000 miles or so), I was browsing the internet and I kept seeing 1-1/2 turns. Sounded good to me. I've since bought the extended fuel screw and messed with it. I'm still at 1-1/2 turns, give or take. At my altitude (6000 +), I'm satisfied; although I've heard that riding a TM-40 or FCR will ruin me forever (or until I convert).
Yesterday, my baby turned 40.
205'd by motolab
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 10-12-2012, 09:49 PM   #70009
planemanx15
planemanx15's Avatar
Oddometer: 1,007
Tell you what, I'm going to devise quick release systems for the side panels, seat, and fuel tank. Even if I don't become a millionaire, I'm sure I'll save about 10,000 man hours per year.
Thumb screws...made all the difference
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-12-2012, 09:56 PM   #70010
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
got my single track setup. 18" rear wheel with 90/90-18 and drive hub with off road gearing.
I have a street tire for the 17" rear with another drive hub and highway gearing.
I've also made a different dog bone plus the larger wheel gives me about an extra inch of ground clearance.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 10-12-2012, 10:10 PM   #70011
neo1piv014
ADV in training
Oddometer: 619
Regards,
Derek
1/4 Throttle opening sounds about right for where it starts dying, and if I remember my names correctly, that's where the clip is missing from the spring. So if that clip isn't there, I'm guessing that's letting the jet needle move around incorrectly. If that was jacking with my fuel flow, then maybe that's causing it to die out? I don't get why this didn't happen before, and I'm damn near positive that I didn't see that clip when I pulled out the spring, but I've been checking around my work area just in case it fell out when I was pulling it out.
205'd by motolab
I'll give 1 1/2 a try tomorrow when I'm ready to get dirty again. I'm right at the same altitude as you, so it's at least a starting point. I've been wanting to snag a TM-40 after the first review I read for one. Considering all the stupid stuff I spend money on, $450 really isn't all that much.
Ride videos
'01 DR650
Old 10-12-2012, 10:10 PM   #70012
neo1piv014
ADV in training
Oddometer: 619
Woah. That's a crazy skinny rear tire. Does it still have enough traction with that narrower profile?
Ride videos
'01 DR650
Old 10-12-2012, 10:38 PM   #70013
TinkerinWstuff
Take it apart
Oddometer: 1,292
should be ass-loads of traction on the single track.
probably not so good on the paved canyon twisties, but that's what the 17" wheel is for. This is my single track only setup.
1999 Suzuki DR650
Old 10-13-2012, 03:25 AM   #70014
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
Cool2 Fortunes to be made on fasteners.
I don't know how old many of you are but WAYYY back in the day, I recall my old YZ 125 A to date myself. You know BEFORE the days of one shock suspension . It had aircraft DZUS (sp?) quick connects to hold the side panels on. To refresh old dusty memories, it was like a bolt with a single slot with a quarter turn and and a notch. On the other side there was a heavy gauge wire that would hold it together . Its along the lines of an interrupted screw.
For the gas tank you can use more of these OR there is the alternative of having a stud welded in with a hole drilled in the top of it so you can pass a cotter pin /' a linchpin with an integral sprung retainer through it(connect these to the frame with a small wire so you dont lose them). Add a washer then pin the tank down the tank into location . That along with the seat being held down holding the tank in position should seem secure.I may not be smarter then the average bear but I am almost as old as dirt. Now who's gonna send me a royalty check.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim screwed with this post 10-13-2012 at 03:37 AM Reason: A mind like mine is always abuzz with ideas
PPCLI-Jim is offline   Reply With Quote
Old 10-13-2012, 04:06 AM   #70015
greer
Oddometer: 3,729
White tank
Westley's Bleache White (tire/whitewall cleaner from Walmart) worked very well on a white tank I had. I soaked paper towels in the Westley's and left them draped on the tank overnight. Soak them again the next morning if you need to.
Sarah
Originally Posted by Sierra Thumper View Post
Lucky you
I have a plan to turn my yellow-that-used-to-be-white IMS tank white again. I found that using a scotchbrite pad with soft scrub with bleach helped quite a bit.....I just didn't want to spend 24 hours scrubbiing on it to get the best results. So I'm going to get some scotchbrite type pads for my electric drill, along with the softcrub, and use a slower speed to scrub the tank beyond belief.
Believe me that sob is going to be white again
'08 DR650
greer is offline   Reply With Quote
Old 10-13-2012, 04:27 AM   #70016
greer
Oddometer: 3,729
When you break into the carb, be sure to check the condition of the two o-rings on the float assembly. They'll deteriorate with age and allow gas to leak thru. This might not be such an issue with a stock vacuum-operated tank but it'll get you in trouble in a hurry with a gravity-fed system like an IMS. Congrats on the bike!
Sarah
Originally Posted by Skidmarkart View Post
Wow. Just wow. This thread is awesome.
I am the proud new owner of a DR650. I can see my job performance is going to suffer due to this very thread. I just got a 2005 DR650 with only 800 miles on the clock. The guy I got it from only rode it 100 miles in the year he owned it!?! How that happened is beyond me because I just rode it 100 miles over the weekend. No adult should be able to have this much fun getting to work!
Question - since this bike is older, and has low miles, is there any particular maintenance I should do? I am assuming that I will need to do the oil, filters, etc. I do not know if the bike had the 600 mile valve adjustment tune up. It seems to run well, but it is difficult to start at times and seems to bog-down a little bit at lower rpms. I am sure I can find this info inside, but jeebus, there's a to sort through.
Any advice would be appreciated.
'08 DR650
Old 10-13-2012, 05:20 AM   #70017
buckrut1972
H.R. Nightmare
buckrut1972's Avatar
Oddometer: 112
Sta-Bil
Want to run Sta-Bil to keep things runnin good but I see they have this Marine Sta-Bil for 2 and 4 cycle motors....has any one had good luck with this newer stuff?
"Never argue with stupid people, they will drag you down to their level and then beat you with experience" Mark Twain
buckrut1972 is offline   Reply With Quote
Old 10-13-2012, 09:01 AM   #70018
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,845
Typically, as the contact patch decreases the contact pressure increases. As you lose floatation you often increase bite, or traction due to the smaller contact patch. I have more experience in offroad truck tires, but if you want to increase traction, you often need a narrower tire. There are trade offs and conditions can dictate what works in a given situation, but riding desert sand might favor a wider tire, where you need more floatation, and forest single track might favor a narrower tire, where the narrower tire has more traction.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 10-13-2012, 09:37 AM   #70019
Fire Escape
Fire Escape's Avatar
Oddometer: 1,554
There are a myriad of opinions about additives, since you asked, this is mine. Reports a few years back were that the higher percentage of alcohol in fuel (and the water it attracted and held) was causing good old red Stabil to be less effective. I don't know what it's 'failings' were but I changed over to the green (Marine Formula) about 5 years ago and haven't had any problems. That said, it is entirely possible that had I not used anything the results 'could' have been the same. I put it in my boat whenever it will not be used for a while, I usually add it to my bikes when the weather gets cool (due right about now). I try not to mix additives since I have no idea if they will 'play nice together', I generally keep a can of SeaFoam near my gas can and add some of that every time I fill the can so my small engines never see 'untreated gas'. Probably either, both or none of them wouldn't change much but this works well for me and I am happy (maybe just because I 'think' that I am doing something for my engines). Despite all of that, I am leaning toward replacing both with Startron, based on reports from others who have done well. YMMV!
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 10-13-2012, 11:12 AM   #70020
motolab
motolab's Avatar
Oddometer: 2,521
Sound advice, except a distinction should be made between the two o-rings. The smaller one of the two is the cold start enrichment feed pipe o-ring, and the larger one is the float seat o-ring. Of course they're both important, but it's the latter of the two that pertains to the concern you raise. Also, it's just as much of an issue with a vacuum operated petcock. Sure, the vacuum operated petcock theoretically shuts the fuel off when the engine is not running. However, whether it's being opened via vacuum or manually, the petcock has to be open when the engine is running, and the bowl only overflowing when the engine is running is really no better than overflowing all the time.
Regards,
Derek
Times are GMT -7.   It's 12:20 PM.
